06-22-2023, 07:47 PM | #1 |
Rep 1,424
Soft top discoloration
I had my 2022 M850i ceramic coated about 3 weeks ago and have not washed it since. It rained a few days ago and I noticed some white discoloration on the edge of the fabric which has NEVER happened before. I let the detailer know and will take it there on friday for them to look at it. It might just wash off? I'll just leave it for now so they can look at it. I've never had that happen before with rain.
Rob |
06-22-2023, 07:49 PM | #2 |
Rep 5,145
Posts Drives: 22 Z4 M40i, 21 228i Retired Join Date: Sep 2021
So you think that the ceramic coating caused this issue?
06-23-2023, 01:08 AM | #3 |
Rep 1,424
I have no idea, but they did put something on the soft top. I don't think it's related to that otherwise other areas would be turning white.
I took a really wet cloth and dabbed the area, but it didn't help. Once it dried it was back to being white. I think it's contamination of ceramic coating into the cloth material. The material doesn't look frayed or show signs of physical damage. Rob |
06-23-2023, 08:38 AM | #4 |
Rep 5,145
I initially put ceramic coating on my Z4 after I had PPF installed almost 2 years ago. Last week I had it done again as where I park at my condo my car faces southwest and is subject to very strong direct sunlight virtually all day long and the many extremely heavy rain storms that are normal in South Florida. I never noticed any discoloring on my top like you have shown in your photos after they had applied the ceramic coating on my car. My shop first applies Ceramic Pro's 9H followed by their Top Coat ceramic products.
You should inquire what brand of ceramic coating they are using when you visit and how they applied it to your M850i. If you see them putting ceramic coating on other cars when you visit check that out first and see how they do it before your discussion with the owners of the shop. |
06-23-2023, 11:11 AM | #5 |
Rep 1,165
Rob -
Take a fine mist sprayer and spray the top.... How even is the -beading- on it. Just to see as a baseline how consistent is the coating on the material. I have not seen white as you speak, but I have seen -inconsistent- evens of the coating, which is not you depict or describe |
06-23-2023, 12:02 PM | #6 |
Rep 5,145
I just showed your photos to the shop that did my PPF, and ceramic coating and he said it is possible that when they did the color correction the buffing pad could’ve come in contact with the soft top and caused this to happen if the person working on your car wasn’t careful. Also, they should’ve use tape to protect the top while working on the paint.
Merlin_83486.50 |
06-23-2023, 12:12 PM | #7 | |
Rep 1,424
This shop is generally reputable, but I already told them before their attention to detail wasn't very good on this job. For example, they washed the car, but left the inner trunk area completely dirty still. They also missed applying ceramic to a part of the bumper where the trunk overhangs. Now it's apparent they have contaminated the edges of the soft top with polishing compound. If that's what it is... so stay tuned! Rob |
06-23-2023, 01:15 PM | #9 |
Rep 5,145
06-25-2023, 02:21 AM | #10 | |
Rep 1,424
I took this photo tonight of the soft top while in a parkade. The lighting made the top look really bad. Whatever thet put on the cloth, you can see the inconsistent application. This is obviously going from bad to worse. I think I'm just going to ask for them to remove whatever they put on there. If they can't, well they owe me a new roof then. Rob |
06-25-2023, 07:44 AM | #11 | ||
Rep 5,145
This latest complaint doesn't make any sense, inconsistent application of what? Did you have them treat or clean the top with any product when they ceramic coated the paint? |
06-25-2023, 06:33 PM | #12 |
Rep 1,424
06-25-2023, 06:40 PM | #13 |
Rep 1,165
Rob -
This is an easy fix I suppose.....the only ? is that you seem to state the edges only turn white after you wet it ? Anyhow, detailer will probably use a heavy cleaner, remove the coating so it's one clean base. After a rinse, and visual, he still might need to attend to areas where the coating has not been removed. Once you have a -perfect- clean base, then as long as the coating is done correctly, you should be fine... Can't speculate on the white as you did not go into further details, but the recent pic due to un even application |
06-25-2023, 10:10 PM | #14 | |
Rep 1,424
I have such a bad history with this car already that I'm just trying to not get even more frustrated as it is. Rob |
06-26-2023, 08:11 AM | #15 |
Rep 1,165
Did you do a quick -fine spray- pattern with water - misting - to see the beading. Was in the same or none in the area you describe versus where you know you visibly have coating - per recent pic.
Looks you the top needs to be re-done regardless but I myself would want to know what flaws were left when you left the shop. Do a test spot on a known white part. Take something maybe like dishwashing liquid diluted with some water and an old toothbrush. Scrub/clean some of the edge and see if you get back to clean. Once clean, rinse and let it dry. Then wet again and see what happens. HEREIN lies the problem which is just more a OCD thing. Anything you rub, even on a minute level - you are potentially change the texture of your ragtop. |
06-26-2023, 08:49 AM | #16 |
Rep 5,145
It seems that you are jinxed, first you had dealer issues on your Z4 and now this. Maybe BMW has put a curse on you and you need to consider buying from a different car manufacturer?
