07-06-2022, 06:28 AM | #23 |
Rep 457
Yes, Top Tier is a real thing and it does make a difference. Yes, branded vs unbranded makes a difference. I work in the fuels additive industry and will try to briefly explain.
First you need to understand how to gasoline supply system works in the US. All the gasoline comes from refineries via a network of large pipelines such as the Colonial that you might have seen in the news last fall when it was attacked by ransomware. Those pipelines feed regional terminal stations that pull gasoline, diesel, jet fuel, and heating oil off the pipeline as needed to fill large above ground storage tanks at their terminal. These fuels are then delivered by truck within the region. In short, all the gas in your specific region in the same fuel from the same pipeline. Link for those wanting to learn more about the pipelines: https://www.api.org/oil-and-natural-...-the-pipelines Here's where you get differences in the fuel. At each terminal there are a variety of fuel additive storage tanks as well. When a truck gets filled to make a delivery to a service station, the fuel is transferred from a large storage tank and into the truck. During this process, additive is injected into the gasoline at the proper treat rate for whatever is being ordered. The additive is what makes the difference in your fuel! Unbranded gas stations (Sheetz, Wawa, 7-11, etc.) use whatever the cheapest additive is they can get treated into the gas at the lowest allowed concentration (LAC) allowed by the EPA to pass certain performance tests for deposit control. Branded stations (Shell, Exxon, BP, Costco, etc.) typically have their own additive only used for those branded stations and they are treated at much higher rates, sometimes 5-7x for premium treats like V-Power and Synergy. These branded gasolines are usually also Top Tier certified which is a more strict set of deposit control performance tests that have to be passed to use the TT branding. Diesel is similar but difference. Additization of diesel is rare in the US and the only one you can buy with additive consistently is Exxon. All others do not add detergent or other additives. I know that marketing material can make it seem like branded gasoline is snake oil but I promise you it is not. I personally have spent millions of dollars worth of engine and vehicle testing in the past 18 months to develop a new additive for one of the top companies. There is a significant amount of data and statistical rigor that the data goes through to be able to support any claims made in court if, and when, it gets challenged by a competitor. |
18
cmyx6go15693.50 ///MPhatic13846.50 2000cs3496.50 Boomer 20191755.00 OkieSnuffBox1802.50 BMWGUYinCO4121.50 zx10guy5149.50 Kowalski20111172.00 Tambohamilton3058.00 LivingInSalt1977.50 NYG10627.50 Samurai of 2day2115.00 Sedan_Clan25016.50 rebekahb3131.50 jmack548.50 CamasM3e933147.50 Marmugmotleocay1568.50 BMWGirlFL6269.50 |
07-06-2022, 08:01 AM | #24 |
Rep 941
Posts Drives: 2015 BMW i3 BEV Join Date: Jun 2019
Garage List 2014 Mighty Freight ... [0.00]
2015 BMW i3 BEV [0.00] 2000 Audi TT Quattro [0.00] 1967 Formula Vee [0.00] |
Back when I was in college, I had a job at a Mobil corporate-owned/operated station. Mobil owned the regional fuel terminal, the fuel came from Mobil's refinery on Mobil's barge, and was delivered on Mobil's trucks. There was serious QA/QC at all phases, and the truck drivers even had to check each station's tanks for water/sediment before making a delivery and log the results.
Across the street, there was a no-name station that bought their fuel from whatever regional terminal was cheapest that day. (Can you say lowest bidder?) It was delivered in non-dedicated independent tanker trucks, that were in some cases also used to haul asphalt and other yuckies and picked up occasional loads of gasoline to rinse them out. One of Mobil's drivers used to work for that trucking company, and told me why he left. It is also worth noting that we used to sell a lot of dry gas to pedestrians when the temperatures plummeted and their cars broke down a block away after filling up across the street. When Mobil had to buy truckloads of gas from a competitor's terminal due to tank farm maintenance and stuff at their own terminal, the drivers were given concentrated containers of Mobil's fuel/detergent chemical package to add as the truck was filled at the competitor's terminals. They took their fuel quality seriously. One of the Mobil drivers told me that he watched Sunoco drivers dumping their chemical package into their branded trucks when they occasionally had to fill up at Mobil's terminal, so they also appeared to have similar standards. These days, there's one regional barge terminal that everyone buys from thanks to supply chain divestiture. I haven't seen a Mobil-branded truck on the roads in a while. I would imagine that the chemical package still gets added at the terminal by the driver when the truck is filled, but who knows about the QA/QC in checking each station's tanks for water/sediment before dropping a delivery...especially at shady independent stations. TL;DR - Ask me why I own an electric car now, and why it's only filled with premium Canadian electrons from water falling over a cliff? Mandatory disclaimer - I am still a shareholder in ExxonMobil, when my corporate Mobil employee stock benefits rolled into the merged company.....
2015 BMW i3 BEV, Giga World (Lodge interior), Tech/Driving Assist Packages, 30K miles
07-06-2022, 08:05 AM | #25 | |
The Seeker
13847
Rep 3,316
I think for most of us here who are running upgraded parts and a tune it's all about consistency. I use Phillips 66 93 octane and a 91 map, so I feel like I'm pretty safe. I do wonder if the gas I'm getting is the same as Shell, Exxon, etc. Is there a list somewhere that shows the differences? I could be buying crap gas and have no idea. |
cmyx6go15693.50 |
07-06-2022, 08:30 AM | #26 | |
Rep 941
When in doubt, look at the station to see if they have ~15 foot long tank stick rulers near the fillers or vents. If you don't see a ruler, run! If you do see a ruler, feel free to examine the bottom foot of it to see if there's water paste on it and what it detected the last time it was used. Unless the paste formulation has changed since the 1980's, green paste/residue is good, pink/red is bad.....
cmyx6go15693.50 ///MPhatic13846.50 |
07-06-2022, 08:38 AM | #27 | |
Rep 457
Edit: Phillips 66 additive is decent stuff and Top Tier registered, you're fine there. I've seen the test data for that additive Octane is driven by the fuel itself and is controlled by the refinery from what I understand. There are octane booster additives but that's usually an aftermarket bottle, not in the pump additives. In my work I'm ordering either regular unleaded (87 octane) or premium unleaded (93 octane) from our local terminal. I have had many 3rd party fuel analysis performed on those unadditized terminal fuels and the measured octane is always dead on the 87 or 93 pump rating. Something else to keep in mind is that the additive package is comprised of several things to boost the performance of the base fuel. Intake valve detergents, GDI injector detergents, antioxidants, corrosion inhibitors, antiwear, demulsifier, and sometimes other things depending on the product. Your top branded products (Shell, Exxon) have much higher concentrations of these things which improves overall performance especially if you're filling a fun car that gets a fresh tank of fuel once every couple months. My advice to anyone that listens is to at minimum fill up with Top Tier branded gas, stick to Shell/Exxon/BP if you want the best. If you buy the cheap stuff on a regular basis, do 1-2 tanks of premium V-Power/Synergy or run a bottle of STP Complete (silver bottle) every oil change. Personally I run Shell as much as possible in all my cars, V-Power in the BMWs and regular in my wife's RAV4. Last edited by hoki06; 07-06-2022 at 08:43 AM.. |
07-06-2022, 08:48 AM | #28 | |
Rep 457
vreihen1615188.50 Tambohamilton3058.00 |
07-06-2022, 08:50 AM | #29 |
Rep 75
Posts Drives: '22 BMW X3 Join Date: Oct 2021
I used to fill up at Valero for 2 reasons- you could get 91 and it tended to be cheaper then other stations. That is until I got bad gas in my Mercedes. $6000 later and a 1.5 year long fight with the gas station to get them to pay for the repairs (they paid for other customers repairs but said mine was "too expensive"). Now I only go to the top tier stations.
07-06-2022, 08:52 AM | #30 |
Rep 1,049
I pretty much primarily use Costco gas. It's 10 minutes from my house and is significantly cheaper than normal gas stations, I get 93 for cheaper than Shell/Sheetz/BP have 87 for. I've heard Costco gas is crap, also heard its good, also heard it's super "fresh" b/'c so many people use it. Who knows...
540iSUP704.00 |
07-06-2022, 08:54 AM | #31 |
Rep 1,004
Back in the day I could really tell the difference in my cars (knock and fuel economy) because of mechanical timing, etc. Now with computer controls the car adjusts as much as possible so I can hardly ever tell if it is enjoying the fuel or working hard to compensate. But the better grades give better engine life and fuel economy in my experience (BMWs and Porsches).
GM recommends premium now for the big SUVs (Tahoe, Suburban, Denali, etc), but they run “fine” on regular, especially if being leased. My boss always runs regular in a Denali and seems to grenade the engines just shy of 100k miles (drives close to 50k per year). I suspect a lot of the turbo-4’s being sold now insist on premium. Anecdotal, but I’m sticking with premium. I prefer Shell but it isn’t available all over the USA so sometimes I use BP or another good brand. |
07-06-2022, 09:01 AM | #32 | |
Rep 1,011
This would have been 98-01 |
vreihen1615188.50 |
07-06-2022, 09:36 AM | #33 | ||
The Seeker
13847
Rep 3,316
Every oil change I need to run 2 tanks of good stuff basically, correct? And this would include my Phillips 66 or not? I don't like additives, so the STP thing is out for me. Sorry for so many questions, I keep my cars a LONG time. |
07-06-2022, 09:57 AM | #35 | |
Rep 65
07-06-2022, 10:02 AM | #36 | |
Rep 457
As for the additive bottles, they're just a concentrated dose of additive. Most of those bottles are solvent but they contain a high dose (generally 2-4x Top Tier treat) of additive. Filling up with V-Power or Synergy every handful of tanks will be similar results. |
Tambohamilton3058.00 ///MPhatic13846.50 |
07-06-2022, 10:26 AM | #37 | |
Rep 273
But good topic, I learned some things. |
cmyx6go15693.50 |
07-06-2022, 10:35 AM | #38 |
Rep 2,039
Posts Drives: 2022 X6///M Comp Join Date: Aug 2015
Is the M Sport a real M?
I thought I was a good person but the way I react when people drive slowly in the left lane would suggest otherwise
07-06-2022, 10:36 AM | #39 |
Rep 3,241
hoki06 What are your thoughts on Sam's Club and BJ's gas?
07-06-2022, 10:46 AM | #40 |
Rep 611
I never used to think much about where I stopped until I got a diesel. Now I pay close attention. I always try to stop at truck stops when traveling because they go through diesel faster and avoid any small town or down town stations that likely don't see much diesel traffic.
I have a Cenex station close to my house which is where I fill up the most. I never have issue with fuel from here or any Cenex I find on the road, which is always surprising because Cenex stations always seem to be dun down compared to everything else. BP diesel burns super dirty. My rear bumper will be black after one tank. This happens after every BP fill regardless the location or state. I don't see performance issues, just dirty. Caseys has been hit and miss. Some tanks have been fine, some have power loss and hesitation issues. Kum-N-Go is a no-go for diesel. Every tank I've filled at a KNG has had sputtering and power loss issues. One stop in Colorado was so bad I was worried I was going to be stranded in the middle of nowhere. I also add EDT every tank, and Extreme Diesel every oil change.
F15 35d M Sport (SOLD ) | F30 328i | 2020 Tacoma TRD Pro
My Diesel Information Thread | My Wheels, Tires, and Fitment Thread | My Teardrop Camper Build | My F15 Suspension Lift Thread |
///MPhatic13846.50 vreihen1615188.50 |
07-06-2022, 10:55 AM | #41 | ||
The Seeker
13847
Rep 3,316
Thank you sir! Last edited by ///MPhatic; 07-06-2022 at 11:00 AM.. |
hoki06228.50 |
07-06-2022, 11:31 AM | #42 |
Rep 725
It's all the same in the sense that it meets the regulatory standards for the specific octane levels advertised. Whatever proprietary "additive" is used by any gasoline manufacturer may, but likely does not, produce a nominal positive impact in terms of performance or reliability. Car manufacturers' recommendations to use a specific brand of gasoline are just clever marketing partnerships. A car manufacturer is not going to risk a potential class action, when most of their customers use "less safe" Costco gasoline rather than the more safe "preferred" brand of gasoline for which the engine is designed. Otherwise, they would've mandated the use of the preferred gasoline. Whenever the Shell contract expires, and for the subsequent contract, if BMW and Chevron can make more money together, Chevron will be the preferred gas. I may be wrong but that's my 0.02 cents. I use whatever is available nearby.
07-06-2022, 11:56 AM | #43 |
Rep 457
Neither are listed on the Top Tier website and I know my company doesn't supply them. Considering the target market for Sam's Club (aka Walmart) and BJ's, I'm guessing both are buying the cheapest unbranded LAC they can find on the given day. I would consider these the same as Wawa, Sheetz, 7-11, and many others.
07-06-2022, 12:50 PM | #44 |
Rep 3,658
I use Shell whenever I can for good reason.
Using crappier fuel once in a while won't do anything bad to the car thanks to your ECU/filter. I know of members on this forum who have had their cars serviced after Costco/Wawa fuel complaining about lack of power with that being the cause, crapped out fuel filters, and some gen 1 R8 guys have compared fouling on valves with different fuels. Some of this can 100% be attributed to the fuel station or the distributor they get their fuel from, not the brand, but Shell has been consistently good fuel from station to station. Chevron is another good one from my experience. |
