10-24-2015, 12:57 PM | #45 | ||
Roofless & Ruthless
1356
Rep 1,480
Drives: 2015 AY 6MT F83
10-24-2015, 06:49 PM | #46 |
Rep 560
maybe the wing was designed in response to c63 black series which also uses the GT wing..
if eel like we are in the era of the GT wing..a few years back..they were too "rice" now its common place for all cars to have them somehow last few years were gloss black rims..now i feel like gold is the new color as for that video...correct me if i am wrong...but isnt that a function of poor downforce on the front with good downforce in the back? the air went underneath the car (front splitter design or maybe a bump) and then basically flipped |
10-24-2015, 11:28 PM | #48 |
In The Rain
8174
Rep 6,259
Drives: '24 GT4RS, '24 Macan GTS
Hm...
A GTS car is build specifically the way it is for a reason. Why do you want to do this? That's like getting a 911 GT3 RS and ask for them not to put on the rear wing, you literally get half of the car the way it is. Yes it is your car and you can do what you want with it, but that doesn't make it any less of a stupid decision.
'24 Porsche Cayman GT4RS Arctic Grey "Alice"
'24 Porsche Macan GTS Dolomite Silver "Gina" |
10-24-2015, 11:56 PM | #49 | ||
Roofless & Ruthless
1356
Rep 1,480
If you look at the second video I posted, the front lifted initially because there was a minor crest/lift in the road. That's the point where the front end just got an inch or two higher than it should and that's all it took. Once all that extra airflow got under the car it was over.
10-25-2015, 10:37 AM | #50 |
Rep 732
Instead of getting the GTS at $150K+ and spending another $10K in removing the tail/fixing the trunk.... why not get a base M4 and mod the crap out of it all for about $100K! saving yourself 50% !!
10-25-2015, 06:43 PM | #51 | |
Rep 1,292
Also modding a base M4 isn't the same thing as having a GTS. The base car depreciates and modding it won't help its value. So while you're looking at it as saving money, If you start to calculate depreciation it makes a lot more sense to pay the hefty price tag and go with the GTS. BTW don't think the GTS will be $150,000+ in the US.
2015 Porsche 991 GT3 Sapphire Blue Metallic
2015 BMW F80 M3 Silverstone Metallic |
10-25-2015, 10:55 PM | #52 | |
Rep 732
The GTS may be 150+ on markup just like the I8... but it'll cool down. At the end of the day it is your car but we are all talking theoretical here. |
10-26-2015, 04:20 AM | #53 |
Rep 143
One option would to be like what I did to my Subaru STi. I ordered another trunk, had it painted and then installed. I just had to buy the steel panel, the dealer just swapped out all the hardware between the trunks.
7:51,4 BTG BMW M4, 8:35 BTG Mini Clubman S, 8:56,6 BTG Swift Stage 2
208 laps on the Nordschleife |
10-26-2015, 06:12 AM | #54 | |
Roofless & Ruthless
1356
Rep 1,480
Would be the way to go, that also lets one keep the trunk/air foil for later if he changes his mind. plus it doesn't "wreck" the car.
10-26-2015, 08:00 AM | #55 | |
Rep 20,741
Drives: 2021 911 turbo
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
10-26-2015, 09:43 AM | #56 | |
Roofless & Ruthless
1356
Rep 1,480
Think of the wing of a plane - it's the same principle. The wings of an airplane are generally towards the rear of the aircraft. They don't just provide lift to the rear - otherwise the plane couldn't fly. Plus the wings have flaps that allow the pilot to adjust the nose up or down. That's what I mean by "rotational force" - an airplane's wing on takeoff doesn't just lift the plane up generally - it also specifically lifts the nose up.
An airfoil is literally an upside down wing - it provides downforce instead of lift but the principle is the same. It is designed to provide downforce to the entire vehicle not just the rear. In theory in terms of downforce it would be better to have the airfoil placed in the middle of the two axels - right on top of the roof. You see that in short wheel base racers like go-karts. That would provide more "perfect" front and back downforce but at the cost of increased drag. Part of what the airfoil is doing is disrupting the low pressure zone immediately behind the vehicle which is a major part of the vehicle's drag.
10-26-2015, 09:54 AM | #57 | |
Rep 7,887
10-26-2015, 10:11 AM | #58 | |
Rep 20,741
The center of lift of the main wings is very close to the Cg of the aircraft. Further, the vast majority of planes have two pairs of wings, most of the time with the second pair located at the rear of the aircraft (horizontal stabilizer). It is the elevators located on the horizontal stabilizer that control pitch, not the flaps. The function of the flaps on the main wing is to increase lift in low speed operation (take-off and landing). A rear wing on a car will generate downforce on the rear of the car only, period. Further, as tidbit, because the wing is located aft of the rear axle, it will actually create lift on the front axle.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 10-26-2015 at 02:28 PM.. |
10-26-2015, 10:32 AM | #59 | ||
Roofless & Ruthless
1356
Rep 1,480
Perhaps you are right about the airfoil not helping the front of the car also - it's just very different from what I've always understood - that the airfoil created a force that helped pitch the nose down as well as creating downforce. If I'm wrong about that - peace. However that was never my main point. My main point has always been - the guy is not flying off the freeway at 90 MPH for want of an airfoil. Last edited by F83; 10-27-2015 at 06:00 AM.. |
10-26-2015, 12:30 PM | #60 | |
Rep 308
2024 X3 M40i
2011 1M Coupe VO (Sold) 2015 MB GLK 250 Blutec Deez (Sold) 2001 S54 M Coupe (Sold) 1998 M3/4 (Sold) |
10-26-2015, 01:45 PM | #61 | |
Rep 1,292
10-26-2015, 06:15 PM | #62 | |
Rep 20,741
Loosing a rear wing will not cause the car to fly in the air, but rather cause an imbalance in handling with the rear of car becoming loose (see video below). I however doubt that the downforce created by the GTS rear wing is significant enough to cause such a dramatic loss of control. I however believe it would make the car more more prone to oversteer in high speed corners. The simple fix for that would be keeping the front splitter in its stowed in position, but all this is that the expense of lost speed in the corners and longer lap times.
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 10-26-2015 at 09:06 PM.. |
10-26-2015, 07:51 PM | #63 | ||
Roofless & Ruthless
1356
Rep 1,480
I think you are misinterpreting my previous point. Let me clarify. As I'm sure you know, most race cars allow very little under vehicle airspace at the front of the vehicle - generally increasing slightly towards the rear culminating in the diffuser. As the amount of airspace under the car is increased slightly towards the back, the air expands as it travels the length of the car creating a low pressure zone below the car - particularly at the front - generating downforce. Even in vehicles that don't have more underbody air space towards the rear the diffuser seeks to accelerate the underbody air helping to create a low pressure zone below the vehicle. I think you are saying the same thing. You do speak to it being desirable to have low pressure above the car - I will assume that's a typo. There are places of high pressure above a car (in front of the windshield, creating downforce) and low pressure (towards the rear of the car, creating drag). My point with the second video is that the car that flipped popped up too much (seemingly due to a rise in the road) and took an excessive amount of air under the front. Once that happens the vehicle is a wing and.. Well flies. Your comments are besides my point which is; none of these factors are MATERIALLY relevant at street speeds. They are at track speeds. My comments are to make the point that concern about the handling and safety of the vehicle are overstated at street speeds. OP can remove the wing safely if he doesn't track the car. Agree that video is a better example of the effect of a wing but... Less exciting isn't it? . What I was really trying to show with that video is that stuff can happen on a race track that just doesn't happen on the streets. This image isn't perfect, most trunks have low pressure zones above them - and almost all cars have low pressure zones behind them. But it is 80% right.
10-26-2015, 08:23 PM | #64 | |
Roofless & Ruthless
1356
Rep 1,480
10-26-2015, 09:01 PM | #65 | ||
Rep 20,741
But I need to reiterate what others have posted, what is the point of getting a GTS if one does not intend to track it. A total waste IMO. Quote:
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black Last edited by CanAutM3; 10-26-2015 at 09:13 PM.. |
10-26-2015, 09:32 PM | #66 | ||
Roofless & Ruthless
1356
Rep 1,480
Anyway I think we are more or less saying the same thing. Up to and including that the OP is a) safe driving the car without a wing at highway speeds but b) why?
