03-30-2021, 10:18 AM | #1123 |
18177
Rep 9,389
Battling one at work. It seems to be connected to the Wi-Fi from the front panel, but when I check the Wi-fi half the time it isn't connected. I try to ping the device from the Meraki portal and it doesn't respond. We are to the point we are going to replace the metal cover with a fiberglass to see if we get better reception. Seems like we can get the system engaged from a phone if we leave the door open about 50% of the time.
03-31-2021, 02:02 PM | #1124 |
Rep 1,913
Posts Drives: Here and There Join Date: Jul 2013
What recommendations do folks have for a lawn tractor?
I've got a little over half an acre that I currently use a 21" Honda push for. I enjoy working out in the yard, but with a newborn, it takes a bit too much time to cut, and I have started to consider a riding mower. I'll get a small trailer to bring around mulch, plants, and clean the yard up. May grab a pull behind aerator as well. So I see added benefit other than time and getting a cupholder. I also figure that our next place will have a bit more space - maybe a few acres. I was taking a look at a Husqvarna 18.5HP 42" (single cylinder w/hydrostatic) https://www.lowes.com/pd/Husqvarna-Y...ely/1000368427 What else should I consider? Not interested in zero turn as I need more than cutting grass. |
03-31-2021, 05:14 PM | #1125 | |
Rep 688
03-31-2021, 05:17 PM | #1126 | |
Rep 688
Get a rear engine rider. Only type of mower I can stand after using zero turns for about 10k hours over the years. Perfect for small lawns, easy to maintain and can fit in small spaces. They usually only have a 30 inch deck so they make smooth cuts. |
03-31-2021, 08:02 PM | #1127 | |
Rep 1,913
A couple that I’ve been looking at would probably be slight overkill for my current yard, but could be considered a good one-time purchase when we get a little more space. Can’t believe I’m saying it, but I’m even considering a 22hp 42” |
04-01-2021, 05:41 AM | #1128 | |
Rep 14,521
04-01-2021, 07:07 AM | #1129 |
Rep 1,913
Nice! Looks like a 24hp model? Tough to tell on my phone.
04-01-2021, 06:54 PM | #1130 |
Rep 14,521
This is the one I got
https://www.lowes.com/pd/Husqvarna-Y...ely/1000368435
spazzyfry1234378.50 |
04-01-2021, 08:30 PM | #1131 |
Rep 12,738
Laid down some bio char today. Let's see how it does. Cheers.
Instagram; @roastbeefmike
lsturbointeg9169.50 |
04-02-2021, 12:17 PM | #1132 |
Rep 4,824
I should have taken “before” pics, but here are the “after” pics following live oak trims. They should be good for another 2-3 years.
Current: 2018 SO/SS F83 ZCP
Gone: 2015 SO/SO F82 |
lsturbointeg9169.50 nyalpine907444.00 |
04-03-2021, 03:39 AM | #1133 |
Rep 14,521
i'll probably put bio char as my 2nd app this year
roastbeef11594.00 |
04-03-2021, 12:38 PM | #1134 |
"Salud"
14045
Rep 4,692
Posts Drives: F01 & F15 / Mineral White Join Date: May 2013
Some of our current Flowers...
lsturbointeg9169.50 RickFLM411002.50 |
04-04-2021, 04:35 AM | #1135 |
Rep 12,738
This is kind of a fun one... I was at my parent's house this weekend and saw the "old man cactus" on the side of the house. This used to be about 5" and sit on my window sill when I lived there. It's probably about 24 years old.
04-04-2021, 10:15 AM | #1136 | |
Rep 1,556
I've been wanting to rake through the grass in the back to break up any dead clumps and fluff matted sections to get more air and light down. The lawn sweeper didn't pan out so I ran the tine dethatcher in a crossing pattern in the back and side yards yesterday. I used the middle setting w/o any weight on it since I wasnt trying to actually dethatch. Manual raking would be better but damn my yard is big... I think the tines did a decent job. I used the lawn sweeper for clean-up. Need to order my prodiamine and get my irrigation back up and running. I still need to deal w/ all the clumping fescue but that will probably be a season (or year) long activity.
- Jeff
bosstones' flickr |
04-04-2021, 01:05 PM | #1137 | |
Rep 688
This is a good brand that manufactures biochar products. You can get the Carbon Pro G for lawn applications (SiteOne sells it) or use the actual Mirimichi for gardens. https://mirimichigreen.com/ |
04-04-2021, 08:43 PM | #1138 |
Rep 12,738
https://www.amazon.com/Andersons-Bio...7586942&sr=8-6
they say they don't ship to california, but low and behold- it was at my door in a few days.
04-04-2021, 10:50 PM | #1139 | |
Cole
322
Rep 498
Based on your images, you definitely have a soil compactuon/nutrient deficient lawn. If you aerate and apply some wetting agent, you will absolutely get turf going in those spots. You unfortunately, do not have a summer turf which will spread like Bermuda, kikuyia, st Augustine, so you will have to overseed it with Rye. Many people on here mention overseeding as it is common scross the country, but based on your landscape it is not necessarily needed. Others overseed because they have perennial summer grass which goes dormant in the winter. They have no choice but to overseed with a perennial or even an annual rye so theh have green grass in the winter. You appewr to be somewhere warm enough in the winter where you can have mildly green truf all year without overseeding. |
roastbeef11594.00 |
04-04-2021, 11:05 PM | #1140 | |
Rep 12,738
another factor, is we have two big german shepherds. they tend to urinate on the outer edges of the yard which contributes to the patchy grass. we did have a squirrel burrough in an area that sunk in, but i leveled it off somewhat. i have been thinking about aeration... not sure if i should do the kind that removes plugs, or just spikes and pierces the ground.
04-07-2021, 08:53 PM | #1142 |
18177
Rep 9,389
Planted around Feb this year. I love that orange and red mix!
04-13-2021, 10:29 AM | #1143 |
Rep 621
Can someone tell me what type of grass I have? I'm terrible with this stuff. I load up pictures online and everything looks the same to me. The reason I ask is that I have patches to fix and every time I buy grass seed it's the wrong kind and doesn't match. I live in mid Michigan.
