F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > 335i Exhaust Installed on 328i (pictures and video attached)
Extreme Powerhouse
      08-12-2014, 08:07 AM   #89
altaaf999
Drives: BMW 428i ///M Sport ///M Perf
by any chance do you have a picture of your fabrication adaptor part... how do I explain to muffler shop what exactly it is that I need... like I explained them the situation but they said to send all details thar are necessary - eg dimensions measurements etc.... please send me the details that you would use for yours and I will see if the same thing applies to me... thank you
      08-12-2014, 08:13 AM   #90
TurboM
TurboM's Avatar
Drives: 2018 F82 M4 ZCP
I don't unfortunately as it is installed on my car and you cannot see it. It is literally just a piece of metal pipe welded to the end of the muffler inlet. Its purpose was to align the new muffler to the rest of the exhaust so it could be clamped together in the correct position. Not rocket science, ANY muffler shop should be able to do this in less than an hour without any planning (assuming they have a small piece of the correct diameter piping to be used for the "adaptor").
      08-22-2014, 06:18 PM   #91
EstorilVic
EstorilVic's Avatar
Drives: 23 cars and counting
sweet
      08-30-2014, 05:26 PM   #92
exclusivo
exclusivo's Avatar
126
Drives: race car
I just got mine done, my shop welded mine which I was fine with for 75 bucks. We noticed that the tips did not line up evenly, the right tip is inwards, and the left tip stuck out a bit. After trying different ways to getting them to line up, I told them to just bolt it up to the stock position, and I'll order some 3.5 tips to weld on so everything can be even.
I am very happy with the sound as I get that V6 sound I used to get out of my e90. The only thing I am wondering about is, I am hearing a blow off valve type sound when revving, but from what Ive read, our cars dont have a blow off valve, so is this sound normal or could there be something wrong with the weld?
      08-31-2014, 03:37 PM   #93
TurboM
TurboM's Avatar
My passenger side (US) tip actually stuck out about an inch more after install. I just adjusted the tip to make them even.
The muffler will have nothing to do with the noise of the diverter (blow off) valve makes. You can definitely here it regardless, its just not very loud.
      08-31-2014, 03:38 PM   #94
TurboM
TurboM's Avatar
Originally Posted by Stefanovich View Post
Hi
Just recently fitted a 335 MPE to my 328i.
Surprised at how little extra sound the exhaust contributes to the overall mix.
Very subtle, just enough for me.
Anyway, purchased a BMW 75mm exhaust clamp, cut and fitted to the standard muffler setup, then fronted up to my local muffler shop where they fitted the 335 MPE by adapting (cut & weld) a 'stretched' piece of 72mm stainless tube to span between the existing clamp and new muffler.
Had to fit the 335 rear diffuser at the shop. 1.5 hrs in all.
Great outcome. And easy to revert to standard in needed.
Cheers
Steve
Sounds pretty much the same as my install. Not very complicated, just need to muffler shop (or welder) to fit it correctly.
      09-01-2014, 09:04 AM   #95
altaaf999
Hi
Cheers
Steve
"surprised at how little extra sound the exhaust contributes to the overall mix" ????
you saying there isn't much of a difference? and it isn't worth it?
also please elaborate the clamp you used is a 328 clamp?
      09-01-2014, 09:47 AM   #96
TurboM
TurboM's Avatar
BMW Part Number - 18307560781
      09-02-2014, 01:27 PM   #97
altaaf999
please advise whether there currently is a clamp on my OEM 428 exhaust from the factory? and if this is usable...
      09-02-2014, 02:51 PM   #98
TurboM
TurboM's Avatar
No, the exhaust is one piece from the factory (after the downpipe)
      09-02-2014, 03:13 PM   #99
altaaf999
thanks.. also please advise regarding electronic valve? is it difficult to disconnect? any other installation hassles to be aware of?
      09-02-2014, 03:14 PM   #100
altaaf999
also are the connections the same for EV on 328 and 335
      09-02-2014, 03:15 PM   #101
exclusivo
exclusivo's Avatar
126
Drives: race car
I thought the purpose of the diverter was to retintriduce that air back into the engine, and there would be no blow off?
On another note, my gas mileage has been terrible because I've been purposely building boost lol...The sound is music to my ears.
      09-03-2014, 07:23 AM   #102
TurboM
TurboM's Avatar
yes
      09-03-2014, 07:25 AM   #103
TurboM
TurboM's Avatar
Correct, however you can still hear the recirculation of the air through the plumbing of the intake (not nearly as loud as an open atmosphere type)
      09-03-2014, 03:25 PM   #104
altaaf999
yes
hey guys please advise on the process to disconnect the Electronic Valve? do you simply just pull out the 3 wires? I had a look at the EV but haven't attempted yet.. please advise urgently
      09-03-2014, 03:46 PM   #105
TurboM
TurboM's Avatar
Just unplug it
      09-10-2014, 03:23 PM   #106
altaaf999
hi guys... finally got the job done on my 428i ! loving it!! will post pics soon.... the only difference now that I don't like between a 435i and the 428i with 435i MPE is that if you really had a 435i the second exhaust opens up momentarily after starting the car and I have seen this on the F30 335i as well.. but on the 428i the second exhaust even after conversion is mostly closed... is there a way to leave the valve continuously open? as it sounds much better with both exhausts open... best regards
      09-10-2014, 05:05 PM   #107
BeachsideF30
Drives: E90--> E92-->F30
Can't you just unplug it? So you installed the n55 MPE instead of the standard rear section. We definitely need some videos
      09-10-2014, 06:19 PM   #108
TurboM
TurboM's Avatar
Just unplug it
      09-15-2014, 09:43 PM   #109
Julesjohn
Convert
Julesjohn's Avatar
Drives: 2013 BMW 328i M sport
I had something slightly different done to my 2013 328i M Sport. I installed the Magnaflow 328i #15161 cat back dual exhaust system originally but later replaced just the muffler of the 335i #15271 system in order to split the exhaust and use the 335i matte black diffuser. I like the deeper tone of the Magnaflow personally. This did require a few minor customizations from the local muffler shop and purchase of larger chrome tips. So far so good.
Vimeo video link showing cold start exhaust sound with a few revs:
d_a_m92.50
N26Ghost497.50
      09-17-2014, 11:27 AM   #110
TurboM
TurboM's Avatar
Originally Posted by Julesjohn View Post
I had something slightly different done to my 2013 328i M Sport. I installed the Magnaflow 335i #15271 cat-back dual exhaust along with the 335i matte black diffuser. I like the deeper tone of the Magnaflow personally. This did require a few minor customizations from the local muffler shop and purchase of larger chrome tips. So far so good.
Looks good man
f30post
