      11-10-2013, 01:48 AM   #89
Acheron83
Acheron83's Avatar
South Africa
53
Drives: F22 M240i
2018 BMW X3 M40i  [0.00]
2016 BMW M240i  [0.00]
Got my hands on a set of Blackline tails
Old on the right, new on the left:
Lights off:
Lights on:
      11-10-2013, 06:41 AM   #90
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
Originally Posted by Acheron83 View Post
Got my hands on a set of Blackline tails...
The Blacklines really makes your car "pop".
      11-18-2013, 03:35 AM   #91
ray-ray89
Drives: Red 2009 135i
Do you still have your old ones? I need a pair one my led is out
      11-18-2013, 06:01 AM   #92
Acheron83
Acheron83's Avatar
South Africa
53
Drives: F22 M240i
I do, but unfortunately I'm little far away from you
      11-18-2013, 07:12 AM   #93
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
You should go to a bmw dealer... while they were not recalled, there was a "service action" and you might be able to have bmw replace them for free. Its worth asking.
Or... just upgrade to the Blacklines.
      11-30-2013, 02:57 PM   #94
m_thompson
m_thompson's Avatar
Drives: M-Sport 128i, 328xi, 3.0CS
2009 128i  [0.00]
1972 3.0CS  [10.00]
I installed Blacklines from Schmiedmann on my '09 Black Sapphire Metallic 128i. Total time was about 30 minutes. Looks very nice.
'09 128i - Black Sapphire Metallic\Coral Red\Glacier Silver\N51 DISA\6MT\Navigation\Premium\M-Sport\Heated seats\Xenon\Headlights\iPod\Smartphone\Euro Delivery
      12-04-2013, 08:38 PM   #95
sonicbimmer19
Drives: E88 and F32
I just installed mine tonight, thanks David for the DIY.
Just a quick questions, how tight should the three screws be or does it even matter? I know for the third light, it matters but I just want to make sure, I wouldn't want to find my taillights cracked.
In addition, can someone further explain how to make the fitting of the taillights near perfect? Do you just kind of have to hold it as you screw the bolts on?
      12-04-2013, 08:41 PM   #96
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
In addition, I noticed the fitting of the lights are not perfect, that's normal, right? What I'm talking about is gaps between the car body and the light.
Thanks guys, these lights absolutely rock.
Not too tight, bc you can damage the lights. Just snug enough to compress the rubber gasket and make sure to water test those seals.
We are probably talking like ~8 ft/lbs tightness.
      12-04-2013, 08:42 PM   #97
sonicbimmer19
Drives: E88 and F32
Thank you David.
I think I'll try to readjust the fitting; have my friend hold the lights for me while I screw it in or something.
weeeeeeeeeeeeee
      12-05-2013, 07:20 AM   #98
m_thompson
m_thompson's Avatar
2009 128i  [0.00]
1972 3.0CS  [10.00]
I used some pieces of a cereal box between the lights and the bumper to hold the lights in position until the nuts were tightened. Worked nicely.
      12-05-2013, 11:49 AM   #99
Acheron83
Acheron83's Avatar
South Africa
53
Drives: F22 M240i
+1. Exactly what I did
      12-06-2013, 03:07 PM   #100
sonicbimmer19
Drives: E88 and F32
Thank you for the tip, I really appreciate it. I shall try that method right now..
edit: the fitting is not perfect, but much better than before. Brilliant idea, I didn't think pieces of cargo box would hold it up haha.
On a side note, I noticed the far side wires on each side of the lights face opposite of each other. For example, the wire on the left taillight faces down and the wire on the right taillight faces up. If someone is bored, you can check this and let me know if that's normal. I'm pretty sure it doesn't matter but just found it odd
      12-09-2013, 10:03 PM   #101
m_thompson
m_thompson's Avatar
2009 128i  [0.00]
1972 3.0CS  [10.00]
On mine the left one was the same as the original, the right one was upside down from the original.
      12-11-2013, 12:50 PM   #102
sonicbimmer19
Drives: E88 and F32
Cool, thanks for letting me/us know! seems like that's normal.
      02-10-2014, 05:42 PM   #103
Venom
Venom's Avatar
Drives: M2 Competition
2008 BMW 135i  [8.50]
Thanks for the DIY! Just finished this install myself! Woo-hoo!
      02-27-2014, 10:54 PM   #104
sparkyblue
sparkyblue's Avatar
Drives: E82 135i & F80 M3
2008 BMW 135i  [0.00]
I agree!
Thanks for the DIY. Just did this install myself. Probably the easiest mod yet haha.
      03-02-2014, 01:57 AM   #105
johngrossi
johngrossi's Avatar
9
Drives: 2011 135i e82
I can't wait for my blacklines!
PE exhaust, tints...more to come
      05-10-2014, 12:56 PM   #106
new2the3
new2the3's Avatar
Drives: 2020 X3M Competition
Which seals are you referring to check for water proofness?
2020 X3MC
2009 135i: AW/CR Aluminum Trim, 6 speed, M-Sport, Premium, Heated Seats, Ipod, BMW Performance Pedals, BMW Performance SSK, BMW Performance Exhaust, BMW Performance Grills E93 M3 FSB
      05-10-2014, 04:58 PM   #107
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
The black foam seal that seals the tail lights to the car body. If the tail light is not tight enough... water can leak into the car. Also make sure the rubber flap/seal of the tail light is routed correctly to "deflect" water around the trunk seal.
      05-10-2014, 05:04 PM   #108
new2the3
new2the3's Avatar
Thank you Dack,
Do you have an up close picture of this area - the rubber flap/seal of the tail light is routed correctly to "deflect" water around the trunk seal.
I just got my blacklines installed today and I think they are good to go but I just want to make sure the water will be deflected before I go for a car wash!
2020 X3MC
      05-10-2014, 05:10 PM   #109
Dackelone
European Editor
Dackelone's Avatar
Germany
10633
Drives: N54 e82
Thank you Dack,
Page 1 of this thread...
      05-10-2014, 08:07 PM   #110
new2the3
new2the3's Avatar
From the very top of the tail light rubber/plastic mine doesn't sit very "molded to the surface." They are positioned right but it can be pulled up / not perfectly flat. I guess that is normal.
2020 X3MC
1addicts
