New Vanos Recall (23V-707)
01-09-2024, 07:26 PM | #89 |
Rep 483
Drives: Break My Wallet
So you got back the car on the same day? Did they offer a loaner vehicle?
01-12-2024, 10:07 PM | #90 |
Rep 4
Drives: BMW 328i xDrive 2011
01-13-2024, 07:21 PM | #91 |
Rep 48
How could you tell the job was done properly apart from the car running well? Did they replace just the bolts or the entire vanos unit? The open recall does not apply to my car but I know the bolts have sheared.
01-25-2024, 01:20 AM | #92 |
Rep 2
I just had this “done” at my dealer, it took 4 days along with a state inspection. When I got home I pulled the engine cover which looked suspiciously untouched.. dirty
They hadn’t touched a thing. 2 years ago I had the whole valve cover replaced for the stupid pcv valve + tiny oil leaks, at the same dealer.. I have the video of pulling it off and looking around and how it was obviously completely untouched. I’m guess complain to BMW USA? |
StradaRedlands5029.00 zhent70.50 lordnikon393.50 M-technik-32133.00 charlesantoine16.50 johnnyorange58.50 |
01-25-2024, 05:57 AM | #93 | |
Rep 22
M-technik-32133.00 |
01-25-2024, 08:25 AM | #94 | |
Rep 483
01-25-2024, 09:40 AM | #95 |
Rep 2
AHA the recall process is only to inspect it.
And replace if it's completely broken. It was filthy because they'd only put a camera through my oil cap to inspect. The recall process is not remedied - they are only fixing BROKEN cars and taking data. They forwarded me to the mechanic in the shop - he said to expect a recall WITH a fix to be dropping in the next few months. Then they will go through the whole deal and if the bolts are shredded, reseal the oil pan. As of now unless it's fully broken, they'll just take inventory of how many bolts you have remaining and report |
01-25-2024, 12:18 PM | #96 |
Rep 483
That's ridiculous. The whole point of the recall is to REPLACE the bolts regardless of whether they're broken because the wrong bolts were used in the first place.
It makes sense that they don't have to drop the oil pan if no bolts were broken but just to check if they're broken or not and not fixing it is a pointless exercise. |
zhent70.50 |
01-25-2024, 01:02 PM | #97 | |
Rep 1,186
01-25-2024, 01:06 PM | #98 | |
Rep 4,108
"If any of the bolts were loose or broken during this procedure, the VANOS assembly will need to be replaced. Refer to step 14."Then refer to pdf page 8 of 23V-707 where it states: "Description of Remedy Program : The four VANOS bolts will be replaced."In the 2014 RCRIT, clearly the entire VANOS Unit (NOT just the bolts) was to be replaced if ANY of the 4 bolts securing it was Broken or Loose, as illustrated in the Photos. There is NO mention of VANOS Unit Replacement or inspection for Loose/ Broken bolts in the NHTSA 2023 document. Stay Tuned. George |
01-25-2024, 04:33 PM | #100 |
Rep 1,508
01-30-2024, 01:08 PM | #101 |
Rep 3
VANOS Recall
Hi
My N52 is at the dealer for the Recall Only 162 K Kms ( 100 K miles ) Good news They found badly bent bolts, none broken Bad news additional parts required due to damage backordered for a few weeks Good news It got in before it failed, they did not recommend reassembling and driving before the replacement - failure was imminent |
KKevin89.00 |
01-30-2024, 02:06 PM | #102 | |
Rep 483
01-30-2024, 02:23 PM | #103 | |
Rep 4,108
BMW LISTED price on those VANOS Units ~ $600 each. It's NOT just a matter of 4 new bolts per Cam with loose/ broken/ bent bolts. The REAL question is: "What exactly is to be replaced when bolts are Broken, Loose or Bent", and what are the terms of the RCRIT or agreement with NHTSA on a "Practical Fix"? If you get ANY Invoice or Itemization of NEW PART$ from the Dealer, please provide a Scan of that Invoice. This is NOT a "New Issue". There was a recall in 2014 (see RCRIT attachment ABOVE). Human Tendency to "Kick Can". George |
01-30-2024, 02:49 PM | #104 | |
Rep 194
My 2010 is about the the same KMs, better bring mines in soon. |
01-30-2024, 09:42 PM | #105 |
Rep 3
BMW GRAND RIVER IN KITCHENER HAS THE CAR
I will post the results when they are done with it - Parts are backordered in Germany - description was not clear other than they were no charge The Eccentric shaft position sensor had oil and corrosion, they are charging for the part (800 cdn) BUT only 1/2 hour labour since they are in and going back ito do later when it does go - ugh |
01-30-2024, 09:58 PM | #106 | |
Rep 401
Drives: 2011 e91 328i RWD
Ask to see the “bent bolts”. Or a photo of same. They are likely wiggling out of pulling your pan to remove the faulty sheared and broken bolts remnants. The more I learn about this recall, the less I like it. I was one of those who pushed NTSA for the recall and I replaced my faulty bolts myself a few years back. I’m pretty sure that the last thing I want is some clowns tearing back in there to kite up a dealer service bill! And BTW, a genuine BMW ESS is about $400 US for the part. Last edited by Mike K; 01-30-2024 at 10:04 PM.. |
StradaRedlands5029.00 |
01-31-2024, 07:09 AM | #107 |
Rep 483
800 CAD for the sensor? Jeez it's about $280 USD for one; converted to CAD will be about $376. Let's call it $400 even. They're basically charging double the price.
https://www.fcpeuro.com/products/bmw...ic-11377524879 |
StradaRedlands5029.00 Mike K332.00 |
01-31-2024, 07:17 AM | #108 | |
Rep 194
01-31-2024, 09:42 AM | #109 | |
Rep 4,108
https://www.autohausaz.com/catalog?v...age=1&sortby=r https://www.getbmwparts.com/oem-part...bC1sNi1nYXM%3D If you REALLY want to "Go Low" (I've NEVER had an issue with Amazon parts ;-): https://www.amazon.com/s?k=BMW+11377...f=nb_sb_noss_1 George Last edited by gbalthrop; 01-31-2024 at 09:48 AM.. |
Mike K332.00 |
01-31-2024, 10:09 AM | #110 |
Rep 1,186
And Canadian prices are EXPENSIVE. I’ll bring parts across the border when I visit my aunt in Canada. Saved her quite a few $$$ on her F25.
Mike K332.00 StradaRedlands5029.00 |
