ZPOST
Go Back   ZPOST > BMW Z4 Technical Talk > Navigation, Audio, Bluetooth, Stereo, Electronics Talk
  TireRack
      03-12-2020, 10:38 AM   #89
rsutoratosu
Drives: Z4 3.0i
nice.. looks good, looks like thats the newer menu version also..
-Roranji
      03-12-2020, 10:53 AM   #90
Black911S
Drives: 2007 BMW Z4M Coupe - Imola Red
Which nav unit did you buy exactly? How did it mount to the dash and does it completely cover the dash opening?
More pics would be great when you have a chance.
thanks
Originally Posted by CJW2OO4 View Post
Well scooped up and Android Unit with car play and installed it. Just need to install the backup camera now perhaps a front camera for recording purposes. At this time I have not hooked up the mic, gps, or what i suspect to be a wifi antenna. Although I did run the GPS antenna to the right cup holder in case I want to install it down the road. My car had factory professional Nav, so i scooped up a business radio so i can see the stations. The factory audio/cd at least to me sound better than the professional nav ever did.
Lastly although the screen is big I do not believe it really obstructs my visibility. There may be a custom baseplate cover in the works for the Z4 to make this screen sit lower.. (might be able to sit an inch / inch and a half lower)
      03-12-2020, 06:42 PM   #91
CJW2OO4
CJW2OO4's Avatar
Drives: E86M,M2,F13 E86&E85M,E86,2E46
I do not have the same interface as the newer BMWs.. The screen you are seeing is the Apple Car Play Screen. Which is all i really wanted. The base-plate is a tad small so it doesn't perfectly cover the existing nav screen cutout.
I am in touch with a another guy that installed this screen and is working with a vendor to come up with a properly sized base plate that does not require trimming. Although this exact nav solution is not perfect once the custom base-plate is made its gonna be A+ in my eyes.
I will try to snag more photos this weekend
      03-12-2020, 07:03 PM   #92
XMetal
XMetal's Avatar
Drives: Anything
2008 Z4M Coupe  [10.00]
2018 Audi S3  [0.00]
2004 X5  [8.50]
Thanks for the update. Keep us posted on the custom base plate. I may try this route when my screen goes kaput.
Out of curiosity, why can't you reuse the OE's GPS antenna since you have the OE NAV?
      03-12-2020, 07:26 PM   #93
CJW2OO4
CJW2OO4's Avatar
To be honest I didn't look into it. Also didn't want to take apart the headliner / visor and I' not exactly sure of the wiring...When i swapped out my nav head-unit unit all i had was the regular radio connector and standard antenna plug.. I did not see a GPS antenna wire / connection anywhere.
Zposters feel free to educate me with some tips and tricks.
      03-12-2020, 10:31 PM   #94
XMetal
XMetal's Avatar
Drives: Anything
2018 Audi S3  [0.00]
2004 X5  [8.50]
Just remembered...the GPS antenna is connected to the NAV DVD drive in the center rear console
      03-13-2020, 03:26 PM   #95
Black911S
How exactly is this screen being held to the dash? Does is screw right into the existing mounts?
      03-15-2020, 08:03 AM   #96
ZMCoupe
Drives: 2007 M Coupe
This was posted in a Z4 FB group. Not affiliated but they claim it fits and works with E85/E86’s. I’m curious but not willing to cut a hole in my dash.
https://bimmersupplies.nl/product/na...85-e86-en-e89/
      03-15-2020, 06:02 PM   #97
Black911S
That unit looks promising but rather pricey
      03-15-2020, 08:56 PM   #98
WestCDA
Drives: 2006 Z4R 3.0si
I like that it lists Android Wireless as an option, which would add a lot of value for me, but there is an asterisk beside it with no notes I can find - so it's not clear under what conditions that would actually work.
The installed picture looks almost like it's intended to fold into the dash, but no indications in the description or pictures that it does. If it doesn't fold, it's a pretty clunky looking structure behind the screen, and the pictures of the standalone unit and the installed unit don't match.
What little description there is, is confusing at best, and there is also no installation manual to peruse - just not enough info there for me to take a risk.
      03-17-2020, 03:14 PM   #99
rsutoratosu
Drives: Z4 3.0i
They often use photos from e89 in the sale, it does not fold
-Roranji
      03-22-2020, 04:29 PM   #100
Dav3
Dav3's Avatar
950
Drives: G87 M2/E89 35is/F21 M140i/GT4
Wishful thinking, but any chance the E82 satnav/tray trim fits the Z4 E85?
      04-05-2020, 11:17 PM   #101
Black911S
CJW2OO4, rsutoratosu,
Any updates on your nav screen installs?
Thanks
      04-14-2020, 06:57 AM   #102
CJW2OO4
CJW2OO4's Avatar
Hi no update from me.... I am still working out some kinks... Need to download the andoid 10.0 update. Also need to mess around with the settings as the clock always resets and the volume does as well. Nothing major because as soon as I pair my iphone i go into car play mode and the time is accurate.
      04-14-2020, 11:56 AM   #103
tominizer
tominizer's Avatar
Drives: 2007 Z4M Roadster
......watching this thread closely. That Alpine looks interesting as well. My issue is I have the factory NAV and I DO NOT want to cut the dash in case the car has to go back to stock (because the value went thru the ceiling to a 6 figure collectors item!!)
      04-14-2020, 01:33 PM   #104
CJW2OO4
CJW2OO4's Avatar
Skyer would be willing to do a baseplate if we get enough interest (got a thread going please chime in with interest). I had to do no cutting as the dash cutout for the OEM was big enough. This would essentially be fully reversible back to OEM in under and hour or so.
      04-14-2020, 03:55 PM   #105
Black911S
I certainly would be very interested in a base plate from Skyer.
Would this baseplate just be a filler plate?
      04-14-2020, 06:40 PM   #106
CJW2OO4
CJW2OO4's Avatar
Sorry not sure what you mean by filler plate? The base plate that comes with the nav are a smidge too small.
      04-21-2020, 02:16 PM   #107
yyz_bobby
Drives: BMW Z4 (2007)
Fairly pricey unit but it straight up says it will work for E85/E86.
https://www.aliexpress.com/item/3305...chweb201603_52
I have the BMW nav screen so no cutting required.
Did you ever get this?
I got the OEM Nav screen, everything people are posting here is about cutting a new hole but i want to just replace the crappy existing nav and base.
      04-21-2020, 02:25 PM   #108
yyz_bobby
Originally Posted by rsutoratosu View Post
Today is their black friday 11/11... ordered..
Final price 494.10 + 29.85 tax - 24 bf coupon = 499.95
PX6 - 4gb 64gb rom. 6 core.. not the newest 8 core one.
What did you get done in the end?
Did you have the E85 with OEM Nav screen already?
      04-21-2020, 02:34 PM   #109
yyz_bobby
Hi , i tried to read back on the thread to see who had which OEM fit.
Did your z4 have the factory nav screen? If so was anymore cutting required? Did the new base fully cover the old one?
Do you have a direct link to the one you bought?
How are the features? I am curious how easy it is to use, does it show car performance similar to the old nav screen?
      04-21-2020, 05:08 PM   #110
CJW2OO4
CJW2OO4's Avatar
I had the existing hole in my dashboard but the nav I bought the baseplate doesn't cover it properly and the mounting points don't line up.
zpost
