08-31-2024, 11:41 PM | #9109 | |
Rep 2,228
But you're right - the reality is the safest solution is to just burn some overall inert hydrocarbons in a generator to charge that battery while you go. Even better if you can use a biofuel, like an algae derived biodiesel. There's been some amazing work on that where the algae could in theory use more CO2 to create their biofuel than burning it would release. That's got the added benefit of actively removing all that pesky CO2 we are worried about. What would truly be a wonderful product would be something like Ramcharger with a diesel generator to charge the battery. Because of how well diesels handle high load vs gasoline, they're a perfect fit for a high load application like this, so you'd use significantly less fuel to charge the vehicle. |
09-01-2024, 07:06 AM | #9111 | |
Rep 11,107
09-01-2024, 07:15 AM | #9112 | |
Rep 11,107
https://www.caranddriver.com/features/a41103863/hydrogen-cars-fcev/ |
09-01-2024, 08:48 AM | #9113 |
Rep 19,463
I can think of cost as a reason.
09-01-2024, 10:22 AM | #9114 | |
Rep 2,228
The EPA has essentially regulated most small diesels off the market. Regulatory issues aside (and the fact that it went out of production for like 2023), the eco diesel was an expensive engine, and the pentastar is not. Pentastar gets used in everything and is mass.prodiced to the extreme. Ramcharger will probably start at like 65k for a basic ass truck. It would have likely gone up to like 70k with eco diesel. Which would have killed it before it started for a base truck. |
09-01-2024, 08:19 PM | #9116 |
Rep 6,526
Posts Drives: 2018 340i M Sport Join Date: Apr 2006
Garage List 2018 BMW 340i M Sport [8.78]
2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [7.38] 2006 BMW 330i Sport [5.83] 2004 BMW 330i ZHP [7.13] 2000 BMW 328i [6.17] |
I would completely disagree with that. I’ve actually been a fairly big fan of the 330e. I haven’t driven a G20 330e, but I’ve driven an F30 330e quite a few times. As I think about it I may have driven a G20 330e once at a BMW driving event. Anyway, I always enjoyed driving the F30 330e and was always pretty impressed with its performance. I’ve always driven one with juice in the battery. I live in a condo with garage parking where I could not easily charge a plug-in hybrid. My parking space is close to a storage room and I even considered whether I could run an extension cord from there to my car, but I knew I would run into a Karen or two who would unplug it. I even posted a thread on F30Post asking opinions and, of course, the overwhelming response was “no, don’t do it” and quite a bit of discussion about hauling around dead weight if I drove it uncharged and losing mpgs if I drove it in self-charge mode with the motor charging the battery. So, I would say there absolutely is a reason not to have a plug-in hybrid if you don’t have an easy way to charge it.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
09-01-2024, 08:40 PM | #9117 | |
Rep 2,228
Whoever told you that was... To be blunt, an idiot. Yes, there's a weight penalty, but there's also a "free thrust" from the electric motor to compensate. If you can't charge it, then it's just a hybrid vehicle, regenerating power when you decelerate. Now of you can't charge it, you'll likely never see an ROI based on fuel savings, and that's what really matters (I wouldn't buy a PHEV in your case either) but you're not going to use more fuel in a PHEV that isn't charged. That said, I think you missed the context of my comment. My comment was "it makes no sense to have a fairly large hybrid battery that is not a plug in". For example, if the 330e had an optional charge port, everyone would buy that option because not having it would be stupid, and it would have no downside except being a $250 or whatever option. Caveat, a lot of peop.wpuld buy it without the charge port because they would assume the charge port came standard. |
09-01-2024, 10:09 PM | #9118 | |
Rep 1,985
And this is why they make different cars for different people. |
09-01-2024, 11:53 PM | #9119 | ||
Rep 6,526
Just how much regenerative power do imagine is produced when braking? I’m not sure what “optional charge port” you’re referring to. Is this what you are talking about?
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ Last edited by tturedraider; 09-02-2024 at 03:16 AM.. |
09-02-2024, 06:06 AM | #9121 |
Rep 11,107
Not all hybrids plug in; those without have less range. Not sure it’s all regenerative braking though that certainly helps — a more powerful alternator can help charge a smaller drive battery. https://www.caranddriver.com/news/a46414049/toyota-prius-vs-prius-prime-test-results/#
09-02-2024, 08:24 AM | #9122 | |
Rep 2,228
My point was that if there was a car that had the same battery pack and electric motor, and it was either a regular hybrid, or as an option you could add a charging port, nobody would not buy that option, except for a handful of dummies who thought it was standard. |
eugenebmw2000.00 tturedraider5517.50 |
09-02-2024, 08:27 AM | #9123 |
Rep 19,463
I don't consider a 15 to 20 kWh battery as small. I think there is more than $100 of added (manufacturing) cost to have a DCFC-capable built-in charging system along with the complexity of an on-board generator system.
09-02-2024, 08:32 AM | #9124 | |
Rep 19,463
09-02-2024, 10:39 AM | #9126 |
Rep 643
Welcome to Canada
Tesla’s official map of its charging network shows that its Superchargers are noticeably absent in Canada’s northern provinces. “We are in the Yukon, which is pretty cool because all the chargers are free,” he said in a recent video. “It’s free because it’s one charge post. I waited an hour to be able to plug in here and I will have to change for like two and a half hours to make it to the next charger.” Before even getting to the Yukon, Bearded Tesla was battling with a charger that was shutting off every five minutes. Three Tesla Cybertruck Owners Are Driving From Florida To The Arctic Circle And Already They Are Having Problems https://jalopnik.com/three-tesla-cyb...ida-1851637005 |
M5Rick66807.00 |
09-02-2024, 10:56 AM | #9127 | |
Rep 2,228
09-02-2024, 02:27 PM | #9129 | |
Rep 1,985
Is it the worst thing in the world? No. These are all first world problems as they say, but if I want to take the miata out in the morning to go for breakfast up the mountain and I get in and see it doesn’t have enough gas. Now I have to stop what I was going to do to go to Walmart or what not to put gas before I can do what I wanted. Maybe it takes 10-15min extra to get there put gas etc… not a big deal, but when I’m in FL for the winter where I basically only drive the Tesla and I come back to NC where I have 3 ICE vehicles I notice how much I actually dislike it. Again it was something that surprised me when I got my Tesla how much I disliked having to put gas. Would have never guessed at that being a benefit until I experienced it. Last edited by dreamingat30fps; 09-02-2024 at 02:34 PM.. |
09-02-2024, 03:00 PM | #9130 | |
Rep 6,526
