08-29-2010, 11:28 PM | #67 | |
Rep 1,680
08-31-2010, 09:19 AM | #68 | |
Rep 1,339
11-27-2010, 09:02 AM | #69 |
Rep 724
I already covered these two items in my rewrite of the procedure (please see the pdf). I did recommend a pliers instead of hands though, just because it's less messy and provides better grip.
There are a couple of things I'd change in another rewrite however; 1) I'd suggest jacking up all four corners, rather than one side at a time. This saves a lot of time and let's you bleed all four corners one after the other (starting farthest from master cylinder and ending closest to it); and 2) I'd recommend using a power bleeder to better do the job solo. I've gotten the whole procedure down to an hour even now
Mmmm... M&Ms,
Dale |
12-30-2010, 01:27 PM | #70 |
Î canŧ főcus mŷ attėntĭon
73
Rep 1,407
Does everyone replace their rotors when they change the brake pads? I've been told by some BMW techs that you should buy new rotors everytime you change the pads, then other techs that you only change them if you need to. My M3 has 51k on it now and it needs brakes, so I'm debating if I need to change the rotors out or not.
2011 M3 Coupe - Individual Fire Orange/Black Novillo Extended Leather, 6MT, Mode Carbon, Eisenmann Race, BBS CH-R, BC Coil-overs (Sold)
1995 M3 Coupe - Avus/Hurricane, AEM EMS, Precision Turbo, Boostlogic, H&R, Fikse FM/5, MaxVelocity, Maximum PSI, 20% Tint, etc etc..(Sold) 2009 M3 Coupe - AW/Fox Red, 6MT, Carbon Roof, Shadow Trim, etc (Sold) |
12-30-2010, 01:29 PM | #71 | |
Rep 1,108
01-31-2011, 09:10 PM | #72 | |
Rep 2,536
No, you do not need to replace rotors every single time you buy pads. Usually, you can resurface rotors, but drilled rotors, no. If your at 51k on stock rotors however, they may need to be changed. But what they said is complete bs. |
04-03-2011, 06:41 PM | #75 | |
Rep 1,672
06-15-2011, 08:53 PM | #76 |
72
Rep 383
When you say "Remove the pad wear sensor. It is clipped onto one of the brake pads. Just pull on it and it will come out. The chances are the tensioner clip will remain in the pad. Make sure to get it. They are not sold separately, and if you lose it, you'll need to buy a new sensor."
Are the pad wear sensors reusable? Are the tensioner clips removable and essential? When you swap to track pads, do you guys attach a sensor? if not, what happens? do you just receive a brake light? aka are pad wear sensors necessary? Thanks |
06-15-2011, 09:20 PM | #77 | |
Gearing
86
Rep 3,962
Are the tensioner clips removable and essential - Yes and yes, unless you want or care about warnings/errors on the console. Re: Track pad swap, do we attach? - I no longer do. See below. If not attached - you get an computer error. Car works as normal. I re-used my sensors until I lost the little metal tensioner clip or the cable system failed in some fashion (they are cheap $18-$22). I eventually got so sick and tired of having to frig around with the cable system that I have since disconnected them front and back and simply cut off the sensor to expose both wires, twist them together (system shorted out to believe all is well) tape them off and tie wrap them up. Only makes sense to do this if you track often and are very aware of your pad usage. Otherwise I dont recommend anyone doing this.
If at first you don't succeed ...
08-07-2011, 02:28 AM | #79 | |
Rep 5,012
09-25-2011, 06:23 AM | #81 |
Rep 47
Drives: 2015 BMW M4
Thanks for sharing, and thanks for taking the time and efforts in providing us pics...
03-07-2012, 02:29 PM | #82 |
11818
Rep 23,187
useful DIY and very easy. switched to my ds2500 pads this morning, removed my dust shields for extra cooling with my gt4 ducts and put on my track wheels so set for the season!
02 Tiag e46 M3|6MT|GC plates|MCS c.o.|GC bars|GC race control arms|GC bushings|BW eng. & tran. mounts|subframe kit|BW race shifter|BW Jaffster|Euro header|BW exhaust|K&N c.a.i.|Epic race tune|Rouge pulleys|Seibon CF hood|CSL bumper|apr gt 250 & splitter|ST-40|XR-2|SS lines|half cage|Recaro profi|Profi 2 harness|BMWpedals|BW studs| |
03-30-2012, 10:45 PM | #83 |
Rep 8,077
Drives: 11 E90 M3 Individual
Compared to my Stoptechs...What a PIA! And thanks for the DIY!
2018 F30 320iX Melbourne Red
04-07-2012, 05:21 PM | #84 |
Rep 600
Drives: 2012 E92 SSII ZCP DCT
How did you get rear anti-rattle spring out? I tried so hard and is not working..so I only changed front pads.
AA Green Filter/AA Pulley/AA catless X-pipes/AA signature exhaust/AA TUNE/TMS studs/Project Kics R40/R888/VOLK ZE40/ST60,ST40 BBK/MCS 2WAY NR/Vorsteiner GTS5 Bumper/APR GT250/APR SPLITTER |
04-07-2012, 06:31 PM | #85 |
11818
Rep 23,187
the rear was super easy i think i may have just used my hand. the front was harder for me.
04-07-2012, 09:09 PM | #86 |
Rep 600
Really!How did you do it by your hand. Took me half hour and still can not get it out.
04-07-2012, 09:37 PM | #87 | |
8300
19
Rep 573
The fronts are easy and can be done by hand. |
04-08-2012, 12:13 PM | #88 | |
11818
Rep 23,187
