Mo Reviews
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Suspension | Brakes | Chassis
      09-03-2014, 10:15 AM   #67
Mandi90TT
Drives: BSM 6MT M4 F82
Just a note: this will throw off your TPMS sensors. They will report the wrong wheel. Not a huge issue, just a comment.
      09-03-2014, 11:07 AM   #68
Wei718
Wei718's Avatar
340
Drives: 718 GT4
Good thing with BMW is you can reset the tpms sensors and it'll register the correct values
      09-03-2014, 11:09 AM   #69
Mandi90TT
Well then, good!
      09-03-2014, 03:03 PM   #70
dhoggm3
dhoggm3's Avatar
Drives: 850i C, Gated R8 5.2, E63
Yes, it told me I had a flat, so I reset them and now everything seems as it should be.
M850i Vert with RaceChip
E46 M3, Euro Headers, Rasp Pipe, Kassel Tune
Alpina B8, zero performance mods
      09-04-2014, 08:37 PM   #71
brian1225
Drives: 2015 F80 M3 MW/BLACK
Originally Posted by dhoggm3
Originally Posted by Milban View Post
I've been running auto repair shops for too many years. When a car pulls left or right, and the alignment specs are good, and the tires pressures match, it's usually a "radial tire pull". The way to troubleshoot it, is to switch the front tires left to right, and see if it has an effect. If the tires have a directional rotation, switch them front to rear (if they're all the same size). The results usually bring a smile.
Ding ding ding ding! FIXED!!
My car would be in a ditch within 5 seconds before this fix. These cars are so high-tech that it never occurred to me (or the dealer) to try a decades-old technique as simple as this one. Thank you, Milban. I test drove the car after the swap and took both hands off the wheel, and BAM! It tracks true. I'm SO HAPPY that this didn't turn into one of those "re-flash the steering software" things that others have reported with e-steering on other makes.
While I was in there, I noticed that the cooling vents on the new M direct the cooling air to swirl through the wheel well. All earlier M's just dumped a blob of air near the dust covers. I'd be interested to find out whether this is to improve cooling, or reduce drag, or reduce debris getting behind those dust shields. BTW the shields are farther from the disks than earlier M's, and irregularly shaped, so much less prone to trapping stones and twigs that make awful screeching noises.
Glad to hear that this worked. I thought the tires were directional... I will have to check when I get home. Does anyone have insight to this for the 19" wheels.
2011 E92 M3 AW/Black Competition Package Fully loaded.
On Order 2015 F80 M3 MW/Black loaded minus ceramic brakes. Production start date: 07-08-14
      11-06-2014, 06:06 PM   #72
Bryan
Drives: F80 M3
2015 BMW M3  [0.00]
2008 335i (sold)  [0.00]
I have this problem also. F80 19" wheels
Anyone have an update? Is your car still pulling or have they found a fix?
The dealer has checked the alignment and swapped the tires but still pulls. They want to replace the front swivel bearing to one that gives the front right wheel -.30 more camber. Part # 31217853640
Current Camber is:
FL -1.20
FR -1.05 with new part -1.35
Any thoughts?
      11-07-2014, 01:59 PM   #73
str8nm
str8nm's Avatar
Drives: 2020 M2C DCT
2020 BMW M2C  [0.00]
2011 335is  [10.00]
Current Camber is:
FL -1.20
Any thoughts?
These cars are designed to pull to the right to avoid head on collisions. My 335is is the same.
"The sleep of reason brings forth monsters."
      11-07-2014, 02:54 PM   #74
Bryan
Drives: F80 M3
2015 BMW M3  [0.00]
My 335i with sport pkg drove perfectly straight.
      11-07-2014, 04:41 PM   #75
YMB-M3-J2
YMB-M3-J2's Avatar
Drives: YMB M3
Try many different roads. That's what I do when I think it's off
      11-08-2014, 09:16 AM   #76
Drizz
Drizz's Avatar
182
Drives: '23 BMW X7; '20 911 Carrera S
Maybe BMW sets the spring rate on the driver side a bit different for US-spec cars to account for fat-ass Americans. So if you're actually a normal weight the car pulls right. :
      11-08-2014, 09:28 AM   #77
shivaswrath
shivaswrath's Avatar
Drives: 2012 335i
I think others were
Complaining about the alignment, might be a factory related issue.
CURRENT: 2017 RS3 (miss you guys)
SOLD: 2012 335i Mineral Gray
M Performance Exhaust/Brakes/Suspension/LSD|Bav Stage 1/AMP||ER CP/IC/DP/OC | Dinan CAI/N55 PWG BIG TURBO|BMWF30.com
      11-08-2014, 10:01 AM   #78
A267839885568
A267839885568's Avatar
Drives: 2015 BMW M4
2015 BMW M4  [0.00]
Mine definitely pulls to the right as well
      11-08-2014, 11:33 AM   #79
audihere
Drives: F80 M3 and Clown Shoe
A while back I realized that most roads are not flat. If you roll a marble in a straight line on the right hand side of a road that is slightly sloped downward from the middle on both sides, the marble will pull to the right due to gravity. I think it goes same for cars. Only way to test is on perfectly flat pavement which is harder to find than you'd think since most roads have a slight slope to them for drainage or whatever. Just my 2 cents.
Chris
      11-08-2014, 11:56 AM   #80
nujabes24
Forever Rest In Beats
nujabes24's Avatar
73
Drives: 2014 MW M4
Man i just got mine two days ago and it pulls to the right. It sometimes feel like im trying to fight it, what the hell!!!!!
      11-09-2014, 12:52 PM   #81
kiloil
kiloil's Avatar
21
Drives: 2015 M4
Mine is the same way.
2015 M4
Looking for a 50' SeaRay
      12-04-2014, 06:47 PM   #82
MWcoupe
24k GOLD
MWcoupe's Avatar
Drives: Mineral White M4
Same here, only issue I'm really having so far. Going to swap front tires and see if that works
      12-04-2014, 09:52 PM   #83
minn19
minn19's Avatar
14078
Drives: 24 Z06, 23 CT4VBW, 22 PFinder
Add mine to the list. Dealer is going to check it out at my break in service.
      12-08-2014, 09:11 PM   #84
MWcoupe
24k GOLD
MWcoupe's Avatar
+1 over here! Any got dealer to fix this issue?
      12-08-2014, 09:22 PM   #85
M3.2.M4
///MD
33
Drives: 2017 MW ZCP F80. 2016 SG F15
Chris
I agree. Tested on two lane country road and it did go to the right. Tested again same road left lane and it went to the left. Seemed to notice it more the faster I drove. On then track...straight line.
      12-08-2014, 09:27 PM   #86
Tonymiabmw
Tonymiabmw's Avatar
555
Drives: Nardo F90 M5 on order
Mine pulls hard right to, suspect radial drag though gonna swap tires. Should do the trick.
      12-08-2014, 10:08 PM   #87
Lessthanzero
Drives: BMW M3
M3 on 18s. No pull so far.
      12-08-2014, 10:19 PM   #88
Wei718
Wei718's Avatar
340
Drives: 718 GT4
Wow, more and more people are coming forward on this issue. I hope BMW will do something about it as it's bugging the crap out of me.
f80post
