      02-14-2008, 08:38 AM   #67
BMWeber
Drives: 08 135i
Originally Posted by MrRoboto View Post
(E82)1423>(E92)1395
yes that is height not weight 56' for the E82 and 55" for the E92
      02-14-2008, 08:43 AM   #68
MrRoboto
Drives: VO 1M
^^^Damnit I am an idiot. Sorry for the confusion.
      02-14-2008, 08:46 AM   #69
BMWeber
Drives: 08 135i
hey you had me second guessing my self but I new something was wrong when the E92 calculated out to 3069lbs it's all good though :smile:
      02-14-2008, 09:49 AM   #70
Sherifftruman
Drives:
Ok, that make sense as we knew the 1 was a touch higher. Funny the difference that one little letter in front of "eight" makes when you do not pay enough attention. :biggrin:
      02-14-2008, 10:40 AM   #71
Brandon26pdx
Drives: 2011 135i
So this car has the DSC/DTC which can be turned on/off via a button, and the "E-diff" function which is fixed and cannot be overridden? (If I read that right...the language could have been better polished.)
      02-14-2008, 10:44 AM   #72
larryn
Drives: '97 332ti, '21 X5 45e, '16 GT4
Correct, but it only becomes active when both the standard DTC and DSC are disabled.
I can't see a need to disable, if it remotely does what it says it does... which is to try to immitate a conventional LSD.
This new eLSD seems to simply be DTC (which normally applies brakes to spinning wheel plus shutting down the fuel injectors), minus the killing throttle part.
      02-14-2008, 10:46 AM   #73
cracka
cracka's Avatar
Drives: VO 1M
That's how I read it as well... and further, the e-diff isn't in effect unless DSC/DTC is disabled. That's definitely new news.
      02-14-2008, 12:05 PM   #74
xlifelessdaysx
135 elite
Drives:
and this is because dsc will not let you get to the point where non lsd and lsd becomes apparent.
      02-14-2008, 12:18 PM   #75
cracka
cracka's Avatar
Drives: VO 1M
Sure, it makes perfect sense in the narrative we finally got. There had been a serious dearth of info before this, though.
      02-24-2008, 10:32 PM   #76
RedTRex
Digital Cerebrum
Drives: 05 330ci ZHP
2005 BMW 330ci  [0.00]
Originally Posted by Klinn View Post
Hmmm, so much for leaving out a spare tire and jack to save weight! How about putting those back in and removing the "trim weight".
cuz it has run flats :iono:
      04-24-2008, 03:12 PM   #77
taylor82
Drives:
think he means he'd prefer non RFs, who wouldn't! :wink:
      05-26-2008, 10:49 PM   #78
wrx4sale
In Love
Drives:
these pdf's are about the be the reason why I am very tired at work tomorrow.:hitcomput
135i-6spd-BlueWater-Savanna-Aluminum-Sports
Delivered 6.27.08
      06-09-2008, 02:45 PM   #79
larryn
Interactive Flash Based versions of the technical manual and non-iDrive owners manual added to first post!
Thanks for doing that, Mic!!! You rock!
      06-09-2008, 03:36 PM   #80
mikeo
Santa Fe Concorso
mikeo's Avatar
Drives: '11 M-sport 328i, '13 X1 28i
Any idea when the E82 will show up in online BMW ETK Parts?
      06-09-2008, 06:30 PM   #81
larryn
It's already on http://bmwtis.com
I know AndyM had a 24 hours subscription a while ago, and got a bunch of part numbers. I don;t know when there will be a ETK/TIS downloadable version of it, as they seem to have moved to that online subscription database, in lieu of having to burn thousands of cds every quarter and distribute them.
      06-09-2008, 07:34 PM   #82
mikeo
Santa Fe Concorso
mikeo's Avatar
The free one, Larry, the FREE one! :biggrin: I've used RealOEM.com and was hoping for it to show up there. Oh well. :iono:
      06-09-2008, 07:39 PM   #83
Kris
Drives: m3
The training info says that the 135 comes standard with adaptive turning lights? my car does not have that.. what gives?
      06-09-2008, 07:56 PM   #84
mikeo
Santa Fe Concorso
mikeo's Avatar
The training manual is for the US market only I think.
      06-10-2008, 12:22 PM   #85
DC135i
Drives:
Originally Posted by Rook View Post
Is there an owner's manual that includes iDrive? I don't see it here, or am I missing something?
[SIGPIC][/SIGPIC]
      06-10-2008, 12:52 PM   #86
plien69
Drives: 2014 M235i
No one's been able to find an electronic version of the iDrive manual.
      06-10-2008, 03:27 PM   #87
whiplash
Private No Class
whiplash's Avatar
Drives: Depends on the day
They only work when the headlight switch is set on the 'automatic' mode. The interactive portion is disabled if you simply turn the switch to "on". I found that out about a month after I had the car (no as a matter of fact, I did NOT read the manual...).
Don't know if this is the case for you or not but thought I would throw it out there.
They followed me home...can I keep them?
Dan in Houston / CCA # 93849
      06-17-2008, 08:32 AM   #88
bmwfreak
bmwfreak's Avatar
32
Drives:
iDrive manual upload as well now and added to the first post, thanks to Jeff @ BMWNA!
the roundel
1addicts
