03-29-2022, 04:04 PM | #47 |
Supreme Allied Commander
3893
Rep 54,602
Drives: F80 M3
SPL Titanium Series Adjustable Rear Upper Wishbones (Camber Links) BMW E9x E8X F8x
Our SPL FKS front caster rod bushings replace the stock flexible rubber bushings with low friction articulating spherical bearings elminating bushing deflection and reducing friction. This maintains optimum suspension geometry under load to improve braking and handling feedback. Massive 1" sized FK racing bearings with self lubricating Teflon liners are used to ensure maximum performance and durability. Innovative CNC'd offset bearing spacers provide +/- 4 degrees of caster adjustment. 6061 Aluminum bearing housing with outer knurl 6061 Aluminum offset spacers provide +/-4 degrees of caster adjustment FK one inch spherical bearings Sold as a pair. Made in the USA. Applications: E8X 1 Series BMW M and non M E9X 3 Series BMW M and non M F8X M2 M3 M4 |
