02-08-2021, 04:54 AM | #45 | |
Rep 335
2017 G30 520 (1.6lt)
2016 S1000RR 2014 W205 Last edited by ejlover06; 12-28-2021 at 06:07 AM.. |
02-08-2021, 09:11 AM | #46 | |
Rep 108
02-15-2021, 04:16 AM | #48 |
Rep 335
I'm glad it worked
2016 S1000RR 2014 W205 |
02-24-2021, 07:36 AM | #49 |
Rep 1
Dear fellows!
Thanks, for sharing you ideas and the way you trying to achieve it My bmw g30 my2019 doesn't have KAFAS, so i use FSC code, to activate SLI from navigation map (I used sli emulator from ali). nowdays i try to activate manual SLI assist, i did this codings and have Speed Limit Assist in NBT and can activate it, but nothing happens and i don't have limit assist at dashboard. Here's my coding: DSC3: C_EDP_vorhanden = nicht_vorhanden -> vorhanden C_EDP_Land_Aktiv = F9, DC, 00, 00 -> all FF C_SLA_Variante = kiene -----> dcc [01] C_vSLI_Land_aktiv = UNK_PARAM_1 (FB, DF, 83, C0) -> all FF C_VZA_Funktion_Land_aktiv = UNK_param_1 (FB, DF, 83, C0) -> all FF C_VZA_Funktion - false --> true BDC_BODY2 3420 DG_3420, 14 24 STRECKEN_VERLAUF --- aktiv PIA_DEFAULT_UEBERNAHME_GESCHWINDIGKEIT aktiv UEBERNAHME_GESCHWINDIGKEIT aktiv sas2 C_EDP_vorhanden = false --------------------> true C_EDP_Land_Aktiv FB, DC, 00, 00 ---> all FF C_EDP_Vorausschau_aktiv = UNK_param_1 FB, DF, 83, C0 ---->> all FF C_EDP_SLI_aktiv = FB, DF, 80, 00 ---->> all FF C_EDP_Anzeige_Zusatztexte: = true C_vSLI_Land_Aktiv UNK_param_1 FB, DF, 83, C0 -->> all FF C_vSLI_Funktion - false --> true C_EDP_Laendersteuerung_Konfiguration Voraus aus matrix, sli immer aktiv---->Vorausschau immer aktiv, SLI immer aktiv C_ISA_vorhanden false ->> true C_VZA_Funktion_Land_aktiv UNK_param_1 FB, DF, 83, C0 -->> all FF dkombi LDM_ISA_ENABLE nicht_aktiv ---> aktiv LDM_TIP_ENABLE nicht_aktiv ---> aktiv LDM_VORAUSSCHAU_ENABLE nicht aktiv [01]---> not change LDM_VORAUSSCHAU_sli_ENABLE - nicht_aktiv--> aktive HMI_ECO_TIPP_GESCHWINDIGKEIT_KI_ENABLE aktiv nbt slamanuel - nicht ----> gen_1 AUTOTEMPOMAT - nicht aktiv --->gen1 AUTOLIMITER - nicht aktib ----> gen1 HUD_VZA - nicht - > aktiv KI_DISP_CB_STRECKENUEBERSICHT - nicht -> aktiv STRECKENVERLAUF aktiv [01] VORAUSSCHAU gen 1 VOFFSET gen1 After that i have an error in SAS: Message (traffic sign recognition, 258.1.4) missing, recipient SAS, sender KAFAS I think i missed something, couse SAS recieve message from KAFAS, but cannot recognize it. Or it's not possible to activate manual SLI assist without KAFAS module? |
09-03-2021, 03:11 AM | #50 |
Rep 80
hi
who can write correct coding for speed limit activation in G30 2019 (means MGU an live cocpit). Of course kafas4 is in the car. I ordered fsc, and i just looking for coding. I have some from many pages, but all diffrent and diffucult check what is true. thanks in advance Edit 23-09-2021: I added SLI_NPI to car - some photoes added Last edited by Wojti_; 09-23-2021 at 03:56 AM.. |
12-27-2021, 02:37 PM | #51 | |
Rep 562
ACSM5 AMP_TOPHE ATM BDC_BODY2 BDC_GW2 DKOMBI2 DME_BAC2 DSC3 EGS EME3 FLM FLM FRR2 FZD2 GWS2 HKEM2 HU_NET2 ICAM3 IHKA4 KAFAS4 LMV2 OBC RS SM2 SM2 SME217 SPM SPM_S TFM2 USS VSG ZBE4 |
12-28-2021, 06:09 AM | #52 | |
Rep 335
12-28-2021, 10:13 AM | #53 | ||
Rep 562
04-28-2022, 10:19 AM | #54 |
Rep 9
Hello guys
Is anyone of you having an issue with Driving Assistance Affected after pressing the button Cruise Control with Distance Control in the steering wheel. I have changed the SLINPI values to 00 and FF, it reads the signs very good and also the Distance Control works good but as soon as I press the button in steering wheel it shows the Driving Assistance Affected in head unit. Thank you! |
06-09-2022, 03:08 PM | #55 |
Rep 99
Who knows how to increase additional speed value from 15km/h to 20km/h? https://g30.bimmerpost.com/forums/sh...1#post28995431
10-12-2022, 10:42 AM | #56 |
Rep 1,529
Just revisiting this subject: Has anyone been able to provide a working code path for <2019 G30 with idrive 6 for the speed-adjust to work?
11-23-2022, 12:25 AM | #58 |
Rep 562
01-03-2023, 07:37 PM | #59 |
Rep 24
I'm using a 2017 G30 523d.
I got my FSC code for SLI activation. The data sent (xxxxxxx is the VIN code of your vehicle) e.g. xxxxxxx_007E0001.xml e.g. xxxxxxx_007E0001.der e.g. xxxxxxx_007E0001.fsc Are the following FSC installation parameters correct? Diagnostic address 0x5D Application number 126 Base variant KAFAS4 upgrade index 1 |
05-06-2024, 08:30 AM | #61 | |
Rep 650
Drives: 2018 F48 X1 xDrive 18D
Tags |
edp, isa, sla, sli, vza |
