N54 Public XDF Repository
01-12-2016, 09:24 PM | #46 |
BimmerPost Supporting Vendor
1339
Rep 1,701
Drives: Slot Machines.. Keep Taking $
07-24-2016, 10:11 AM | #48 |
Supreme Galactic Commander (one galaxy over...)
676
Rep 1,778
How does one upgrade their ROM version? Is that a dealer only thing? I'm on IA80S but don't know if there is any reason to upgrade or not. thx.
Best,
Andy '12 E82-PS2,Stoptechs,Clubsports+M3 bits,Accusump,Wagner DP+EVO III FMIC,ERCP,BMS Intake,Mason Strut Bar,Wedge Tune |
07-24-2016, 12:40 PM | #49 |
1339
Rep 1,701
I8A0S is the latest ROM version for MSD80. The MSD81 supports IJE0S for most cars and IKM0S on the 1M, and INA0S for 335is and Z4's. The only way you'll be able to run IJE0S is to replace the DME to an MSD81. I have an MSD81 in my '07.
07-24-2016, 08:20 PM | #50 |
676
Rep 1,778
Mines an 08...did you backfit? And , if so, what was the driver to do so?
Best,
07-24-2016, 11:26 PM | #51 |
1339
Rep 1,701
07-30-2016, 06:57 AM | #52 |
676
Rep 1,778
07-30-2016, 06:23 PM | #53 | |
1339
Rep 1,701
Another option would be to virginize a used ECU. Talk to Bryce at BimmerScan for pricing. There are a lot of MSD81's that can be picked up for cheap. http://www.bimmerscan.com/ |
AndyW675.50 |
08-12-2016, 05:54 AM | #54 |
Rep 1,184
BUG in I8A0S XDF
the aggression throttle table is badly defined
you should replace 73BBE with 73BDE then the table is fulli defined it was correct in an old wedge XFD I could compare with |
08-12-2016, 12:35 PM | #55 | |
1339
Rep 1,701
08-26-2016, 10:47 AM | #57 |
Rep 345
That's actually the reverse. There was previously an error, corrected for some time now but some residual BINs are wrong.
WedgePerformance1339.00 |
08-26-2016, 10:51 AM | #58 |
Rep 96
Hey guys, long time coming for this update! Lots going on right now and XDF updates got pushed to the back burner a bit. Anyway, here's what got pushed today (20 new tables):
Engine Cooling - Coolant Temp Threshold (enable warning) - Coolant Temp Threshold (yellow warning) - Coolant Temp Threshold (red warning) - Oil Temp Threshold (enable warning) - Oil Temp Threshold (yellow warning) - Oil Temp Threshold (red warning) - Oil Temp Threshold (upshift warning) - Temp Threshold for End of Warm-up - Ambient Temp Threshold for High Mode - Ambient Temp Threshold for High+KFT Mode - Coolant Setpoint (Normal Mode) - Coolant Setpoint (High Mode) - Coolant Setpoint (High+KFT Mode) - Radiator Fan Duty Cycle (ECT Target Diff) Exhaust Flap (credit to MHD Tuning for these and reversing the logic!) - Maximum Speed for Static Exhaust Flap - Static Exhaust Flap Position - Torque Request % for Exhaust Flap Actuation (AT) - Torque Request % for Exhaust Flap Actuation (MT) - Torque Request % for Exhaust Flap Actuation (AT - Convertible) - Torque Request % for Exhaust Flap Actuation (MT - Convertible) The table names for these are pretty self explanatory, but if you run into trouble let me know. If been running High / High+KFT ambient triggers lower than stock (23 / 28 *C), and a tad lower coolant setpoints for awhile now and it works GREAT. Seriously. It even keeps oil temps a good bit lower =) As usual, you can find the latest XDF's at the public github. Enjoy! |
08-28-2016, 07:17 AM | #59 |
Rep 56
Drives: 2007 335i
Wedge,
Is your 2007 manual or automatic. I would entertain an upgrade to 81 but I don't think the 6HP19 is compatible. |
08-28-2016, 05:46 PM | #60 |
1339
Rep 1,701
08-29-2016, 05:34 AM | #61 | |
Rep 1,184
it is from address 73C3E to 73C5C is this a continuation of table throttle angle aggression? or another table? it is undefined in the last XDF of 5 days ago on github |
09-08-2016, 09:23 AM | #63 | |
1339
Rep 1,701
09-09-2016, 07:46 PM | #64 | |
Rep 2,842
| | V What is High mode and High + KFT mode? |
09-11-2016, 01:36 PM | #65 |
Rep 56
Drives: 2007 335i
Does anyone know how I could find the address(hex) for codes 2C9E and 2C9F? I would like to eliminate my rear oxygen sensors and disable the codes from turning on the service engine soon light. If I knew the addresses I could add the parameter to my I8A0S XDF
149,000+ miles, MHD, VRSF 5" FMIC, Aluminum charge pipe. E50 tune by Wedge Performance. 3" Catless DP's. Secondary Cat Delete. DCI cold side w/silicone Inlets. N20 TMAP, "Stage 2" Walbro 450 LPFP. xHP Stage 3. 1/4 mile 12.079sec @ 118.79mph. (2.03 60')Before xHP flash and rear cat delete.
09-15-2016, 08:51 AM | #66 |
Rep 1,544
Will the tables for enabling exhaust burble be added into the XDFs?
So I can change duration without using the flash time options in MHD. |
