04-03-2015, 01:26 PM | #45 | |
High on Acceleration
671
Rep 1,439
04-03-2015, 01:51 PM | #46 | |
Gone Fishin’
7318
Rep 12,125
04-03-2015, 01:53 PM | #47 |
671
Rep 1,439
04-04-2015, 03:52 AM | #48 | |
Rep 321
I race in series overseas that use production cars, you are allowed to take certain things out, others have to stay. At the same time you add in weight with a cage etc. Also, the car has to comply to a minimum weight. If you are building a car for series like this it is extremely helpful to have a list of weight of all kinds of components. It may help you decide whether the car is going to work within the regulations etc. Previously when I have built rally cars I have documented the weight of everything that comes out of the car, down to things like sun visors, small plastic trim panels, seatbelts etc etc. It provides others with a great resource Thanks to the OP for putting this together. It is greatly appreciated |
04-13-2015, 07:22 AM | #50 |
Comrade
56
Rep 211
Drives: 15 M4 DCT
15 M4 / 14 M235i-Sold / 09 E92 M3-Sold / 07 E92 335i-Sold
05-07-2015, 09:36 AM | #51 |
671
Rep 1,439
I've added a couple more items.
Rogue Engineering 12mm and 15mm spacers plus their extended lug bolts. These are supposed to be some of if not THE lightest choice for our vehicles. The extended lug bolts are identical in weight to the Macht Schnell versions so they are probably the same part if I had to guess. The RE spacers are 22% lighter than the Macht Schnell variety. You can clearly see why when you look at them. There are additional large lightening holes on the spacers. |
08-25-2015, 01:06 PM | #52 |
Rep 3,688
Drives: 2021 Supra 3.0 (Past: 2015 M23
Front seats weight: http://f80.bimmerpost.com/forums/sho...5&postcount=20
08-25-2015, 01:55 PM | #53 | |
671
Rep 1,439
10-26-2015, 09:35 AM | #54 |
Rep 560
I know you mentioned the hood is not heavy..but i wonder how much weight savings would be to go to a full CF one..there are already some out there..i am sure some pro ones will come out when more M3/4s are produced
12-13-2015, 01:29 PM | #55 |
BMW Fan
148
Rep 314
Great thread.
So it sounds like the best route for maximum easy weight savings is: - CF roof - Remove back seat - Smaller battery Anything else that would be easy and very noticeable? Unfortunately I feel the car needs more weight on the rear for traction purposes. |
02-28-2016, 02:22 AM | #57 |
Rep 656
Great thread. I have a few items that would be a nice reduction. Interested on how much saved.
I'm concentrating on unsprung weight first. AP Racing Pro 5000R Radi-CAL BBS FI-R HRE (Ticore) Titanium wheels lugs Need to check the weight of Ohlins TTX46 & TTX36 I already have the full titanium AKRA. Weight savings is always and interesting way of modding, that has almost hidden payoffs.
///M4 | AKRA Evo & DP's | Brembo GT BBK | MSR CAI & CP's | MPSC2 |
Suspension : | KW CS 3-way | Dinan Toe Links | GC ARWJ & End links | IND Shims | SPL Control arms & End links | aFe Bars | |
03-09-2016, 03:46 PM | #59 | ||
Rep 2,105
Drives: M4 MW/SO 6MT, E46 M3 AW/IR 6MT
What is the weight of the rear seats?
MILA | E46 BMW M3 | AW/IR | 6MT | KW V3 | CSL | Vorsteiner |
EMILY | F82 BMW M4 | MW/SO | 6MT | M Carbon Ceramic Brakes | M Performance Exhaust | |
03-12-2016, 01:17 PM | #60 |
Rep 20,742
Drives: 2021 911 turbo
IIRC, karussell weighed his M4 rear seats at ~40lb.
Porsche 911 turbo 2021 992 GT Silver
Previous cars: M4cs 2019 F82 Limerock Grey / M4 2015 F82 Silverstone / M3 2008 E92 Silverstone / M3 2002 E46 Carbon Black |
03-12-2016, 01:28 PM | #61 |
Rep 2,105
Registered my car for 1/2 mile at Shift S3ctor so trying to figure out the benefit of removing some parts
03-12-2016, 02:24 PM | #62 |
Rep 20,742
Every bit counts
03-25-2016, 10:23 AM | #63 |
Rep 153
Seems like there's a lot of weight to be had in the exhaust as well. Burger tuning posted a 43lb weight loss using their exhaust over factory.
http://f80.bimmerpost.com/forums/sho...&postcount=152 Last edited by Porsha; 03-25-2016 at 10:28 AM.. |
03-27-2016, 08:38 AM | #64 |
Rep 180
Does somebody have weight info for the stock under seat woofers (2?)and amp? Seems like a good opportunity to change to single woofer and move everything to the trunk to reduce weight and shift weight to the rear.
06-13-2016, 01:11 PM | #66 |
BimmerPost Supporting Vendor
8312
Rep 18,880
Following up with OEM Brake Component weights (non-CCB).
OEM Calipers Front Caliper- 10.65lbs ea. Rear Caliper - 8lbs ea. OEM Rotors Front Rotor - 24.4 lbs ea. Rear Rotor - 20.4 lbs ea. OEM underseat subs are 1.65lb ea.
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
Tags |
curb, f80, reduction, weigh, weight |
