ARMA SPEED
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Forum > BMW M4 GTS Discussions
      04-27-2023, 11:29 AM   #45
carM3kee
Drives: F80
Amazing Build!
      06-11-2023, 07:31 PM   #46
johnjames85
Drives: BMW M4, McLaren 720s
Very nice build. I was looking at the AP Motorsport GT4 front splitter, Im now aware of this other option from Slon and the extra work required. Thank you very much.
Do you by chance have a part number for the GT4 radiator mounts required to fit the splitter?
      06-12-2023, 01:35 PM   #47
daveishi
daveishi's Avatar
Drives: M4 GTS, G05 X5
Originally Posted by carM3kee View Post
Amazing Build!
Thanks!
I do, however I ordered them from everywhere online I could find and nobody was able to source them, so best of luck! Ended up modifying a standard set.
17-10-8-417-417 Bracket Coolant Radiator 9100000F82
17-11-8-431-150 Bracket Oilcooler Right 9100000F82
      12-21-2023, 08:57 AM   #48
torpeteo
Drives: 2017 BMW M4
This looks great. What spring rates did you pair up with the additional aero? Any issues at full compression?
      01-26-2024, 01:07 PM   #49
JustAnothaM4
JustAnothaM4's Avatar
Drives: 2016 M4 GTS
2016 BMW M4 GTS  [0.00]
Whats the latest on this...is that front splitter stret friendly at all? I feel this would get torn the fawk while slammed on 18s.
2021 X5M Comp Marina Bay Blue
2016 M4 GTS Alpine White
2005 M3 Comp Interlagos Blue
Instagram: @JustAnothaM4
      01-26-2024, 03:31 PM   #50
daveishi
daveishi's Avatar
Thanks man, sorry for the delay. I increased them to 11k/16k and haven't had any issues at full compression. I may have gone stiffer but would have required a re-valve so I only increased them as much as KW said would be ok for stock valving.
Still running strong! Don't really drive it on the street though haha, only to/from the track. When I do take it around town I am pretty careful since it'll scrape just about all driveways even at an angle and I'm fairly paranoid I'll hit a dip or pothole that will destroy it. I put slip-lo strips on the leading edge to try to help it slide over driveways without scrapping up the carbon but if they catch an edge (like a sidewalk seam) they come right off. Keep in mind I'm also not that slammed, ideally I would run a bit lower on the 18's but I'm fine trading off some performance for a bit of clearance.
bholler5372.50
f80post
