DPF Delete
10-26-2013, 02:25 AM | #23 |
Curmudgeon and Pedant
692
Rep 3,488
10-27-2013, 04:40 AM | #24 |
Rep 136
There will probably be a production DPF delete pipe in the works soon if I have anything to say or do with it.
10-27-2013, 07:05 AM | #25 |
Rep 2,408
The plan is to ship this "overseas" in near future ...
http://www.e90post.com/forums/showpo...4&postcount=27 PR, what's your time frame on when you need a pipe? |
10-28-2013, 07:00 AM | #26 |
Rep 3,488
Drives: Montego Blue 335d
TDi give me a call anytime today Im looking after 8 November when the guy comes back from vacation, if you or Doc aka 335dwagon can come up w something NOT to expensive then i will wait and delay my jumps, as you can see amigos after the flex tube there are the sensors and THAT is what is restriciting POWER from our cars beside the ACTUAL DPF.
Hooper I concur w you in respects to soot building into EGR, if you guys saw how DPF works, before it accumulated particules and regenerated to EGr once DPF is modded that will not be the case since DPF will either be bypassed or new pipe installed.
RENNtech Flash(Lenny Wu)/WAGNER IC
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) Last edited by Puerto Rican 335d; 10-28-2013 at 07:41 AM.. |
10-28-2013, 07:03 AM | #27 |
Rep 3,488
Also I forgot to metion if you have the crystalization of urea it will happen at the end of the flex pipe that connects into the exhaust
TDi gracias for your link w the picture of the DPF
Enkei Rajin 18"/Execuhitch Hitch/Koni FSD Soft Ride Bike Rack/Brava Synthetic Motor Oil(Made in Puerto Rico)/Meth(in the works)/CBU done w Andrew EGR Race Pipe (whoa! what an animal it is now) |
10-28-2013, 07:45 AM | #28 | |
Rep 2,408
http://www.realoem.com/bmw/showparts...15&hg=18&fg=10 |
11-01-2013, 05:36 AM | #32 |
Rep 3,488
Thanks DOC! Also, another member from this forum sent his DPF to get scanned in europe and hope by lets say next couple of weeks we have ONE for us soon!!!!!!!!!
11-03-2013, 12:23 PM | #35 |
Rep 5
Hi im new on here but I have been reading the thread and thought I would share my experience with my DPF.
well my car was gradually losing power over like 2 weeks after I regenerated my dpf as I only do short journeys to work etc. I did a bit of research and thought my best option would be to delete the damn thing so that's what I did. on Saturday I decided to get the car on the ramp and take the dpf off (very fiddly job and not much room) eventually I got it off and decided to cut it open and take the dpf out but leave the cat in and weld back up (cat and dpf combined). while I was doing this I had a friend read my map and send it off to have the dpf software deleted which was sent back just as the car was put back together then programmed back in. Although its not been long and I have not done many miles yet I can report the car does breath a lot better and feels a lot smoother with plenty more power and likes to spin the back wheels when you plant your foot quite effortlessly. I know people are worried about leaving people behind in clouds of black smoke but there does not seem to be much of that at all, you may get a slight puff when you floor it but otherwise its clear. sorry if I have hijacked this thread I just thought my experience would help others and answer some questions. |
11-03-2013, 03:33 PM | #36 |
Rep 2,408
Thanks for sharing.
Did you take any pictures of what the inside looks like? Did you remove just the DPF section and leave the DOC (Diesel Oxidative Catalyst) in place? Did you leave the portion you removed "open" or did you weld in a pipe of some kind? If no pipe was used, is there any resonances occurring at certain rpm's while driving? Could you describe, or better yet show a picture, of where and how you cut open the DPF? Thanks again for your input. |
11-04-2013, 05:39 AM | #37 |
Rep 3,488
Thanks Scotty thats what we want to hear about people with COJONES to do things youre doing, TDi I sent u a pm let me know ok!!!
11-04-2013, 11:34 AM | #38 |
Rep 3,555
11-04-2013, 01:02 PM | #39 | |
Rep 10,397
11-04-2013, 04:49 PM | #41 | |
3442
Rep 79,211
It would be quite interesting to see a 335D rolling some coal though! |
11-05-2013, 02:32 AM | #42 |
829
Rep 3,982
I'm going through the same performance issues right now. Good performance one run, and then a week later, the engine feels suffocated. I don't do much open highway driving. Does anyone know a way to force the DPF regeneration before you go to the drag strip, etc? My exhaust tips are now covered in black soot. The first 2 yrs they were clean.
I thought this all started happening since my EGR recall, but that could be a coincidence, as the DME faults are for excess exhaust pressure, and the dealership test plan calls for regeneration commands to be initiated, then retesting. So yes, right after regeneration, the back pressure is okay, but then performance deteriorates from then. I'm wondering if this is just a factor of a worn DPF? Or did the EGR recall have any effect on this. I did some testing this last weekend, performance was okay to get in the 12's with traction, but considering I was running K1 with drag radials, and seats removed, it should have been faster. (car ran over 108mph with more weight when it was new!) But in the same configuration with the back pressure issues, my trap speed would be down to 99mph! That is like a 70hp handicap! And basically what the car would run stock without the JBD.
2011 Alpine 335d M-Sport 12.34 @ 110.48mph
2019 i3s Terra, 2008 Black 335i Sedan. 11.11@ 129.47 mph 2008 Monaco Blue JB3 2.0 335i Coupe. 11.33 @ 132.77 mph, 60-130mph: 6.95 seconds 2023 i4 M50 11.48 @ 121.56mph, 3.43 0-60 (dragy) Last edited by hotrod182; 11-05-2013 at 02:39 AM.. |
11-05-2013, 07:35 AM | #43 | |
Rep 2,408
http://www.bimmerfest.com/forums/sho...5&postcount=21 http://www.bimmerfest.com/forums/sho...4&postcount=22 http://www.bimmerfest.com/forums/sho...8&postcount=23 Wonder if the algorithm that tracks the loading on your DPF is out of sync with how much ash has actually accumulated? The more the DPF loads with ash the less room it has to hold soot ... I've been tracking the backpressure and loading of my DPF for awhile now and it had seemed like it was aging gracefully. But if you are triggering backpressure faults ... that is troublesome for the condition of your DPF. |
11-05-2013, 11:41 AM | #44 |
Rep 697
I don't think EGR operation (valve opening ratio) would come to play here in terms of performance under WOT, as the EGR valve should be completely closed under these conditions.
If I remember your posts, you had the JBd pretty much since your car was new. From my understanding of the EGR operation relative to AFR, with the JBd active, you have less EGR. Therefore; less build up (carbon/soot build up) in the intake valves, etc. but more for the DPF to handle. Your symptoms sound like a clogged/restrictive DPF. DPF versus no DPF is about 30hp (saw a dyno chart somewhere) so it can definitely be a restrictive component. |
