12-31-2022, 06:04 PM | #23 | |
Rep 134
07-14-2023, 06:47 AM | #25 |
Rep 105
Drives: BMW 550i (2023)
I’ve looked all through the owners manuals to find a capacities page. This does not seem to exist, specifically the oil capacity for the 2023 M550i. I can find all kinds of info on oil type, checking level, etc.
There is nothing I can find referring to oil change, oil capacity, with and without filter. How does one know how much oil to use without manufacture reference? |
07-14-2023, 01:39 PM | #26 | |
Rep 5,409
07-15-2023, 06:15 AM | #27 |
Rep 105
05-08-2024, 05:00 AM | #28 | |
Rep 2
so which one is more environmentally friendly? reducing engine life or changing oil more often and disposing of the used oil correctly ? Such a stupid argument. |
05-08-2024, 05:54 AM | #29 |
Rep 5,168
It’s 10.5 litres of oil for the m550
I know because that was stated when I got mine changed earlier in the year at the dealership Just out of interest, what is done with old oil , I know it’s dealt with properly but where does it actually go? |
05-08-2024, 05:58 AM | #30 | |
Rep 6,870
Drives: '18 M550i|'21 X5|'03 540i
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [10.00] 2018 BMW M550 [10.00] |
Such a studid reply.
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
430Scud275.00 |
05-08-2024, 02:26 PM | #31 | |
Rep 316
Surprisingly in the USA, most used motor oil that is "reclaimed" is not made into more motor oil, but is filtered and used for industrial uses such as heating, ship fuel or generating electricity (basically we are burning it). I was told, once an oil molecule is used up, you cannot restore it...you can re refine it, blend it with new oil, but will be inferior to virgin refined oil. (not sure if that is a true statement or not) Last edited by 430Scud; 05-08-2024 at 03:58 PM.. |
Joe-BMW337503.50 |
05-08-2024, 02:43 PM | #32 |
Rep 316
If anyone is looking for a little DIY oil change info, here is what I have compiled.
(this document assumes you know the basics of an oil change and have done them previously) BMW M550iX N63TU2 oil change information: 10 quarts LL-01FE, LL-01 or LL-04 oil (LL-01 or LL-04 preferred) Focus on the approvals, not the viscosity. If have the right approval, the viscosity will be in the appropriate range BMW wants. BMW approvals are more about the HTHS rating than the viscosity (HTHS stands for High Temperature High Shear) LL-01 and LL-04 have a higher HTHS than LL-01FE BMW oil filter kit # 11427583220 (made by Mahle), Mahle OX3537DECO, Hengst E359HD306 or Mann HU 8007 z Drain plug bolt torque: 20 NM or 14.75 lb ft Oil filter cap: Initial torque 30 NM or 22.13 lb ft, release torque through 180 degree counter clockwise/final torque 40 NM or 29.5 lb ft. Oil Change Light Reset BMW 5 Series Procedure 1. Make sure the hood is closed and the ignition is off. 2. With your foot off the brake pedal, press the START button three times quickly. 3. Wait for Diagnostic Mode Active to be displayed in the cluster. 4. Hold down the BC or RESET button on the left side of the steering column or cluster until the service menu is displayed. 5. Press the same button to scroll through the menu until ENGINE OIL is displayed. 6. Press and hold the same button until the reset is completed. 7. Follow the screen prompts, you may need to press and release the button several times. |
Joe-BMW337503.50 |
