07-19-2021, 07:48 PM | #23 | |
Rep 2
Thank god it worked!!! I kept on hitting roadblocks and boom someone figured out exactly how to code for a US G30 bc I too didn’t have all of the LIC coding as previous mentioned but luckily my 2018 G30 had the diodes and wiring so all I did was buy a Euro switch and coded with BimmerCode and wha-la we’ve got rear fogs!! Many thanks to all of the pioneers helping everyone else out with coding their cars with ease, I salute you! |
07-23-2021, 06:20 PM | #25 |
Rep 803
I honestly just stuck a plastic trim puller between the top of the switch and bottom of the top part of the dash and pulled it straight out. Unplugged the old switch, plugged in the new one, and popped the new one in. Takes about 5 minutes.
paquet629.50 |
08-01-2021, 08:52 AM | #29 |
Rep 2
I'm trying to change parameter to UNK_PARAM_1, UNK_PARAM_3 or UNK_PARAM_5 but I don't know how?
Someone to explain hot to do that because I have car for fog lights coding. |
10-21-2021, 08:27 AM | #31 |
Rep 6,869
Drives: '18 M550i|'21 X5|'03 540i
Garage List 2013 VW Tiguan [0.00]
2015 Infiniti QX60 [0.00] 2021 BMW X5 [0.00] 2003 BMW 540i [10.00] 2018 BMW M550 [10.00] |
Excellent write up and very helpful. Thank you.
10-21-2021, 08:46 AM | #32 | |
Rep 6,869
Question, is the coding with Bimmercode in simple mode?
2018 M550ix|Carbon Black|Dinan Modifications|2003 540i|Jet Black|M-Sport|2021 X5 Mineral White
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| |
10-21-2021, 08:49 AM | #33 | ||
Rep 803
10-21-2021, 08:52 AM | #34 | |||
Rep 6,869
704g30101.50 |
10-21-2021, 08:55 AM | #35 |
Rep 6,869
Also I thought all the coding in this thread was with esys, I'll have to look back a bit closer for the Bimmercode instructions.
10-24-2021, 05:58 AM | #36 | |
Rep 803
10-24-2021, 06:01 AM | #37 | ||
Rep 6,869
540iSUP704.00 |
10-28-2021, 07:07 AM | #39 |
Rep 6,869
My tracking says "Item sent abroad" on 10/25 from Latvia with an airplane icon next to it. I would have to assume it is in the states by now, but no updates to this entry.
11-01-2021, 06:37 PM | #40 |
Rep 65
Drives: 2017 BMW 540i
Plugged in my switch I got from Europe and this worked without an programming so far. Pictures are no where near how bright this is in person.
Now to get the other one working with it!
11-02-2021, 03:26 AM | #41 |
Rep 803
11-02-2021, 05:50 AM | #42 |
Rep 6,869
He has both wires in pin location 1 inner. Needs to be coded still. This is how it works when coded for Euro tails but not coded for the switch. My car is going in for an oil change today. The same shop that installed my tails is going to check if I have the fog wire. Fingers crossed. I ordered the switch from Latvia and who knows when it will arrive. If I do have the wires, I will pop it in and have Vic code it. If I don't, I will have a switch for sale that is for a G30 without front fogs (M550) and without night vision. It's not worth running two new wires from the BDC, but you never know, the shop today might give me a reasonable quote. The irony here is, I know how to do ALL this stuff myself, but it is easier and more time efficient to have my shop do it. They charged me only $300 to install the tails and run new 5th wires from the BDC.
Prior BMW's: 1987 325e|1993 740i|1998 740il|2001 530i|2002 745li|2007 750li|2006 750li|2001 530i|2012 535xi| Last edited by Joe-BMW33; 11-02-2021 at 05:57 AM.. |
11-02-2021, 06:06 AM | #43 |
Rep 65
Yep, what Joe said. I just have to get it coded now. I was going to get it coded last night but my kiddo is sick, so that took the front seat. I might try my hand at Bimmercode depending on Vic's schedule
11-02-2021, 08:01 AM | #44 |
Rep 6,869
My lucky day. I've got the rear fog wires! All six pins full. Pin 1 is the fogs. Black yellow, Black white.
