06-29-2017, 08:48 AM | #23 | |
Hoonigan
6941
Rep 3,017
Posts Drives: '09 328i, '98 Wrangler Join Date: Dec 2016
Diesel trucks definitely need to be worked, but with the newer ones it is a constant battle. Don't work them enough, and they get coked up. Work them constantly, and the truck produces more soot in the DPF, causing it to regen more often. My buddy also found out that for all the guys who have tuned trucks, you can pretty much add another 0 to the price for what would normally be a wear item. Definitely keep the newer trucks stock, or use only a light tune. A lot of those big tuners will advance the timing too much and the engine goes boom under load.
"Yeah, but your scientists were so preoccupied with whether or not they could, they didn't stop to think if they should."
-Dr. Ian Malcolm, Jurassic Park |
06-29-2017, 05:10 PM | #25 |
Rep 610
It's all going to depend on what size trailer you are going to pull, how far, and how often? Going up mountains?
If you just plan on staying a few hundred miles from home or less and only tow a few times a year then the f150 with either engine is fine. Otherwise highly consider finding a used diesel instead. |
06-30-2017, 12:04 AM | #26 |
NOOB
1607
Rep 1,356
Drove friend's new ecoboost fx4 several time and wasn't impressed at all. Felt really floaty and seemed like a lot of play in the steering. The ride and seats weren't comfortable. Much prefer the Ram especially when they are 25% off. Almost impulse bought one just for towing.
06-30-2017, 01:10 PM | #27 |
Rep 610
I'm not big on Chrysler products but RAM does offer a diesel in a half ton truck that is much more reasonable than its 3/4 ton diesel brother. I belive Nissan has one also that may be worth checking out.
06-30-2017, 01:38 PM | #28 |
Rep 14,443
Iirc, the nissan is having big problems. Nothing against nissan trucks. Went through 2 titans myself and never a problem.
Crazy Diamond
06-30-2017, 01:54 PM | #29 |
Rep 610
Yeah I didn't know any details other than than they offered a diesel and it just came out. Hopefully they will work out the problems.
RAM also had a problem with first year eco diesels... I belive they were getting exhaust gas in the cab. The eco diesel wasn't anything new when it went into the RAM either, it had been offered in the grand Cherokee for years. It's just one of those first year model woes, they changed one little thing when they transplanted the eco diesel into the RAM and it didn't work right. |
