E90Post
The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Wash, Wax, Detailing and Cosmetic protection/repairs > Foam Cannon - worth it?
      08-01-2016, 10:11 AM   #23
bb1857
bb1857's Avatar
868
Drives: 2020 X3MC
2007 BMW 335 E92  [0.00]
2015 BMW 428GC  [0.00]
2014 BMW 535i  [0.00]
I use about 4ounces of soap and the rest filled with warm water. Foams like mad and is enough to do two cars
      08-01-2016, 10:24 AM   #24
PourBoi-Jay
PourBoi-Jay's Avatar
Drives: 2009 335i M-Sport
I use about 2 ounces (sometimes less) with warm. I always get plenty of foam. I use an mtm cannon
      08-10-2016, 01:39 PM   #25
Mr. Tasty
Mr. Tasty's Avatar
428
Drives: AW 335i Mperformance
Originally Posted by Route 16 View Post
put like probably 2 bottles of that yakult size into the container and fill the rest with water. both the pressure washer cannon thing and foam cannon use the same principle
View post on imgur.com
Mine definitely says to just put concentrate in the cannon resivoir.
      08-10-2016, 03:10 PM   #26
jkrig
jkrig's Avatar
74
Drives: 07' e90 335i (SGM)
Try it with just a few ounces of soap, doubt you see much difference in foam thickness.....if you don't see a drastic difference then cut back on soap no need to waste product..
MHD Stage 1+ FMIC // VRSF 5" stepped// StopTech x-drilled Centric Posi-Quiet Ceramic Pads // Wiesslicht AE's // OEM Blacklines // Matte Kidneys // MonoChrome emblems.....
      08-10-2016, 03:50 PM   #27
Mr. Tasty
Mr. Tasty's Avatar
428
I just fill the entire resivoir and use accordingly. I probably only use 1oz each wash.
      08-11-2016, 07:35 PM   #28
chumley
chumley's Avatar
50
Drives: 2009 335
I'll be the naysayer here...I have the Gilmor but haven't used it in a while. I found that to get a nice thick layer you have to go through ALOT of wash soap. Plus - here in FL, even if you aren't washing in direct sunlight, it's usually way too hot to leave soap lie that on the car for more than a few minutes. I usually thoroughly rinse, wash the wheels with a separate bucket, then go by sections with a clean bucket rinsing after each section. Last - unless you don't care about where you are washing, just look at the picts! It takes 10 minutes to rinse all that foam off your driveway!
MHD flash, DCI, BMW PE, ETS FMIC, Powerflex, SWS8xi's, VMR 803's in Solar Rain, LUX V4
      04-14-2020, 01:07 PM   #29
advrider6510
advrider6510's Avatar
Drives: E36 M3, F80 M3, Ford Mustang
Yes, a foam cannon is worth it, especially if you want to keep your cars original shine. Using one before each full contact hand wash will remove large amount of dirt that could otherwise scratch your car. One of the reasons why some prefer to use foam guns/cannons, is that the foam produced helps break down heavy dirt without agitation. By applying suds with zero agitation, heavy layers of dirt can begin to run down the vehicle's surface without you even touching the paint.
Hope this helps
      05-01-2020, 12:16 AM   #30
Gig103
Drives: 2014 Tesla P85D
Is a "foam cannon" the same as a soap tip on a pressure washer?
And follow-up: Should I use my old standby Maxi Suds II, or switch to "Honeydew Snow Foam"? That's a product I had never heard of, and it sounds good for pressure washing, but I'd want something that I can use both as a hand wash as well.
Was: 2008 335xi sedan 6MT Black Sapphire Metallic
Is: 2014 Tesla P85D (Blue Metallic)
Wife's: 2013 Infiniti G37 S sedan 6MT, Black
      05-08-2020, 09:04 AM   #31
fortywater
Drives: E90 335i M-Sport
The Honeydew Snow Foam is a good product, I use it on my cars. Creates good suds and smells good. You can definitely hand wash with the Honeydew. When my car is really dirty I do as follows:
1. Foam Car
2. Rinse
3. Foam car and 2 bucket handwash
4. Rinse
      08-24-2022, 11:11 AM   #32
bimmerzeit
Drives: E28, E39, E90
I'm really happy with Griot's foam sprayer for the $40 it retails for. No need for the pressure washer, and much better than not having any sprayer. It doesn't create that shaving cream style foam however, which will cost at least $240ish to achieve.
      08-26-2022, 08:32 PM   #33
Hoody007
Hoody007's Avatar
Drives: 335i ZMZ LCI | 850i/6
I love mine. Pairs especially well with their pink shampoo and purple foam wax.
That + Sonax for wheels is the optimal car-wash regime, IMHO.
      01-31-2023, 03:13 PM   #34
Alekss
Alekss's Avatar
9
Drives: BMW 328i xdrive
What's pictured above is the Foam Gun. Foam Cannon however is used together with a pressure washer.
The point is, Foam Cannon produces thick, sticky foam that is supposed to dwell on the car's paint for a bit and in the process it is supposed to release stuck on dirt, so it doesn't later get caught in the wash mitt and cause swirl marks. That's the idea, right.
Foam Gun, on the other hand does not have the same properties but it serve as an excellent lubricant while washing the car with a wash mitt.
Both require a decent amount of soap.
The main point, when washing a car, is LUBRICATION. Use a two-bucket method with grit guards and a MF towel or wash mitt.
e90post
