01-27-2015, 09:27 AM | #23 | |||
Rep 8,077
Posts Drives: 11 E90 M3 Individual Join Date: Mar 2006
I'm willing to guess that it would really send the BMW RWD "purists" over the edge. The M division is apparently toying with an AWD M5...rather reluctantly. Could you imagine the uproar and AWD M3/4 would cause? Look at what's happening with turbo engines.
2018 F30 320iX Melbourne Red
01-27-2015, 09:35 AM | #24 |
Rep 1,644
I didn't listen to the audio in the 2nd video, but these tests kinds of tests are completely bogus. Audi's system uses a Torsen (aka torque sensing) center diff. It's a purely mechanical set up that will multiply existing torque on one axle by some factor and transfer it to the other axle. The key is that there has to be some small amount of torque present or else 0 x 0 = 0. Despite that, its still a great system and is easy/cheap to implement. The transverse mounted audi's use haldex which is an xdrive type clutch setup.
Xdrive uses electronically activated clutches to engage the front axle (no true center diff), thus being able to transfer 100% of the torque to either axle even in 100% slip conditions (usually maintains a partial lock to maintain a rear bias of 60/40 I believe). Is it better than a torsen system? In the extremely unlikely event (and by that I mean impossible) that you have ZERO traction on BOTH wheels of an axle, then yes xdrive is superior. The fact that it uses sensors means it should be able to "detect" slippage before lost of traction (using steering angle, throttle, etc...)as well is another advantage. What's really more important is the traction between wheels on each axle. Most of these cars with open diffs and traction control will brake the spinning wheel to transfer torque across the axle. My guess during this test was that they disabled that for the Audi and left it enabled on the BMW. If you want a true performance AWD system look at a WRX STI. An adjustable viscous coupling center diff, which while slower to react can transmit torque in complete no slip situations, and torsen LSD diffs on the front and back (pre 2011). That setup blows the doors off xdrive and quattro. Honestly, I think actual awd performance for quattro vs xdrive has more to do with how the DSC is programmed for same axle traction and tire size/type instead of how the power gets to each axle. If BMW wanted to throw an mechanical LSD or two along with Xdrive it probably would make a formidable performance AWD system. Last edited by PackPride85; 01-27-2015 at 09:55 AM.. |
01-27-2015, 09:45 AM | #26 | |
Rep 233
01-27-2015, 09:45 AM | #27 | |
Rep 1
Audi's Quattro's major axle is front axle while BMW xDrive's major axle is rear axle. Torque are distributed to the other side as controlled by the clutch. If it was the front wheel that is touching the ground, the result is probably the reversed. |
01-27-2015, 09:59 AM | #28 | |
Rep 19,368
Give it time and we may see AWD passenger car sales pass RWD passenger car sales. Actually, I say that without knowing the current numbers and how things break down. I imagine BMW still sells more RWD passenger cars than they do AWD ones, but I'll bet it is closer than one might think. Ignoring two seaters, which are generally not targeting all-climate, year-round driving, there are few RWD cars now that do not have an AWD option. Looking at RWD sedans in particular, optional AWD is quickly becoming the price of entry if you want to be competitive. In another decade and RWD-only sedans could be extinct, and RWD-only four or five seat coupes could be limited to muscle cars and a couple outliers.
01-27-2015, 09:59 AM | #29 | |
Rep 9,134
01-27-2015, 10:26 AM | #31 |
Rep 32
BMW vs. Audi
I've driven both an Audi S4 Quattro and a BMW 328i xDrive in the snow. The Audi had snow tires and the BMW did not. I must say, the BMW did quite better than I expected; it was very resistant to slippage. I've also driven Subaru's with snow tires in the snow as well. I must say that if the BMW had snow tires, it would definitely do better than Audi Quattro but in a test between a BMW with all seasons and an Audi with winter specific tires, the Audi does handle better.
01-27-2015, 10:30 AM | #32 |
Rep 479
01-27-2015, 10:51 AM | #33 |
Rep 252
Posts Drives: Anything with a locking diff Join Date: Nov 2014
I just read a review, where the reviewer mentioned a 435i xDrive would understeer in almost every corner. Well, Im sure that wont happen in the M AWD, but can this issue not be resolved in the normal BMWs???
01-27-2015, 11:03 AM | #34 |
Rep 25,151
Really, wow I for one was suckered by the Audi marketing, nice one BMW.
My car made front page of Bimmerpost
01-27-2015, 11:14 AM | #36 | |
3391
Rep 7,544
-----| Like us on Facebook | Instagram || Tuning Information | Remote Coding |----- ----Visit us at www.BPMSport.com - Emotion. Driven. | Toll Free: (888) 557-5133---- |
01-27-2015, 11:18 AM | #38 |
Rep 3,688
Posts Drives: 2021 Supra 3.0 (Past: 2015 M23 Join Date: Aug 2012
wow.... I really thought audi quattro was king, I don't think I could buy a passenger audi quattro after watching this video
01-27-2015, 11:20 AM | #39 |
Rep 19,368
It could, but the general public is afraid of understeer. Well, that may not be totally fair - they are perhaps just not accustomed to it. You see, since most passenger cars are FWD, people moving up to a luxury car with RWD may not be familiar with it's driving dynamics. Therefore, to make luxury cars more friendly to such people - who represent a large number of buyers, many of whom would not even be interested in buying the car if it were RWD - AWD cars are often purposely made to handle more like FWD cars (or at the very least, are made not to oversteer like a RWD car would).
01-27-2015, 11:21 AM | #40 | |
Macgyver
208
Rep 942
GTX3076R , ADV, JB4, FMIC, BOV, 17"APEX, 255/40/17 SQ, 6-SPD Manual
01-27-2015, 11:31 AM | #42 | ||
Rep 222
2012 BMW M3(LCI)- Frozen Silver| Lux V4 | Competition Package|
