02-18-2015, 09:46 AM | #23 |
High on Acceleration
671
Rep 1,439
I've updated the list to add the OEM, Akrapovic, and M Performance (w/ Carbon Tips) exhaust system weights as noted by EAS here: http://f80.bimmerpost.com/forums/sho....php?t=1092134
02-20-2015, 09:25 AM | #24 |
671
Rep 1,439
Added downpipes weights (OEM, AR Design, Evolution Racwerks) from N54Tuning: http://f80.bimmerpost.com/forums/sho....php?t=1093313
natedog7700667.00 |
02-26-2015, 12:47 PM | #25 |
Rep 2,672
Subscribed.
And I'm curious if someone might attempt to calculate or guess the weight for what I think my track focused build will be. M4, DCT, 19's (to accommodate BBK), Cloth Seats, Carbon Roof, Harmon Kardon (bc I need my music). Then I'm still on the fence on the CCB's. My plan is for this to be my DD for a few years, I then plan to strip it down and do a welded half-cage and one-piece race seats, full harness setup. I'm hoping it will still be street legal at that point for occasional weekend drives but I'll have to check the local regulations to be sure. If that wouldn't be street legal then I think I'd just do a full cage at that point for that added protection and start towing it. |
02-26-2015, 01:11 PM | #26 |
BimmerPost Supporting Vendor
8300
Rep 18,868
Didn't see the Lithium battery listed:
Weight of F80 M3 / F82 M4 Lithium Battery http://f80.bimmerpost.com/forums/sho....php?t=1004967
Tom G. | european auto source (eas)
email: tom@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x22 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
02-27-2015, 10:29 AM | #27 | |
671
Rep 1,439
Oops! I knew you guys weighed that but forget to add it. Thanks and added with EAS noted as source. |
03-01-2015, 10:35 PM | #29 |
Rep 2,672
Thanks, appreciate your dedication here! Will take a look around also for the earlier weigh-ins.
03-02-2015, 01:56 AM | #30 |
8300
Rep 18,868
Stock downpipes vs Evolution Racewerks Catless Downpipes:
03-02-2015, 07:20 AM | #31 |
671
Rep 1,439
03-02-2015, 10:08 AM | #32 |
Rep 2,997
As far as I can tell, without changing functionality, exhaust is the best area in which substantial weight can be shaved while improving other functionality - albeit at cost. I haven't been following too many exhaust threads, but I'm sure a straight-pipe w/ resonator and at least one set of cats would yield a balanced result (though it might sound like crap).
The stock front seats no longer weight alot and replacing them would alter the airbag system. Stock wheels are light. Stock battery is light. Roof, hood, trunk - light. OEM struts - as far as I know on the adaptive suspension at least they are aluminum bodied, and thus I doubt much weight savings are going to be had in the suspension. BMW did an outstanding job SHOWING the enthusiast community just how hard it is to get lighter yet maintain OEM reliability and functionality and a good everyday driving experience. ... Lastly, if someone is truly going with a lightweight model and making some sacrifices, do your thing and then corner weight it. |
03-02-2015, 10:12 AM | #33 | |
671
Rep 1,439
Would be nice if there was a way to offset that in the front. So you could do a muffler delete and then shave weight in the front to keep it to stock weight distro...but I'm skeptical that there is enough weight in the front to shave to offset 20-40lbs or more on a serious exhaust weight savings. |
03-02-2015, 10:57 AM | #34 | |
Rep 2,997
AFAIK, a car with a 52/48 weight bias that is 50 pounds lighter in the rear than a 50/50 weight bias that's 50 pounds heavier....the lighter car is still the superior performer in all respects.
AW/Carbonstructure 6MT 2015 M3 picked up 8/22/2014. Stripper except for adaptive suspension. Weighed at 3,450 pounds with 1/4 fuel. 70,000 miles as of February 2020.
03-02-2015, 11:26 AM | #35 | |
671
Rep 1,439
03-02-2015, 10:56 PM | #36 | |
Enjoying driving
388
Rep 1,169
I admit what I wrote above is utter useless without data, but simple tests can show the difference by just adjusting the rear track width and doing skid pad and straight line testing. The differences will be in the millisecs with those tests, but enough to prove the theory. I personally would prefer to add 50 lbs to the car if I can on the rear axle than take it off, and I believe that is what Swift is trying to do as well with their springs with staggered lowering heights when they release them. |
03-03-2015, 03:35 AM | #37 | |
Rep 321
03-06-2015, 10:14 AM | #38 |
Rep 2,672
I've changed my DD/track build up a bit:
M4, 6MT, 18's, Steel Brakes, Cloth Seats, Carbon Roof, Harmon Kardon Then I'm going to see if I can back calculate the weight from the EAS weigh-in thread and your info. Their M4 specs and weight: 2015 Alpine White M4 Specs 0ZDB Driver Assistance Plus - my guess is no weight penalty 0ZEC Executive Package - ?? 0ZLP Lighting Package - my guess is no weight penalty 02MK M Double-clutch Transmission (DCT) - 89 lbs 02VF Adaptive M Suspension - probably talking ounces on this one 02VZ 19" Black Wheel 437 M Mix Tire - 7.6 lbs Fuel: 1/2 Tank (no driver) - 50 lbs (estimate) Weight: 3579lb Well, I guess I may have to wait until someone else orders a stripper build and weighs it but it looks like I'll be at least less than 3432 lbs w/o fuel (edit: + Harmon Kardon I just realized), not bad! |
04-02-2015, 03:22 PM | #39 |
671
Rep 1,439
Hey guys, I added a bunch of weights today. Thanks to dmk08 for bringing his F80 over to do the KW HAS install I was able to weigh many of the OEM suspension components plus the KW HAS parts and his Macht Schnell spacers and bolts.
I removed my pictures because my bandwidth at Photobucket is getting roasted but if anyone needs them, I am retaining them. |
04-03-2015, 10:46 AM | #40 | |
Rep 3,152
04-03-2015, 10:53 AM | #41 |
Rep 3,251
Not trying to be a hater... But there is almost no point doing all of these works unless you are stripping down the interior and going with a lightweight racing seats (you can probably save a 100lbs just be switching the seats alone, going with a stripped down interior would probably net another 100-300lb saving, but why are doing that to a brand new $80k M3 is the question)...
Most of the weights in any modern BMW are in the sound insulation and stock seats. And unless you racing competitivelyp, it would be just a waste of money. If you want faster times, spend the money on sticker tires and better driving skills instead.
09 BMW E92 335i: Top Mount EFR 7670 / Dinan / AP Racing / Wavetrac / TC Kline [Full Mod List]
07 BMW R1200S: Shine Yellow / Akrapovic / Ohlins 19 Volvo V90 T6: R-Design / Bowers & Wilkins / Polestar Optimization |
04-03-2015, 11:28 AM | #42 | |
Gone Fishin’
7318
Rep 12,125
04-03-2015, 11:30 AM | #43 |
8300
Rep 18,868
Nothing wrong with collecting data. It's great we a reference page as this info will be valuable once the new platforms start becoming more popular on the track.
04-03-2015, 01:24 PM | #44 | |
Rep 3,422
Becoming a better driver, investing in sticky tires, AND weight reduction are all ideal. Maybe it's not going to be possible with this platform without sacrificing too much, but I applaud guys for investigating. I suspect a ~3200# F80 would be a hoot @ the track. |
EGbeater116.50 |
Tags |
curb, f80, reduction, weigh, weight |
