F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > The $89 BMW performance spoiler on my EBII M sport
Extreme Powerhouse
      01-01-2013, 11:42 PM   #23
AMPS
Drives: 2013 328i XDrive
For $89, the spoiler looks great! BTW, does it have the same design as the OEM BMW M Performance trunk spoiler?
      01-02-2013, 12:43 AM   #24
M.Suka
M.Suka's Avatar
Drives: 2013 335i M Sport
Thank you and it is 100% worth the money since it's only a small cosmetic modification, as for how close it is to the OEM spoiler I wouldn't be able to tell you for sure because I have yet to see one in person, but by judging by the pics if have seen on this site it looks like an exact copy.
European delivery 9-19-2012
      01-02-2013, 12:48 AM   #25
AMPS
Sounds great! For those that are interested, the link is posted below.
http://item.mobileweb.ebay.com/viewi...id=59056322498
      01-02-2013, 08:55 AM   #26
jamie335i
Drives: 2013 335i M sport 6MT
Originally Posted by M.Suka View Post
Thanks. Just ordered!
2013 335i M sport 6MT --Sapphire Black Metallic/Black Dakota, premium package, technology package, dynamic handling, black grilles, 5% tint--
      01-02-2013, 06:58 PM   #27
etmathews
WARRIORS come out to play yay!!
etmathews's Avatar
Drives: 2016 F30 340i M Sport
Just ordered! Thanks
2016 340i M Sport/Alpine White/Black Dakota Leather/Ash Wood Trim/ M performance carbon fiber spoiler, M performance grills, M performance front splitter, M performance carbon fiber mirror caps, Llumar ATX Axcess 30% tint
      01-02-2013, 07:17 PM   #28
fastduo
Drives: 2012 335 Melbourne Red Sport/T
Says, red and white may be different. Do you all think black would look good on red?
2012 335I Sport/Tech Melbourne Red
2002 F350 CrewCab Powerstroke Diesel
2012 Chev Cruze LT 2006 Featherlite 3117
HPDE Instructor: PCA, PBOC, NASA, Trackguys, HOD
www.trackweekend.com Asst Administrator
      01-02-2013, 07:46 PM   #29
AMPS
Honestly, I think black goes well with any color. My opinion - Red and black definitely looks great! Our cars comes with black trims and if u have the black side mirrors, the trunk spoiler in black definitely matches the theme. I plan on getting it in black but just have not decided to go ahead with this spoiler or the OEM one.
      01-02-2013, 07:49 PM   #30
AMPS
      01-02-2013, 08:04 PM   #31
etmathews
etmathews's Avatar
They didn't show B39 Mineral Grey Metallic. I hope it works out.
      01-02-2013, 08:19 PM   #32
Seagull
Seagull's Avatar
Drives: F87 M2, E84 X1
How long did your install take? I have to install mine at the underground parking at work :P, so I'm wondering how much earlier I have to get there... LOL
Current: F87 M2 MT MPE, E84 PP SP LP
Previous: F30 - 335i AT, E90 - 335xi MT, E90 - 330i MT, E46 - 330i MT
      01-02-2013, 08:25 PM   #33
AMPS
Fingers crossed. Keep us posted after you receive it.
      01-02-2013, 08:38 PM   #34
etmathews
etmathews's Avatar
Will do
      01-02-2013, 11:06 PM   #35
AMPS
To OP: After the install does the trunk still pop right up or does it just unlock and you have to lift the trunk?
      01-02-2013, 11:57 PM   #36
M.Suka
M.Suka's Avatar
Trunk pops right up, spoiler is super light and is made out of abs plastic not cheap fiberglass and maybe only weighs a pound or two tops.
      01-03-2013, 12:09 AM   #37
AMPS
Thank you very much! You had been very informative and helpful. I think I am sold on this.
      01-03-2013, 12:33 AM   #38
M.Suka
M.Suka's Avatar
Your very welcome, just trying to help my fellow enthusiast out.
      01-03-2013, 01:12 AM   #39
M.Suka
M.Suka's Avatar
Install was about a 10 minute process, first make sure the edge of your trunk is clean and probably is best to wash your car before hand this way the 3M tape can adhere for a day or two before your next wash.
First step I took was cleaning (trunk and spoiler base with alcohol pad) and then testing fit and location, then its a matter of applying the double side tape to the spoiler first and don't worry they supply enough double sided tape to install 2 spoilers (I still had almost half a roll left), when installing tape on spoiler I used my thumbs to force down tape also scissors are critical if you want the job done right, especially on the outside edge of the spoiler I made the cut to kind of flow with the shape of the spoiler at the base on that part.
Then the most tricky part was attaching it to the trunk because you want to make sure both sides of the edge of the spoiler have an even distance from the other edge of the trunk, just a rough estimate there was about a quarter of an inch spacing on both sides.
The process I took was to remove the red plastic from the tape and carefully place it on the trunk itself and then going from left to right and then forward and back until it sits flush and level with the trunk , it will be very tacky just don't force it down until you know you got the spot you want.
Then you will need to apply a bit of force on the spoiler and start pushing down on it but there is no need to push down like your giving CPR (you don't want to put a dent in your trunk) just apply force evenly and hold your hands in place for about 5 seconds at a time moving slowly across the top of the spoiler.
Next step stand back and admire the look of you new car.
Thanks,Mike
      01-03-2013, 01:55 AM   #40
AMPS
First step I took was cleaning (trunk and spoiler base with alcohol pad) and then testing fit and location, then its a matter of applying the double side tape to the spoiler first and don't worry they supply enough double sided tape to install 2 spoilers (I still had almost have a roll left), when installing tape on spoiler I used my thumbs to force down tape also scissors are critical if you want the job done right, especially on the outside edge of the spoiler I made the cut to kind of flow with the shape of the spoiler at the base on that part.
Thanks,Mike
What more can I say.......
      01-03-2013, 03:05 AM   #41
8E88
Drives: 335i '13
Have to say same thing ...Just ordered! Thank you
      01-03-2013, 01:15 PM   #42
diesel86
Drives: 2012 BMW 328i Sportline
Thinking about ordering this as well, but they didn't have 475 Black Sapphire Metallic listed as an available color option.
2012 328i Sportline - Black Sapphire Metallic - 8AT Sport
I pronounce it "Beemer" and turn my fog lights on even when it's not foggy.
      01-03-2013, 02:24 PM   #43
irishbrahmin
irishbrahmin's Avatar
25
Drives: 2021 X5 M50i
diesel86,
On Tues. I ordered 475 Black Sapphire Metallic from the following vendor:
http://cgi.ebay.com/ws/eBayISAPI.dll...m=370725220963
Just indicate the color/code as instructed in the listing.
2021 X5 M50i
      01-03-2013, 02:29 PM   #44
jamie335i
I ordered this one as well in 475 Sapphire Black Metallic
f30post
