07-02-2009, 10:48 AM | #23 |
Where my bitches
784
Rep 1,924
Posts Drives: Cadillac coupe deville Join Date: Mar 2009
max output over component is 720p or 1080i bc of regulations
The probelm is not the component signal. That signal will do 1080p60 without any problems. BUT the licenses governing BD-ROM A/V do NOT allow 1080p outputs on analog connectors. The maximum permissible output resolution is 1080i60. This has nothing to do with the ICT flag btw, so it doesn't matter if ICT=0 or ICT=1.
07-02-2009, 11:34 AM | #24 | |
I am Gundam
193
Rep 1,211
07-02-2009, 11:59 AM | #25 |
G35 convertee
69
Rep 1,008
Because there are no copyright restrictions.
And your 360 is not technically outputting 1080p, because no Xbox360 games support 1080p (only 1080i and 720p). So your TV upscales ('stretches') the image to 1080p. You would hardly notice a difference between the two, because you aren't viewing a native 1080p signal. Your TV is more or less "pretending" to output 1080p.
07-02-2009, 12:51 PM | #26 | |
My car is less than a week old and on its 3rd tank
14
Rep 379
07-02-2009, 01:00 PM | #27 | |
I am Gundam
193
Rep 1,211
07-02-2009, 01:08 PM | #28 |
G35 convertee
69
Rep 1,008
Yes, you are correct, component is capable of providing 1080p (if your specific TV accepts a 1080p signal through component) That's not what I was saying. I'm not even sure what you are trying to say here honestly.. ?
07-02-2009, 02:00 PM | #29 | |
G35 convertee
69
Rep 1,008
support native 1080p. EDIT: I think I stand corrected. Certain games say that they support 1080p, which means that it has the ability to be upscaled to 1080p, if your TV is 1080p capable. So you aren't seeing true 1080p, as I said before. It wouldn't make too much of a difference anyway, unless you are standing pretty close to a large TV.
07-02-2009, 02:09 PM | #30 |
Rep 412
i got a 46" panny plasma 1080p for $950 around christmas. i would definitely tell you to go with a plasma. there so much better than lcd. if you plan on watching sports or action movies or playing games i would definitely stay away from an lcd tv.
no matter what anyone says plasma is still better than lcd. unless your concerned about glare. the motion lag on lcd's is ridiculous. if you had the money i would say go LED cause they look sick but you dont. check out www.highdefforum.com they know there shit and will be much more knowledgeable than any of us. good luck
07-02-2009, 02:23 PM | #31 |
One cam is enough
136
Rep 6,801
+1 on stretching your budget for plasma. Even some of the best LCD's still have issues with blacks and/or greyscale, as mentioned above.
Also, just my personal opinion, but if you're going 42" or larger, I would definitely recommend 1080p (if you have a device that outputs 1080p to the TV of course). |
