04-23-2014, 10:22 AM | #353 |
Rep 1,110
will (18x9 et 31 with 245/40/18 front, 18x10 et 25 with 275/35/18 rear) fit well on stock suspension? thanks
2007 TiAg ///MCoupe
* Dinan strut bars * ZHP knob * RPI scoop * Ultimate Pedals * RE Diablo * 3.91 TMS gears * Apex PS7 * Eventuri intake* Nitto NT05 * TMS pullies * Zeck CDV * RE tranny mounts * Tekarbon * Mstache 2 * '14 Jeep Grand Cherokee Overland Hemi... No more snow for the M! |
04-23-2014, 11:04 AM | #354 |
Rep 5,329
stock e92 m3 18" 260 wheel fitment.
8.5"x18 et 29 front & 9.5 x18 et 23 front fitment is less than ideal, needs significant camber to tuck into the fender ( not an issue with my aggressive track setup) running a 235/40 semi slick and this is as far as i comfortably can go, 245 i tried before hand rubbed significantly ( luckily i only tested static and by getting my GF to turn wheel while stationary so no damage caused) Rear fits perfectly, on semi slick no larger than a 265/35 , anything larger will rub. ill report back after my first track day, i may need to dial I more camber up front as it may still rub with -2.7 i have at the moment, its definitely close. All in all this really works well on an aggressively setup car and looks very nice, the fenders are filled like pamela anderson's Bra.
Z4MR VT2 - Clubsport build.
Multi award winning Detailing | Wrap | PPF specialists UK based - www.topwrapz.com Last edited by Beedub; 04-23-2014 at 01:34 PM.. |
05-07-2014, 10:59 AM | #355 |
"The Midas Touch"
521
Rep 1,055
Drives: F87 LBB ///M2
I'm currently running the following setup
19x9 +30 (245/35/19) - Nitto NT555 19x10 +18 (275/30/19) - Nitto NT555 On Fortune Auto Coilovers (~2" drop and -1.5 Camber (Front)/-3.0 Camber (Rear), fenders are rolled. The rears are fine but the front rubs on the liner pretty bad on the area where the fender liner and bumper connect when turning. Does anyone know if by going to a smaller tire size will help? Maybe a 235/35/19 or should I go lower profile too? Thoughts? Thanks in advance |
05-07-2014, 11:07 AM | #356 | |
Rep 924
Drives: '08 Z4 M Coupé // '09 X5 d
'08 Z4 ///M Coupé (#1765/1815) — 1 of 68 Sepang Bronze / Black Nappa / Madeira Wood / 1 of 1 this combo
19" Advan RS / AP Racing / Bridgestone RE-11 / Autosolutions SSK / R.E. Diablo / R.E. trans mounts '09 X5 35d — Space Grey / Saddle Brown 20" Forgestar F14 / SCR Delete |
05-07-2014, 11:39 AM | #357 | |
"The Midas Touch"
521
Rep 1,055
05-07-2014, 11:43 AM | #358 |
Rep 924
If you don't mind the stretched look and a bit less grip, it's an idea. Personally I would try camber first. Like -2.5 to -3.0
07-18-2014, 05:07 AM | #359 |
Rep 194
my current setup:
Apex Arc-8 Nitto Invo F 18 x 9 ET42 245/40-18 R 18 x 10 ET25 275/35-18 15mm spacers at front. 5mm spacers at rear. Lowered with KW V3. At minimum height it rubbed like hell. Raised it, now rubs little at front only. If I stay at my current wheels setup, which front tire size I should get: 245/35-18 or 255/35-18 or 235/40-18 ? And which rear tire size to match? |
07-21-2014, 04:28 PM | #360 |
Rep 144
I'm currently running stock everything (except a supercharger) and I'm in need of new tires and was hoping to get new rims at the same time. I happened upon the following:
VMR V710 F: 19x9.5 et 22 R: 19x11 et 25 I've gone completely through the "aggressive wheels" thread and this thread and have found that the closest thing anyone has run without rubbing is: F: 18x9.5 et 35 +5mm spacer @(245/40/18) R: 19x10.5 et 25 @(275/30/19) or (285/30/19) I would *LOVE* the extra traction but don't want to mod my fenders, and I would prefer not to use camber plates. I'll use spacers where necessary. What do you guys think? Will they work? Thanks in advance! GT |
07-25-2014, 06:17 PM | #361 |
Rep 23
Fit???
Hi new to the form and bought a 2007 m roadster last week. Looking at some mods ie. wheels exhaust and short shift kit. If anyone wants to sell any of these feel free to contact me.
Can anyone please give me some advise. I have found these wheels and tires and wondering if they will fit 2007 Z4M roadster. Wheel/Rim: Brand OE Replica Wheels Make Alloy Structure One Piece Finish Black / Machined Face Front Size 19x8.5 Offset 35 Rear Size 19x9.5 Offset ET 37 Bolt Pattern 5x120 TIRES Size Front - 235/35/19 Rear- 265/30/19 Size Front - 235/35/19 Rear- 265/30/19 Thanks for any and all advise |
10-20-2014, 06:43 PM | #362 | |
Rep 407
Tire specs: 245/40/18 front (also rubbing) 275/35/18 back For the front, stick to 245/40/18, I stress the 40 so the tire diameter would be equivalent to the back tire. Otherwise it won't be the proper rolling diameter. For the back, 275/35/18 would give you the most performance. I'm not even flush and it's rubbing on hard cornering. And maybe it's just in my head, but it only happens when going downhill. This Wednesday I'ma corner balance it. Hopefully it goes away |
11-07-2014, 04:26 PM | #363 |
Rep 1,110
bump
2007 TiAg ///MCoupe
11-15-2014, 09:31 PM | #364 |
Dog Listener
707
Rep 7,850
I think so. Some have run a 265 front with stock suspension on a 9.5 wheel with 9.5 ET35 wheel with 5M spacer (that's a 30 offset). A 9 ET31 has more 5mm more space to the strut and 7mm more from the fender. YMMD depending on type of tire (square or rounded sidewall) used, camber settings, and so on. Rear is no problem.
Have a look for yourself and do the calculations. Don't count on me only! |
11-18-2014, 02:06 PM | #365 | |
Rep 1,110
2007 TiAg ///MCoupe
11-27-2014, 05:54 PM | #367 |
Rep 1,134
Drives: '07 M Roadster
Those look like they're photoshopped on! lol And the treadwall is so thin, is the rubber just glued to the wheel? Looks pretty sweet!
12-16-2014, 07:12 AM | #370 |
Rep 924
Front works. You'll want a 10-15mm spacer for Rear.
12-16-2014, 07:51 AM | #371 |
braaap
44
Rep 95
12-16-2014, 08:27 AM | #372 |
Rep 924
Not sure about that, but you'll be 12mm closer to it. And it won't look good. If you're conservative, go with a 10-12mm spacer.
12-16-2014, 10:14 AM | #373 | |
Rep 501
245/40/18x9 ET37 (ET42 plus 5mm spacer) -2.7* camber 275/35/18x10 ET25 -2.1* camber Last edited by intoflatlines; 01-13-2015 at 10:27 AM.. |
12-31-2014, 08:31 AM | #374 |
Rep 441
19x11 +17 275/30/19
19x10 +15 235/30/19 No rubbing at all
2007 //M Coupe. BSM. Fabspeed headers. Catless. BMS x-pipe. Strömung cans. evolve tune. Turner CSL airbox. Airrex air suspension with autopilot v2 management.
My Build Thread |
