10-05-2021, 06:54 PM | #34455 | ||
![]() 183
Rep 90
10-05-2021, 07:05 PM | #34456 |
Rep 2,601
Posts Drives: MW Vespa w/pink racing stripes Join Date: Nov 2007
hubbahubba12537.50 fiveohwblow3551.00 IllSic_Design2112.50 RickFLM412125.50 shannon1702.00 Lady Jane89278.50 King Rudi13081.00 |
10-05-2021, 07:42 PM | #34457 |
![]() ![]() 19286
Rep 5,710
Posts Drives: 23 X7 40i; 23 M3; 24 cooper s Join Date: Aug 2019
I'm not a physicist but I'm feeling wild this evening. Let's do this....
Assumptions: - power line height of 4.5 meters - car windshield height of 1.4 meters - goose weight of 6.5 kg - the goose caused a 5cm deep indentation into the windshield We will calculate a couple things: - speed upon impact - force of impact upon windshield V = sqrt(2*g*h) Where: V = velocity at impact g = acceleration (in this case gravity) h = distance (in this case height) So... v = sqrt(2*9.8*3.1) = 7.795 m/s = 17.4 mph Next... F = (m*g*h)/d Where: F = force M = mass G = gravity H = height D = distance (in this case the distance the goose moved the windshield as a result of the impact) So... F = (6.5*9.8*3.1)/0.05 = 3,949 N = 887 lbs Upon further research, the average force required to break a car windshield is 9,400 psi. So what's the lesson here? Absolutely nothing.
2023 BMW X7 xDrive40i
2023 BMW M3 6MT 2024 Mini Cooper S Convertible '20 BMW m340i... '20 BMW X5 40i... '16 Infiniti Q50 RS 400... '10 Lexus RX 350... '08 Lexus IS 350... '00 Nissan Maxima... '93 Nissan Maxima |
9
10-05-2021, 07:50 PM | #34458 |
![]() 15568
Rep 3,493
10-05-2021, 08:13 PM | #34459 | |
![]() ![]() 10063
Rep 4,150
2025 Lexus GX 550 Overtrail
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 ![]() |
10-05-2021, 09:29 PM | #34460 |
Spaceship Man Bad
![]() 1655
Rep 251
17
Murf99314023.00 shannon1702.00 fiveohwblow3551.00 Samurai of 2day2344.00 Marmugmotleocay1808.00 Lucky John613.00 Buug95925895.00 Lady Jane89278.50 King Rudi13081.00 jesm216.00 DieselDiner507.00 Mirko228.50 vreihen1623946.00 hubbahubba12537.50 leopard print1578.50 Suds1669.00 terryd5150503.00 |
10-05-2021, 09:34 PM | #34462 | |
![]() 14023
Rep 1,336
Posts Drives: Porsche 993 Join Date: Mar 2020
10-05-2021, 09:40 PM | #34463 | ||
Rep 2,601
10-05-2021, 09:46 PM | #34464 |
![]() ![]() 10063
Rep 4,150
Bird would need to grounded somehow so don’t see how a flying goose could be electrocuted…. Not to mention the associated,burns. Unless the bird broke its neck and fell. Might need another drink to consider this!
1974 2002tii, Inka, 5 sp manual BMWCCA # 327475 ![]() Last edited by kscarrol; 10-05-2021 at 09:55 PM.. |
10-05-2021, 10:43 PM | #34465 |
![]() ![]() 4272
Rep 1,689
We will use the Impulse/Momentum Theorem. F
⋅∆𝑡=𝑚(𝑣𝑓−𝑣𝑖 ![]() ⋅ ∆ t = m ( v f − v i ) Let us assume that the bird is traveling head on to the car at a speed of +12m/s=Vi. Let us assume the bird has a mass m=0.5kg Lets us assume the bird after impact(the impulse) is now traveling (at least for a moment) -28m/s(-60mph)=Vf. In the opposite direction it was going. Let us assume that the time during impulse is ∆t=0.010s. Then the average force is F=0.5kg(-28m/s-12m/s)/(0.01s)=2,000Newtons. Most birds that would hit a windshield would be less than .5kg. Most impacts would not result in an opposite velocity vector i.e it would bounce off the windshield at an oblique angle. If the last two sentences applied the force would be less. If the time of impulse is less or the initial velocity of the bird is greater then the force increases. 2,000 N distributed over an area of impact of say 100cm 2 2 would result in 20N per sq. cm. about two kilograms of weight pressing on every sq. cm of glass. I do not believe that is enough to shatter the windshield. However, I do believe that the numbers I assumed are not unreasonable for the typical bird that might hit a car. The number that is highly suspect is my impact time, it could be less than that. The poster can play with a greater mass or a greater initial velocity or a lesser time to increase the average force. Remember, this is just the average force there is actually a greater peak force occurring at the mid-time of impact. That is harder to determine without more measurements. Assume the peak force is 4000 N. What I could find on the pressure to break a windshield was anywhere from 4000–16000 N/cm^2 and that depends on how long the pressure is applied to the glass. Under the conditions I assumed I do not believe the windshield would shatter. You would need a bigger and faster bird to get a shattered windshield. |
10-06-2021, 03:22 AM | #34466 |
![]() 28644
Rep 1,713
Posts Drives: 2022 X3 M40i, 1983 911SC Join Date: Jan 2021
10-06-2021, 04:58 AM | #34467 |
![]() 14023
Rep 1,336
10-06-2021, 05:03 AM | #34468 | |
![]() 14023
Rep 1,336
From Wiki: The male Canada goose usually weighs 2.6–6.5 kg (5.7–14.3 lb), averaging amongst all subspecies 3.9 kg (8.6 lb). The female looks virtually identical, but is slightly lighter at 2.4–5.5 kg (5.3–12.1 lb), averaging amongst all subspecies 3.6 kg (7.9 lb), and generally 10% smaller in linear dimensions than the male counterparts |
10-06-2021, 05:47 AM | #34469 |
Cailín gan eagla.
![]() 89279
Rep 1,083
15
RickFLM412125.50 DieselOG1654.50 Murf99314023.00 JJ 911SC28643.50 vreihen1623946.00 No one1167.00 Samurai of 2day2344.00 Joe2402933.50 fiveohwblow3551.00 BMWGUYinCO4476.00 hubbahubba12537.50 3.0L13799.00 Marmugmotleocay1808.00 shannon1702.00 terryd5150503.00 |
10-06-2021, 06:25 AM | #34470 |
![]() 17384
Rep 2,103
Posts Drives: 2022 X6///M Comp Join Date: Aug 2015
Can't help but think about that WKRP episode.
I thought I was a good person but the way I react when people drive slowly in the left lane would suggest otherwise
10-06-2021, 06:48 AM | #34471 |
![]() 13081
Rep 1,965
The short video clip of this is hilarious. Ole boy on the left eyeballing Snoop as he puffs away, then Snoop offers it to the officer, the officer semi-declines, Snoop persists aggressively, then the officer goes to town on it. I mean, how do you tell Snoop no and how to do you pass up the opportunity to smoke with him?
shoei7748.00 IllSic_Design2112.50 |
10-06-2021, 07:09 AM | #34472 | |
![]() 14023
Rep 1,336
10-06-2021, 07:28 AM | #34473 |
![]() 507
Rep 1,614
zi
JJ 911SC28643.50 wtwo319285.50 vreihen1623946.00 Dpc2u11288.00 Samurai of 2day2344.00 BMWGUYinCO4476.00 DieselOG1654.50 shannon1702.00 |
10-06-2021, 07:58 AM | #34474 | |
![]() 13081
Rep 1,965
Power line height you have listed as 4.5 meters, yet the NECs industry standard minimum for attachment points on a telephone pole is 18 feet on line lengths up to 20 feet. Roughly 5' variance, not much, but considering the weight of the Canada Goose, this will greatly impact velocity. Also another point of consideration is random heights of power lines. Although industry standards are set, they are rarely often adhered to. Also, pole height and attachment clearance regulation vary depending on the location of the pole itself. Thus creating an undeterminable height from whence the creature fell, also thus making velocity inconclusive, which pretty much destroys all calculations after. Also, car windshield height that you have listed seems accurate; the grade (downward slope/angle) of said windshield needs to be accounted for as well. The grade of the windshield will also effect displacement of force upon impact. You have calculated the goose created a 5cm (= >2") impression in the windshield, I would imagine that this figure is conservative at best based off the photo. Next in order to accurately calculate velocity, the distance is extremely important and without knowing the exact distance or point of origin of acceleration, it is difficult to determine whether or not this creature reached terminal velocity. Also further considerations must include drag coefficient, projected area and mass of the falling object; but it looks like you covered this in force. I was about to go down the gambit of info in order to attempt to calculate what I could from this, but there simply isn't enough data. I will reverse engineer the shit out of this so stand back. ![]() if a windshield has a tensile strength of 9,400 psi this would equate to 64810718.5 N/m˛. This raises a plethora of questions for me now that can not be answered based solely off the picture. 1.) At what speed was the vehicle traversing during impact, 2.) What was the internal temperature and external temperature of the windshield, 3.) At what trajectory or angle did this impact take place and finally, what hue of brown/consistency of mass was the excrement removed from the operators underpants post impact. |
wtwo319285.50 |
