06-21-2010, 09:49 AM | #199 | |
Rep 2,014
BTW, Awesome Build! |
06-21-2010, 11:36 AM | #200 |
Rep 2
sweet ride! thats one hot car
"WHY?" should you care about State Farm's new website? Because monkeys with infrared sensors will hurt you if you don't (long story, just check the site): whyagent.com
*FYI, I'm helping spread this link around for State Farm |
06-22-2010, 03:25 PM | #201 |
Rep 10,587
new CHRA being installed
Adam getting all hot and bothered testing how well the new CHRA spins. Its MUCH MUCH smoother, easier, and quieter than the old one I traded in. Put a little oil inside before doing this but regardless.....I can only imagine how fast this is spinning when the engine is breathing in it.
06-23-2010, 05:37 PM | #202 |
Rep 1,603
Posts Drives: Imola Red Z4MC Join Date: Apr 2010
awesome thread! subscribed
btw i dont know what happened to your old 335 but this e36 is definitely an upgrade!!! Its a classic for sure!
///M - Some Mods 'N Stuff
06-23-2010, 08:01 PM | #203 | |
Rep 10,587
thanks!!! and I agree the smiles this car gives me the 335 could not hope to touch. didnt have the same....soul. didnt
06-29-2010, 11:24 PM | #205 |
Rep 10,587
I got around to installing the underpanel i picked up from motion motorsports a few weeks ago.
pretty easy install. On the TT stg II I had a few hangups w this underpanel but overall install was a success. packaging was good, parts were all there and looked/felt like high quality/strong parts and the panel, its a thick yet light cut of aluminum that is very rigid.....precision cut and drilled. The before under shot of my car some of the newest hardware to finds it way on the car new chargepiping w Tial BOV by MA motorsports here in Baltimore, bunch of good guys there TRM exhaust crank case check valve......has worked great so far! My helpers holding the underpanel in place after removing the factory craptastic plastic porkchop things.......this underpanel fit perfect w the OEM front bumper and lip. I was very happy to find that all my charge piping and the BOV cleared the panel and didnt require any triming. HOWEVER the charge piping kept me from installing the 2 large brackets which give this underpanel even more strength. After speaking with Matt at Motion I decided to go ahead and install it anyway, it turned out to be really rigid even without those supports. It ties into the fender liners and really helps solidify their positioning much better. I'm happy with the product. you can see from the photos that if anything this underpanel increases ground clearance by getting rid of the pork chop thingies. I am hoping this will help a bit with my cooling issues and plan on adding baffling and weather stripping to seal it up more forcing more air into the radiator. the drive home however didnt really reveal anything, other than 2nd gear is a hoot for drifting and the new CHRA is butter smooth :evil2
06-30-2010, 06:22 AM | #207 | |
Rep 10,587
hint: dont take pics of a girl with it if you want to any later.
06-30-2010, 09:20 AM | #208 |
Rep 2,014
06-30-2010, 02:10 PM | #209 |
Rep 10,587
bingo, thats what I do for a living so thats a perfect example
07-03-2010, 11:49 AM | #210 |
Rep 1,781
Sick sick sick project.
I am very jealous. Any chance you can put up a few videos of the car? I'd love to hear it ideling/accelerating. Thanks.
Current F95 X5M; E60 M5 6spd; Mclaren 570s; Aston Martin Vantage; Ferrari FF
07-06-2010, 10:46 AM | #211 | |
Rep 10,587
once this heat spell leaves ill be happy to 10am today amd 97 degrees.....F THAT
02-23-2011, 05:41 PM | #212 | |
Rep 10,587
I found the issue thats been plaguing me for the past year, my ceramic Magnaflow cat was crushed on the outside causing the ceramic catalyst to splinter into many pieces ruining its flow ability. Chocked the engine out up top as you will see from dyno graphs I'll post in a bit. F cats!!! ============== after removing the cat the car ran like a champ. Low boost on the wastegate spring pulled smooth and just built HP to redline. High boost pulled harder but didnt have the same fierce pull at higher RPMs. You'll see why. ====================== Always wanted a few pics of my car from the outside, now that it seems to be running happy I wanted to give it a shot. Videos dont represent the volume of the exhaust, its a bit louder than these videos would lead you to believe. ================ at MIR today for a great drag racing rental. Took a break during a 30 minute cleanup session on the track to make some videos on the service road. sorry tires......ive been nice until now. watch in 720p Burnout Flyby.....I angered the dogs Attempted launch and what the exhaust looks like
02-23-2011, 05:44 PM | #213 |
Rep 10,587
Ok so I finally got dyno proof that my car is indeed running much much better since removing that stupid clogged cat.
cp-e in Beltsville has an amazing facility full of top notch robotic machinery and rapid prototype machines to churn out top notch parts for BMW's, Mazda's, and others. They also have a $100k Mustang dyno with the most ridiculous fan setup ive ever seen.......video's and photos cant do these fans justic. They deliver honest 65mph winds with extremely similar volume of air to the open road. Photos from yesterday evening Finally strapped down, an process that took almost an hour and a half. Reason for that is at the bottom of this post. Time for action ================================================== ==================================== Here is my low boost dyno from before at MaxPsi. and from today this is on cpe's awesome Mustang Dyno, I have some great pics of their facility but cant get my 16gig sd card to read on my gf's older laptop for reference, a stock 335 will dyno around 220-230 whp from what I was told. Typical dynojet for the same car will be 270-280whp. dyno operator was very impressed w the power on low boost on this dyno. car was at 347whp on low boost. For reference a modded GTR hit 382awhp on the same dyno. I believe the car has ~400whp on higher boost on this dyno in it with the current setup. Not sure what that will mean on a dynojet. It will be quick though, only weight 3195lbs w a 3/4 tank of gas. please note runs were done til he hit the rev limiter......rpm scaling was off. and video of the run and higher boost before at MaxPsi.......a terrible looking dyno chart even after NIckG pulled out all the timing in the trouble zone. and today. Dips up top and then follows the low boost graph. Dyno operator who is also a tuner for cpe said it looks like timing is heavily reduced up top even before I told him NickG did that. Hope thats the case and all power will be back once ECU is reflashed w a standard map. so much better than before. Need to play with boost controller to keep boost up in higher rpms....dropping almost 1.5psi throughout the rev band. the 35r at this psi should have NO problems with keeping boost steady or even slightly growing to redline. low and high on same graph video of high boost all in all a good dyno evening though we did snap my vband clamp off the mid pipe getting it on the dyno.....a new clamp and 2x4's solved that issue lol. car sounded mean as hell with an open exhaust though. Will pull the ECU and send to NickG tomorrow
03-08-2011, 01:58 AM | #214 |
Rep 2
Wow. Incredible stuff!!
03-08-2011, 01:12 PM | #215 |
Rep 1,603
Nice updates! Love this thread and the "red dragon" !
03-09-2011, 07:21 PM | #216 |
Rep 10,587
got the ECU back w the proper tune and the car rips to redline, feels great! will get on a dyno in the next week or so I hope. Pulled the turbo off the car (what a PITA) to have the exhaust housing gasket matched. Probably wont make any difference at all but who knows. also relocated the Aquamist flow control to have a shorter run to the injector
03-13-2011, 07:31 PM | #218 |
Rep 10,587
Hey all
I've started putting more time into detailing cars recently, just have too much fun with it not to do it more. I was working on my car yesterday afternoon. the front end of the car was resprayed 2 summers ago when I hit a damned deer. Since then the orange peel left by body shop has been a thorn in my side. NO MORE! I finally decided to wetsand the peel out and polish. Anyone living in the Maryland area feel free to shoot me a PM if you have any interest in detailing services from maintenance washes to full paint correction wish I had brought my good camera for this, but the EVO4g actually does pretty good. --------------------------------------------------- A reflection on my hood when I started, you can see it simply not a crisp, clear reflection. damned orange peel Test section after wetsanding. Wiped clean and dried to see what the sanding has done. Orange peel still evident on the outside of my sanding area. Fully sanded down, smooth, no peel Buffed the 2000 grit sanding marks out w M105, 2 passes and got this much much better!!! I was so excited to see this result side by side Now the real work begins. Entire hood and front fenders need the same treatment Sanded down, did some more touch up sanding after this photo 1/4 polished w M105 me hard at work, what a workout. I need an orbital. Flex will be on order soon I think. Hood polished out w M105 Fender sanded Fender polished Then repolished w a finer polish to really bring out the depth and clarity followed up w 2 coats of JetSeal applied w black pad. gave 20 minutes for each coat to cure, spent that time detailing the interior. Test pot of Dodo Juice, love this stuff. So easy to apply and remove, depth is incredible and beading it fantastic. Done! Now thats some clarity baby!! (actually a bit out of focus, thanks phone) outside in the evening light, so good. Washed the rest of the car. Will polish to get rid of RIDS after 2 years of washing since last polish then give it the seal/wax.
