      04-20-2006, 05:20 AM   #23
Daytona_John
Daytona_John's Avatar
Drives: 2022 BMW X3M
Originally Posted by cntlaw
IWC watches are more exclusive and most well known are those made of titanium. I have been wearing a Porshce Design Ocean Model Automatic made by IWC for over 10 years. (As you might know, IWC no longer makes watches for Porsche Design) Whenever I go for heavy sports I will wear my IWC Ocean. I also dived in the Great barrier reef with it. It has never failed me. It is not a watch that most of the time you leave it to a draw. The major difference of a Rolex and a IWC Titanium, is the IWC is much lighter and therefore more resistance to vibrations. If I go for a IWC watch other than a titanium one, I will also consider Frank Muller's.
Below are photos I took of the latest CLS IWC AMG shows where my dream watches are the IWC AMG models.
Nice watch - just keep in mind the titanium case construction won't really help shock protection. Shock protection is more a function of how well movement is designed to withstand vibration (like hitting a golf ball for example). The material used in the case construction doesn't really impact vibration in the movement one way or the other significantly.
      04-20-2006, 06:53 AM   #24
cntlaw
cntlaw's Avatar
Hong Kong
238
Drives: 330i E90 C55 AMG
agreed. i should have referred a lighter weight watch makes great comfort when wearing for sports than heavy rolex.
BMW 2006 330i E90 Jet Black/Black Leathers/Aluminium, Steptronic Active Steering; MTech Aero Kit Carbon Fibre Splitters/Diffuser. Bilstein PSS9 Coilover, Rays VOLK Racing RE30 Formula Limited Edition 18" Pirelli Rosso; Project Mu 355mm Forged 4pot Caliper. HID:Osram D1S 6000K, PIAA 6500K White Ring, Philips Diamond Vision HB4 5000K, PIAA H490/H491 Super Bright 6500K LED Interior Lights. Chrome S.Wheel Cover, Rear Windows Sunshades.
      04-20-2006, 10:29 AM   #25
Daytona_John
Originally Posted by ScBlacksunshine
G.O. Panomatic--- under 7k in house movement
Zenith Chronomaster GT--- in house movement also under or around 7k
Jaeger LaCoultre Dualmatic/Master Calendar...etc--- In house movement
IWC FA jones edition (Steel version)--- in house movement around 7k depending on dealer.
Blancpain--- almost in house movement
I mean I can go on with the list, but looking at your name I don't need to be a genius to figure out you prefer Rolex, and that's defintely your choice, but all the above listed movement is just as good if not better then the Rolex Movement (EL Primero movement uses Column wheel) but like once said "Whatever float your boat" Just like there will always be people that prefer buying Louis Vuitton bag over anything else and swear the quality is perfect..
Are we talking about personal preference or objective superiority? Sure Rolex is my choice, but I recognize that Rolex doesn't make the best watch in the world.
I challenged you to list a watch that retails for 7k with an in house movement that's superior to the Daytona's 4130. You have a list of watches in the price range, but fail to demonstrate in any way why the're superior.
Let's take your first choice for example - The Zenith Chronomaster GT. The El Primero movement in this watch has remained essentially unchanged since about 1962. Rolex used the El Primero as the base caliber, modifiying the design substantially to create the Rolex caliber 4030. In 2000, Rolex introduced the Caliber 4130 at Basel in 2000. So the 4130 in the Daytona is at least 2 design generations ahead of the El Primero in the Chronomaster GT. So why do you feel it's superior? The 4130 has a host of Rolex's newest technology inovations, such as their new hairspring, the "Parachrom Bleu". This new Rolex-patented hairspring is very easy to recognise as the spring has a very dark blue shiny color. It consists of an alloy made of Niob (most part), Hafnium and a very small ammount other metals not described. This blue color is created because the Niob oxidizes in contact with air and formes a protective layer this way.
In comparison to the regular hairsprings (like what would be found in the El Primero), this new one consists of only non-Ferro materials, and is as such completely unsensitive to magnetic fields. Another major advantage is that this new spring is much less sensitive to temperature-variations, the frequency does not vary due to differences in temperature, which results into one of the most accurate mechanical watches you can buy today.
I could go on and on about the new technology (I suppose using the word "new" in reference to mechanical watch technology is relative at best) but you get the point.
      04-20-2006, 11:07 AM   #26
ScBlacksunshine
YUGO is my dream car
ScBlacksunshine's Avatar
148
Drives: Bayerische Motoren Werke
OK dude, looking at your credential I am sure you know more about watches then I do... Difference between a professional vs Hobbist I guess.. Anyway, you must feel the need to defend Rolex since you replied to my last post twice..even though I never said Daytona wasn't a nice watch, my point was for 7k (once again if you can even get a Daytona at that price) you can get in house manufacturer movement watches with just as good of fit,finish and accuracy as a Rolex with better styling and more exclusivity. I mean, if you want accuracy, buy a quartz watch and it'll be much more precise. Not denying the Rolex movement is good with all the technical inovation thrown in it and I am sure it'll be a durable watch, but at 7k I was presenting the original poster something else to think about rather then just another "Rolex". Anyway, to prevent dragging this out any longer and to make you happy. I would like to say that for 7k Rolex Daytona is the best you can get, it's technically superior, looks better, smells better, probably taste better and it has nothing to do with the fact that the name "Rolex" has anything to do with it. Also to sum it up, any ETA movements are like a POS Chevy Cavalier
      04-20-2006, 11:09 AM   #27
cosmosblau
cunning, baffling, powerful
cosmosblau's Avatar
19
Drives: '08 BMW 535i
2006 325i  [0.00]
Yea, pull the other one and it plays jingle bells....
A Daytona is a COSC certified chronometer....in order to pass, the watch must peform at a tollerance of no more than +6 to -4 seconds per day. If your "friend's" Daytona had been sent to Rolex for service (something that should be done about every 5 years for any mechanical timepiece) then it would be regulated back to within COSC specs.
If you're truly trying to suggest that a stock ETA movement is superior to a Rolex movement....well, that's like suggesting a Chevy Cavalier engine will out perform the BMW M5.
Who would ever expect someone named "Daytona John" to be so defensive about Rolex Daytonas!
....I don't begrudge your opinion.. we all have to justify our expensive habits in some way.
I don't think that my "friend" (are your quotes to imply he really isn't my friend, or that he doesn't exist?) waits five years to send it back to Rolex; he sends it back because it sucks ass. He has easily sent it back 3 times in five years. I really don't know why he bothers; if I had his money, I'd have a hundred nice watches.- And I do consider Rolex a nice watch, but purely from a jewelry standpoint.
P.S.- A COSC certification costs manufacturers less than eight dollars per movement.
2013 328i Alpine White Black Leather Sport Line Premium Pkg SprintBooster
      04-20-2006, 12:41 PM   #28
Daytona_John
Well, I'm not defending the Daytona so much as I'm defending misinformation. Unless your "friend" operates a jackhammer for a living, there's no way the watch is "several minutes off per day" if it's been sent to Rolex for service.
Your mistaken in your cost of COSC certification - the true cost varies by manufacturer, and depends on the volume of testing the manufactuer does with COSC. Rolex no doubt pays less per test than anyone, as they are COSC's biggest customer. Of course, it has little bearing on our dicussion...I just pointed it out to demonstrate that a watch coming from Rolex (either new or serviced) should hold these tollerances. "Several minutes off per day" just doesn't sound plausible. Sorry.
      04-20-2006, 01:27 PM   #29
Daytona_John
Actually, I "lost" my first reply - I didn't think it posted...when in fact it had. That's OK, because I was time limited on that first reply, and didn't add the depth that wanted - which I rectified in the 2nd post.
Now...back to the issue at hand - your backtracking.
Here's what you just said above:
...my point was for 7k (once again if you can even get a Daytona at that price) you can get in house manufacturer movement watches with just as good of fit,finish and accuracy as a Rolex with better styling and more exclusivity.
This differs substatially from what you said in previous posts:
I know for sure there are better value out there with better movement (which was your first point of argument)
It looks to me like you're backpeddling and changing what you said because you realize your original position isn't very defensible. Which tells me your opinion is based on personal bias and less on facts. Rolex is the 800 lb. gorilla in the watch industry which makes them an easy target for the uninformed for unwarranted criticism. Much in the same way that many will say "BMWs aren't worth the money...yada, yada."
Now, you're welcome to your opinion about BMW...or Rolex for that matter. I'm always interested in hearing if people can back up their opinion with objective facts (and educate me and perhaps influence my opinion) or if they're just blowing smoke.
      04-20-2006, 01:47 PM   #30
ScBlacksunshine
148
Ok..I think you miss the point I am trying to make and no I am not backpeddling.. I never said Rolex suck at making their own movement, in fact on my original post I said Rolex Daytona is a good choice, but like I said many many times for 7k you can buy something just as good. Are you telling me all the watches I listed won't last as long, and don't have the same workmanship and finish as the Rolex, or won't keep time just as good (and if you want technical comparison, then go on Timezone.com and ask around on GO/Omega/JLC forum, perhaps someone can give you the precise data you're looking for?) If the answer is no to the above questions, then there's better choice...btw, even though you listed Daytona technical features before, that still doesn't make it a superior choice to what I listed. Buying a luxury watch is subjective, most people buying it is buying it for the "SOUL" just like people buying BMW/MBNZ...etc, so at the end of the day it is all about opinions and that's what this forum is about. Anyway, if it makes you feel better AGAIN....Rolex is the best, Daytona is the end all and be all watches with the best movement in the industry and Rolex is the 800lbs or 1000lbs gorilla of the watch industry....
P.S. Don't bother to reply to my posting anymore, at this point a simple agree to disagree is good enough..and for the record you won the argument and you can walk away feeling good about wearing your ROLEX
**To the original poster, good luck with your IWC 3706, are you getting the bracelet or leather? Btw, the bracelet has the best adjustment design ever**
      04-20-2006, 02:39 PM   #31
Daytona_John
If I missed your point, it's because you keep changing the point it is your trying to make. I'd be happy to agree to disagree however. They are just watches after all...we're not talking world peace or anything.
Now, care to explain/defend why the IWC 3706 has the "best adjustment design ever" ?
However, I've done reviews from all the manufacturers you named. I REALLY like JLC personally...I wouldn't mind owning one some day in fact.
      04-22-2006, 09:59 AM   #32
8t
Singapore
12
Drives: E90 - 320
guys,
thanks for all good advices and the insight to the world of watches.
i got the IWC this weekend.
well i must say the IWC makes the Rolex looks very machine , and the IWC is a piece fine craftsmanship, so much more refine. , these are my Observation from just looking at the 2 watch. movements wise i don't know much, i am still learning how to appreciate them.
and yes i saw the G.O. Panomatic - it is art & Engineering in its highest form. (well maybe next time)
for now i happy with both SD & Spitfire.
attached are the photos of my Rolex SD & IWC spitfie.
thanks again for the feedback & reply
cheers
      04-22-2006, 10:17 AM   #33
cosmosblau
cosmosblau's Avatar
19
2006 325i  [0.00]
Excellent choice!
      04-22-2006, 01:14 PM   #34
ScBlacksunshine
148
Very nice
      04-22-2006, 01:24 PM   #35
mava330
mava330's Avatar
Drives: '07 M Coupe
2006 BMW 330i  [0.00]
2005 Honda S2000  [6.00]
CONGRATS 8t!!! Wear it in good health!
2007 ///M Coupe Sapphire Black / Black // Extended Nappa Leather // Premium Pckge // Heated Seats // Navigation
RETIRED
2006 330 TiAg / Black
2005 S2000 Silverstone / Red/Black
      04-22-2006, 05:20 PM   #36
Daytona_John
Originally Posted by 8t
guys,
cheers
Congratulations. Your assesment is understandable - the Sea-Dweller is designed to be a tough, rugged tool watch - in most respects (except perhaps the white gold hands and markers) the watch is very utilitarian. That Spitfire sure does look nice!
      04-23-2006, 08:16 AM   #37
SteveMD
SteveMD's Avatar
201
Drives: 2016 F10 535i MSport
I have a Panerai (164). I guess I need to get my camera. I didn't buy a Rolex because everyone will think its a replica. Nobody I have shown my PAM to has even heard of Panerai.
Here's a pic from the official site:
2006 E90 330i (retired)
2009 E90 335i (retired)
2012 E70 X5 50i M Sport (retired)
2016 F10 535i M Sport
      04-23-2006, 10:22 AM   #38
8t
Singapore
12
Drives: E90 - 320
John,
To be fair and honest, the above statements is true about the rolex SD, when I wanted to get a watch then, my criteria was to get a watch is that build like a tank, hold its value, sports model, not as common as the explorer and SM, and get a taste of high-end stuff (well to what I know the SD is the 2nd highest of the rolex sports range). Well I couldn’t find anything better than the rolex SD. It was the best fit for what I wanted and it’s my 1st expensive watch brought with my own money.
Thanks for reminding me.
Yes the rolex SD is a super utilitarian & hardy watch to have daily.
I just wish I could wear both watches at the same time, I love both of them.
Thanks again for sharing.
      04-23-2006, 10:29 AM   #39
8t
Singapore
12
Drives: E90 - 320
thanks for the well wishes.....you too take care & be happy.
cheers
      04-23-2006, 10:30 AM   #40
8t
Singapore
12
Drives: E90 - 320
Excellent choice!
thanks for the advice along the way too......take care.
cheers
      08-03-2009, 10:08 PM   #41
boostedtwin
Sheriff
boostedtwin's Avatar
111
Drives: spyder, Macan GTS, 4xe Rubicon
07 335i  [0.00]
07 335i  [0.00]
IWC's are so nice. I got two.
IWC Ingenieur Chrono SS Automatic
IWC 2000 Automatic Titanium
BTW, the first one is for sale. If interested, send me a PM. Brand new conditions. Just looking to make some changes on my collection.
2023 Porsche Spyder, 2024 Porsche Macan GTS, 4Xe Rubicon & 2021 BMW X5 M Package
