10-29-2024, 08:01 PM | #1 |
Rep 73
Learn something new everyday! Top Tier Gas
I poke around car forums quite a bit and have seen many debates about octane and gas, usually about trying to save money using 87 octane. In my Z4 s30, it is 90 or better, which usually means 91. I thought that was enough to be doing right by my engine.
Although I had seen it mentioned a couple of times over the years, I just learned that Top Tier Gas is a thing, and it sounds like using it makes a difference. A number of articles came out recently about an AAA study and showed just how much less carbon build up there was in engines that used Top Tier Gas. Now that I know where to look and the symbol to look for, much more Top Tier Gas in is my future. Is the idea of using Top Tier Gas (vs just using the proper octane gas) well-known? As someone who enjoys cars, travel, and learning, I was genuinely surprised that I had not known about this standard before. |
10-29-2024, 08:27 PM | #3 |
Rep 344
Posts Drives: 2015 BMW 535i M Sport Join Date: Feb 2022
Full Disclosure - I only became aware about 3 years ago when I got my "new-to-me" bimmer and started looking into it. Before then, I ignorantly believed it was a myth and filled my tank with whatever was convienent (and usually cheap).
10-29-2024, 09:30 PM | #5 |
Rep 2,474
Top tier gas just has extra cleaners than the minimum required by federal law. It's mainly a marketing gimmick, where you run the test everyone passes, and then pay the licensing fee.
You're not gonna get anything out of it more than you would by adding a bottle of techron or other PEA based cleaner in a tank once a year. You'll get no benefit from it in a Direct Injection motor. |
ctcarbonari447.00 |
Yesterday, 05:39 AM | #6 |
Rep 367
Ugh! Only 4 threads down and 17 pages.
https://g87.bimmerpost.com/forums/sh....php?t=1571574 |
Westside Guy7101.50 |
Yesterday, 08:59 AM | #7 |
Rep 1,207
BP fell off last year.
Wait until you find out what LL-04, A40, MB228 is.
2015 Sakhir/Sonoma (first one totalled) 2nd one MHD and BM3, Eventuri, Mosselman, NICECNC, MAD FAT BOY DP, "Valvetronic Designs" single mid, PAGID RSC1, Hotchkis/GTMore, Vorschlag, Bilstein B16/10.
Soon Powerflex diff brace, Akropovic axle back for sale. |
DrFerry6788.50 ///M Power-Belgium69678.00 |
Yesterday, 09:48 AM | #8 |
Rep 6,580
Posts Drives: 2018 340i M Sport Join Date: Apr 2006
Garage List 2018 BMW 340i M Sport [8.78]
2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [7.38] 2006 BMW 330i Sport [5.83] 2004 BMW 330i ZHP [7.13] 2000 BMW 328i [6.17] |
Around these parts Top Tier gas is pretty well known and often cussed and discussed. Even here there are still a few yahoos who believe it’s a myth.
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
Yesterday, 10:20 AM | #9 | |
Rep 1,491
As for Top Tier fuel I refer you to your car's owners manual. A paste from my M2's owners manual: The use of poor-quality fuels may result in harmful engine deposits or damage. Additionally, problems relating to drivability, starting and stalling, especially under certain environmental conditions such as high ambient temperature and high altitude, may occur. If drivability problems are encountered, we recommend switching to a high quality gasoline brand and a higher octane grade — AKI number — for a few tank fills. To avoid harmful engine deposits, it is highly recommended to purchase gasoline from Top Tier retailers. Failure to comply with these recommendations may result in the need for additional maintenance. |
DanG11404.50 |
Yesterday, 10:34 AM | #10 | |
Rep 1,491
https://www.getbmwparts.com/oem-part...ve-83195a07750 By my SA I was told the use of that additive was recommended by the factory. I also note both my 230s and my M2 are direct injection engines. (I don't wish to get into an argument but my info is Techron at least can benefit a DI engine.) At any rate I have used the BMW fuel additive or what I prefer is I decline the BMW additive and pick up a bottle of Techron from the local auto parts store. |
Yesterday, 11:13 AM | #11 | |
Rep 7,130
Posts Drives: 2018 M2 AW DCT Join Date: Aug 2012
BMWCCA member Puget Sound Chapter
Yesterday, 11:26 AM | #12 |
Rep 2,474
In a DI motor the fuel is injected directly into the combustion chamber when needed. It doesn't have any time to do any cleaning unless it somehow survives the combustion event.
In port I jected motors the fuel is injected in the head, so it flows over the valves and cleans them of any carbon buildup. That where top tier gas or an additove can help. |
Yesterday, 11:30 AM | #13 |
Rep 2,034
Refer to BMW SI B13 02 06 - https://static.nhtsa.gov/odi/tsbs/20...52346-9999.pdf
I've known about this for many years, but filling up on the NYS Thruway this weekend, and it was the first time I noticed the Top Tier sticker on the pump: |
Yesterday, 12:51 PM | #14 |
Rep 4,174
Shell Master Race
///M Power-Belgium69678.00 jdl506843.50 |
Yesterday, 09:36 PM | #15 |
Rep 71
This right here, I am in a position that handles all the big company products and when you see which ones accept the specs of the gasolines as a base and then still spec them up you know. Shell is the highest level to start right out of the gate without even adding before the tankers are sent out to the stations.
