10-27-2024, 10:02 AM | #1 |
Rep 1
Dsc and yellow BRAKE E46 325ci
Hey, so I recently purchased an e46 325Ci as my first car. In Norway this type of car is a scarce model. I importer mine from USA and it’s currently at 120K km. I am wondering why may cause the fault?
(Code 5D8C) can this be lateral acceleration sensor under the driver seat? I have noticed it’s a bit moist there, so maybe it got wet and stopped working? Thx for answering |
10-27-2024, 12:07 PM | #2 |
Rep 392
There appear to be a few YouTube videos where the module under the drivers seat or its connector have caused that error code, along with a few others. Check its connector and pins for corrosion, clean with contact cleaner, dry and reconnect, then clear codes and see if it returns.
I'd also put a fan on the wet area to dry it and figure out where the moisture is coming from. Perhaps a blocked sunroof drain, or faulty door seal.
Carbon Black - Debadged|Mocha Nappa|DHP|DAP|Premium Pkg|Luxury Seating|M668 w/ DSW06+
KarolisE460.00 |
