      09-19-2024, 04:38 PM   #1
M-technik-3
Drives: E30 M3, E36 M3, 328iT, 335i
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
Valvoline Restore and Protect Anyone try it yet
I have not seen it on the shelves yet and want to try it in my moderate mileage N52. Hoping to get rid of some sludge and so forth.
      09-19-2024, 05:25 PM   #2
2000cs
Drives: Potato
YT channel The Motor Oil Geek recently had a video about top tier gasoline being better for oil life (because of how it differently affects rings); and has several on oil analyses and comparisons. The core advice from many seems to be oil and filter changes every 5k miles or shorter. Doesn’t matter what vehicle, manufacturer or engine.
      09-19-2024, 05:28 PM   #3
2000cs
Drives: Potato
      09-19-2024, 05:56 PM   #4
Buug959
Buug959's Avatar
Ukraine
21767
Drives: 335xi E90, GMC Sierra, VW Golf
2000cs3784.00
Maynard4109.50
      09-19-2024, 06:17 PM   #5
This sounds like a question better asked in the "topic" sections of this forum.....
      09-19-2024, 06:48 PM   #6
M-technik-3
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
I put here because I know at some point it will go off the rails.
      09-19-2024, 08:14 PM   #7
dradernh
dradernh's Avatar
4820
Drives: 2017 M240i
Is sludge at all likely in modern BMW engines?
That is, without extreme neglect, PCV system issues, or something like coolant getting into the oil without it becoming evident.
I've not thought about sludge as a possibility in many decades.
2017 M240i: 25.9K, 28.9 mpg, MT, Sunroof Delete, 3,432#, EB, Leather, Driving Assistance Package, Heated Front Seats | Sold: E12 530i, E24 M635CSi, E39 520i, E30 325is, E36 M3 (2)
TC Kline Coilovers; H&R Front Bar; Wavetrac; Al Subframe Bushings; 18X9/9½ ARC-8s; 255/35-18 PS4S (4); Dinan Elite V2 & CAI; MPerf Orange BBK; Schroth Quick Fit Pro; Full PPF
      09-19-2024, 09:30 PM   #8
iminhell1
C2H5OH
iminhell1's Avatar
Drives: 2010 SG 135i auto
Because it's a nonissue.
If I can watch hands full of videos about vehicles going 40,000 or more miles with no oil change or top off at all then it should be clearly obvious that if you stick to a reasonable oil change interval that you will have no sludge issues.
Hell the vast majority of people thinking the latest and greatest will save their POS will never keep it long enough to prove anything. Come talk to me when you've put 200,000, 300,000, 500,000 miles on the car.
      09-20-2024, 10:04 AM   #9
2000cs
Drives: Potato
Sludge: watch a few of the tear down videos of any engine on YT I Do Cars. Many suffer from sludge and wear that is apparently caused or exacerbated by extensive oil change intervals. Lots of sludge in engines these days, and lots of heat with the turbos in wide use.
Also a lot of valve carbon buildup (stems) because of DI not providing any cleaning on the manifold side of the intake. That same DI can wash down the cylinders, leading to ring and oil failures.
My take away is modern engines with their heat, DI, and tight tolerances need good oil and frequent changes. My personal opinion is most are designed for a service life of 100k miles (with factory recommended oil change intervals of 10k-20k miles), but this can be extended greatly by using good oil, oil filters and frequent changes.
Buug95921766.50
DrVenture1084.00
      09-20-2024, 10:22 AM   #10
freakystyly
Drives: F22 B58 6MT
N52s are port injected so the carbon buildup on valves aren't an issue.
You could peek inside the oil fill cap to see the top of the valve cover but it likely will be a nice oily brown color. Like you said, sludge is primarily from skipping oil changes.
2000cs3784.00
      09-20-2024, 11:54 AM   #11
M-technik-3
1995 M3  [9.00]
2007 E91  [7.25]
1988 M3  [9.50]
I'm third owner and have owned for last 60K so it gets maintenance now but prior not sure records were about non existent.
I'm going to try it for one or two oil changes figure it can't hurt and easier to do this then an oill flush followed by doing two more oil changes to remove the flush agent.
      09-20-2024, 03:29 PM   #12
2000cs
Drives: Potato
The first video linked above includes rationale for not doing a flush of oil; your approach is preferred by that presenter.
      09-20-2024, 03:35 PM   #13
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
If you don't mind running an oil at LL01fe levels of hths. You likely have nothing to remove.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      09-21-2024, 08:58 AM   #14
Maynard
Drives: 228iX & M2C
Thanks for sharing this. It makes me very glad I have tried to keep to TopTier whenever possible. The info in this video was new to me and I'm surprised at how much of a potential difference the gasoline makes.
2000cs3784.00
Buug95921766.50
      Yesterday, 09:42 PM   #15
m3_kb
m3_kb's Avatar
Drives: 2008 BMW M3
I’ve alwyas used Liquimoly but it’s definitely interesting to see and hear what other companies offer
