09-30-2024, 09:32 AM | #7525 |
Rep 11,893
Posts Drives: MY24 G01 AW Msport Join Date: Feb 2008
any recommendations on good brand for shotgun-semi auto with mag setup
under $1k |
09-30-2024, 01:25 PM | #7526 |
Rep 112
My CS set up like yours. I have the Holsun EPS carry with green dot. I will 21 you when clear.
Sedan_Clan26739.50 |
09-30-2024, 01:29 PM | #7527 |
Law Enforcer
26740
Rep 22,650
Posts Drives: '22 Chalk Gray Porsche C2S Join Date: Jun 2006
09-30-2024, 03:47 PM | #7528 |
Rep 112
Yes they do!
10-01-2024, 04:53 PM | #7529 |
Rep 234
Posts Drives: 2022 BMW M340i Join Date: Apr 2007
Got a Staccato P today.
Tomorrow the new law is going to be signed into effect here in MA, so I wanted one last hurrah... It was this or the DWX...
2022 M340i XDrive, Oxide Grey Metallic/Tacora Red/Shadowline. 2004 330Ci (Sold), 2007 335i (Sold).. |
Yesterday, 09:14 AM | #7531 |
Rep 1,258
Posts Drives: 04 z4 3.0 Sport & 15 X5 35i XD Join Date: Aug 2013
superlative arms adjustable gas block
Put one of these on my latest 223 Wylde build last month on a recommend from a friend and it worked well, so last weekend I got another one and put it on my "Gas Master 3000" AKA my 6mm ARC thermal coyote build that was gassy BEFORE I put a whisper pickle on it......now it's basically a face painter.
These have a full closed setting, a standard adjustable setting, a wide open setting, and a vent setting so instead of just blocking how much is sent thru the gas tube and leaving the rest in the system - it takes what it needs and then vents the rest into the atmosphere. I wound up being able to set it to full vent with zero malfunctions, so I clicked it back in 3 clicks and called it good. One shot used to coat the next 3 rounds in the mag pretty well, but as you can see this helped that significantly. Surprisingly it shifted my point of aim to the right about 6 inches, but that was easy to correct. FYI - If anyone was like me and never heard of them - worth a check out if you need an adjustable gas block.
2015 X5 XDrive 35i - 2004 Z4 3.0 Sport
