09-09-2024, 01:05 PM | #1 |
Rep 2
Need help with paint repair for my 320i
Hello,
Today while parking my car in reverse there was a very short bollard that I didn't see and I slighly hit the back of my g20. The damage appears to be hopefully only on the surface-level on the paint and ceramic coating. What do you suggest me to do? Would some polishing compound like this Meguiar ultimate compound do the trick or? Thanks so much |
09-09-2024, 03:46 PM | #2 |
Rep 2,353
Paint looks cracked, to me & bumper cover dented. Judicious application of heat might help the dent but could further affect the paint. Will probably need a fix & respray.
tcphoto3970.00 |
09-10-2024, 12:47 PM | #4 |
Rep 56
As said, the cracked paint means rubbing, filling and a blast of paint. Heat gun would only really help if the shape had gone. Would be amazed it was more than a few hundred in a body shop to put right.
If you could get a rattle can match you could probably even do a decent job yourself. Bit of wet and dry to flatten, pictures are hard to see if there is a dent, light coat of body filler if there is, rub down and paint, area looks small so you would hardly notice a decent attempt unless you were to point it out 👍🏼 |
