      07-03-2020, 08:16 AM   #1
Yossi123
Drives: 330xi G21
Wet spot on the floor after washing the car
Today I accidentally discovered that after washing the car using pressure-washer there is a wet spot on the floor under the carpet, on the passenger side. It was small but really soaking wet. I marked the spot on the attached picture. Everything else was dry, no trace of water whatsoever. The water must have come from under the plastic trim. I was really careful with the lance, keeping the distance etc. I will report it to the dealer of course. Anyone with a similar issue?
      07-03-2020, 08:58 AM   #2
SCardamon
SCardamon's Avatar
Drives: 2019 330i
Ouch ~ I would dry it up then test each drainage point on the roof and windshield
      07-03-2020, 09:32 AM   #3
themnmd
themnmd's Avatar
Drives: 23 X5MC
I use pressure washer have had no issues
      07-05-2020, 02:11 PM   #4
Yossi123
Drives: 330xi G21
Ok, I did some tests before I book the visit at the dealership.
Water is appearing inside the cabin only when spraying around passenger door edges (low pressure, from the distance). The water starts flowing with smal stream after approx 5 sec. It is coming from under the rubber seal exactly at the spot marked by the arrow.
Honestly I don't know how much I should be worried - I assume water is somewhere under the trim, where it is not supposed to be. Let's see what the dealer says.
Or maybe there are some critical spots that I can check by myself? To my untrained eye all the rubber seals are perfectly fine. Any advice where to look and what to check?
      08-01-2020, 04:25 AM   #5
firetitanx
firetitanx's Avatar
102
Drives: BMW 330i M Sport 2020(G20)
I just use a hose and I do notice there is quite a bit of water on the inside of the doors so I always open the doors and dry it out after I wash the car bir never had a wet carpet although now you mention it I better check 👍
      08-02-2020, 04:04 AM   #6
Yossi123
Drives: 330xi G21
In my case it was factory damaged seal on this big plastic piece inside the door (the one that has the speaker and everything else attached to it). The bottom seal was broken and the water that was getting inside the door was not being directed into drainage point and instead was leaking from under the door.
      07-25-2022, 07:57 PM   #7
Alekz35
Drives: BMW M340i 2020
I am currently having the same issue with my 2020 G20 model. Carpets were really wet after pressure wash. I took this in the dealer and its currently there now. what did they do to fix it? I am worried about mold being in the old carpet, did they replace the whole floor interior?
      07-26-2022, 11:36 AM   #8
Yossi123
Drives: 330xi G21
They've replaced the whole big plastic piece that is inside the door. The seal on the bottom edge that was broken is it's integral part. See my attachment (pic is not mine, found on this forum)
And for the floor carpet they simply allowed it to dry completely, but the leak was not that severe, it wasn't completely soaked, just a spot next to the door.
      07-26-2022, 06:54 PM   #9
Alekz35
Okay yeah what I figured, seen many others with that seal damaged. Dealership just called me back today and said there was no water leakage on my car after a wash so no repair needed (which I think is false) because I swear my carpets were alot more wet than yours in the picture you posted hours after a wash. I am unsure how the dealer missed this. I am hoping this part can be replaced myself, But I feel this is something BMW messed up from factory so they should be the ones fixing this. Idk man thanks for the help.
      08-11-2024, 01:32 PM   #10
jonezyl
jonezyl's Avatar
Drives: bmw 330E
Its rained the whole night (12hrs) and my car is soaked!
      08-13-2024, 04:04 AM   #11
scubajim
scubajim's Avatar
50
Drives: 16 BMW 435 F33 S2 / 03 BMW 540
The same thing happened to my son's car shortly after he bought it used from Arizona. The back seat foot wells would be full of water. He had a warranty, so we took it to the dealer, and they resealed the film behind the door cards on the rear doors. The problem has not reoccurred. I can't recall the name of the sealant. Its thick and sticky stuff.
Butyl..I think
      09-03-2024, 04:12 AM   #12
andymatt1
Ireland
16
Drives: 2020 45e MSport
45e - Sunroof Drip seal end bits - HELP
so the leaking sunroof saga continues .. it seems that the inner channel on the sunroof runs directly into where the mic is, so after investigation I'm replacing the seal.
My question is though, there are 2 little 'spongey bits at the end of the seal, pictured here. Has anyone any idea of the part number for those little guys?
New drip seal BMW - 54107493149
