07-31-2024, 06:00 PM | #1 |
Rep 5,112
Posts Drives: 2022 Z4 M40i, 2021 228i GC Join Date: Sep 2021
Are there any issues mounting a spoiler on PPF
Are there any issues mounting a spoiler on PPF?
I have ceramic coating on top of the PPF and already know that it will need to be buffed or polished off in the area that the trunk spoiler attaches prior to installing the spoiler. After I remove the ceramic coating I am wondering if there will be any issues using 3M double sided tape and mounting the spoiler on the PPF? |
07-31-2024, 06:17 PM | #2 |
Rep 2,377
Posts Drives: 2020 BMW M4 CS Join Date: Jun 2023
I just had a similar conversation with the PPF guy I'm using Monday. I just finished rebuilding the front carbon splitter on my M4 and it will have 12mm double tape where it mounts to the body plus hardware and I'm also adding nylon rub blocks on the bottom so I don't have to do this again.
Bottom line we mapped out the area's that would get PPF and not be under any of the adhesives. IMO I would have your PPF installer install the spoiler as cutting applied PPF is not for the faint of heart and it's possible you may have reapply the PPF to the trunk again after the spoiler is installed. Good luck Last edited by Car-Addicted; 08-01-2024 at 08:20 AM.. |
Westside Guy6995.50 |
08-01-2024, 04:48 PM | #3 | |
Rep 5,112
08-01-2024, 06:01 PM | #4 |
Rep 749
Is this a serious question? Come on...
Would you glue a shelf to wallpaper on your wall and expect it to stay? Let alone a functional attachment that is impacted by force! Remove the PPF and do the spoiler right and then reapply PPF! What's the problem? You wanna play, you gotta PAY! Lol |
tcphoto4046.50 |
08-02-2024, 07:00 AM | #5 | |
Rep 5,112
08-02-2024, 10:13 AM | #6 |
Rep 4,174
There's also a question of the adhesive actually adhering to the PPF. I can't say if it will or will not, but keep it in mind. Even with the ceramic buffed off, the PPF itself might inherently resist being stuck to. Any surface that water beads on tends to be resistant to adhesives.
08-02-2024, 10:08 PM | #7 |
Rep 354
It’s not going to adhere properly to PPF. Remove the PPF from the trunk first and have it reapplied. It won’t cost that much.
Westside Guy6995.50 pegogetem236.00 |
08-03-2024, 06:32 AM | #8 |
Rep 372
My installer removed the spoiler before installing PPF in the trunk. PPF on the spoiler as well. Been almost 2 years and no issues with the spoiler on top of PPF.
2018 MB E400 Coupe
2023 M340i X drive (Mineral White Metallic, Oyster Vernasca Leather, DAPP, Shadowline, PAP, Premium, Cooling & High Perf Tire, Adap M Susp, HK, Drive Recorder, Sensatec Dash) |
Westside Guy6995.50 tracer bullet3603.00 |
08-03-2024, 09:18 AM | #9 |
Rep 2,042
Posts Drives: 2013 E92 M3 Join Date: Jul 2015
08-03-2024, 04:53 PM | #10 |
Rep 5,112
Yes, I live in a condominium which only has outdoors parking and we have to pull into the spot headfirst. My space is partially covered and the rear third is not protected.
My parking space faces directly south and I’m located right next to the intercoastal waterway and a short distance to the Atlantic Ocean. My car is subjected to intense sun all day long, frequent heavy rains and salt air. The bottom line is I need all the protection I can get which is why I have PPF and ceramic coating. 👍🏻 |
08-03-2024, 08:16 PM | #11 | |
Rep 354
There is no debate that any adhesive is going to stick better to well prepped paint than it will to PPF which is designed to be a non stick surface for easier cleaning. |
08-06-2024, 05:36 PM | #12 |
Rep 329
cozye572.00 Westside Guy6995.50 |
08-06-2024, 06:47 PM | #13 |
Rep 4,367
I had my M Performance rear spoiler mounted on on top of PPF for 7 years with no issues. Surface prep is important. Make sure any coating is removed from the area of the PPF you plan to stick on, and use 3M adhesive primer.
If you cut the PPF, the cut edges will collect dirt and look unsightly after a while. So, if you plan to cut, make sure you cut a smaller area so the spoiler covers the cut hole. |
08-06-2024, 10:54 PM | #14 |
Rep 69
UPSROD1034.00 |
