04-10-2021, 04:44 PM | #67 |
Rep 1,353
I think i start figuring out stuff better today. So i purchased the front radar on Ebay, after making some research realized that the sensor i bought is FRR-02 instead of FRR-01. F series and early G series uses FRR-01 sensor. This sensor is FRS. With the new G series they upgraded to FRSF which is long distance radar. And that also change the VO from 5AT to 5AU. So i am planning to use the FRR-02 on my F85 to see how it works comparing to FRR-01.
As far as other modules goes, they are also same on the G series. This is just like the E series High Beam Asist Sensor. I retrofited mine with the Gen2 which responds alot quicker and better than the old gen1 version.
E93 M3 6MT , Nav, Prem, Cold Weather, Sports package, & CA, RGBW DTM with RGB Demons + Eisenmann Race + BE + ARP + Brembo GT 380s, $3AG, $5AC, $508, $6NF, $601
Please "Appreciate" If you like my post! DIYs : OEM Camera Retrofit, FLA Retrofit , Drive Shaft Ticking , Starting Issue, , F85 ACC Retrofit |
04-10-2021, 05:25 PM | #68 | |
Rep 1,179
Drives: 2014 X5 50i M Sport, M3(sold)
It will be awesome if we're able to use newer hardware on ours. Good luck! |
04-10-2021, 08:27 PM | #69 |
Rep 1,353
there is always something new coming up. Someone pays the price and hopefully shares with the community so we can all take advantage of endless bmw retrofits.
04-23-2021, 07:07 AM | #70 |
Rep 1,547
Drives: '22 Tesla MY + '23 Tesla MY
Purchased the front radar sensor sensor on Ebay. Will need to wait for a bit to get the 8 pin plug and bracket from Europe, along with some other stuff I needed for my Webasto retrofit
| '22 Tesla Model Y P - My daily | '23 Tesla Model Y LR - Wife's daily | '17 F15 35D - missed daily |
04-23-2021, 03:42 PM | #71 |
Rep 189
04-28-2021, 01:38 PM | #72 | |
Rep 1,547
SaNGRia996.50 |
04-29-2021, 12:37 AM | #73 |
Rep 85
Pin no 3 - S-CAN H - KAFAS module - 12pin black A56*1B pin no 3
Pin no 6 - S-CAN L - KAFAS module - 12pin black A56*1B pin no 4 Are you sure you have picked the right plug? In my notes it says it should be 12 pin black plug. |
04-29-2021, 08:04 AM | #74 | |
Rep 1,547
https://f15.bimmerpost.com/forums/sh...4&postcount=65
05-19-2021, 08:33 PM | #75 |
Rep 5
ACC and TJA Retrofit
Hello all, appreciate the help and great discussion above. I am looking to retrofit a BMW x6 2016 f16 with adaptive cruise control-- ACC and Traffic Jam Assist-- TJA.
I have Parking Assistant (confirmed it can park, turn wheel stop and go) which reduces the amount of parts required for this from what I can determine to -- ACC: 1. ACC sensor + bracket 2. Front bumper grill for ACC 3. Buttons on the steering wheel I have questions regarding the wiring. Do I need the front wiring harness? 61129355472 --> Is this correct for X6 F16? Or does my current PDC front wiring harness suffice and I simply plug the ACC sensor once installed into the existing front wiring harness constructing an 8pin (ACC side) to 12 Pin (Wiring Harness side)? Where would I buy wiring for the fuse box and control unit? "Wiring for connecting the ACC radar in the process of pinning?" Of course steering wheel buttons need to be applied. TJA: Quidzel or Steering wheel harness and touch control module/sensor. I cannot find the touch module sensor and would appreciate any support on this to be able to do either option. Thank you. Last edited by Wekma; 05-19-2021 at 11:24 PM.. Reason: Adding |
05-19-2021, 09:48 PM | #76 | |
Rep 1,547
https://f15.bimmerpost.com/forums/fo...play.php?f=509
05-20-2021, 02:11 AM | #77 |
Rep 85
I have been doing all harnesses by myself, so can't help with factory ones.
Touch sensor is built into steering wheel, so it is not available as separate item. You need to replace whole steering wheel. Alternatively you can only buy a 3rd party emulator faking that you keep hands on the steering wheel. Personally I wouldn't do it. |
10-21-2022, 01:46 PM | #78 |
Rep 172
I need to replace the ACC sensor on my car. I found a used one that I want to buy. What is needed to program and calibrate the new sensor?
02-19-2023, 01:21 PM | #80 |
Rep 1
Hello Guys,
Am looking forward to doing an ACC DIY installation on my bmw F15. I’ve already bought the radar, wiring stuffs and the additional buttons for the steering wheel. Am wondering whether i’ll need a new DSC or ICM cause the car already have cruise control, park assist and collision assist with braking intervention. Please, anyone here to help me out. Thanks |
04-24-2023, 04:59 PM | #82 |
Rep 93
When you install a replacement (Used) DSC in the F-series, do you need to code the VIN number or unlock it somehow?
I see the E-series requires VIN unlock on the DSC replacement but I'm not finding anyone who has mentioned this on F-series. Of course I can apply standard coding through E-sys but I'm hoping I don't need a tool to change the VIN since the E-series tools won't work on an F15 |
04-24-2023, 11:49 PM | #83 | |
Rep 70
If you Injected CAFD and VO code DSC, esys will write short VIN in DSC.
If you flash DSC, esys will write Long VIN in DSC. Quote:
04-25-2023, 01:18 PM | #84 |
Rep 85
I don't recall needing to code VIN in DSC in my F15. For sure I had to do it in ICM. But for sure I was using only E-sys. Retrofitted ACC works perfectly. VIN was an issue for sure when retrofitting Night Vision. I had to add a box changing VIN in the fly.
04-25-2023, 02:32 PM | #85 | |
Rep 93
Thanks to you and maaii11 for the feedback. Last edited by jfandl; 04-27-2023 at 08:51 AM.. |
04-26-2024, 10:15 AM | #86 |
Rep 652
Drives: 2018 F48 X1 xDrive 18D
Can anyone provide me with a SVT.xml and a .NCD with this radar equipped?
CAFD identification would also help pretty much |
05-02-2024, 10:34 AM | #88 | |
Rep 652
But SaNGRia can probably confirm |
Tags |
acc retrofit |
