10-24-2023, 07:45 PM | #23 |
Rep 1,974
Posts Drives: Here and There Join Date: Jul 2013
Garage List (2)11 BMW E90M Stri ... [10.00]
(1)11 BMW E90M Stri ... [10.00] 98 Lexus LS400 [10.00] 16 Toyota Land Cruiser [10.00] 97 Toyota Land Cruiser [8.33] |
sygazelle13264.50 |
10-24-2023, 08:02 PM | #24 | |
Rep 1,974
Llarry21455.00 |
10-24-2023, 08:09 PM | #25 |
Rep 1,003
spazzyfry1235011.00 |
10-24-2023, 08:58 PM | #26 |
Rep 387
Posts Drives: GMC Denali Join Date: Feb 2021
As promised ... a few pictures to try to show the light produced by various lights in my shop.
First: The two 60w bulbs in the door opener's light (Note: the camera did a longer exposure due to the lack of light) Second: Two 4-bulb banks of fluorescent lights Third: Five of the 35,000 lumen UFO lights Last edited by dscabra; 10-24-2023 at 10:17 PM.. |
10-24-2023, 10:27 PM | #27 | |
Rep 1,974
10-25-2023, 07:25 AM | #28 |
Rep 98
This is what I was trying to describe:
10-25-2023, 08:08 AM | #29 |
Not willing to take advice
4599
Rep 1,575
That's how I have it set - with the lights running between the doors. Every now and then, you get some nice summer evenings where you need lighting and want the doors open.
One thing I did add, I have a few lights on motion detection...so if I need to walk into the garage in the dark (to get a tool or something) - some lights automatically kick on. No need to flip a switch if I'm just in and out. There's not much more to the cost in adding one or two of these. Will state, I've been considering the honeycomb for the back part of the garage as I want something more flush. Little pricey for what it is, haven't pushed the purchase button, but was considering. I'd need to paint the ceiling black to make it stand out, just not sure if I want to go through all the work.
Proud owner of 4 Turbos and 1 Supercharger
10-25-2023, 09:26 AM | #30 |
Rep 414
Just to chime in, I have 8 4-ft led lights in my 3-car, and it's extremely well lit everywhere. I absolutely love it and recommend erring on the overkill side - led lighting is cheap both up front and for use. I went parallel to the cars with 6 of them (for aesthetics) and then I have 2 perpendicular to those to illumate the deeper section of the 2-car portion of my garage (which you don't have), where I have a work bench and cabinets. Even with the garage doors open blocking essentially 3 of my lights, there is perfect lighting. I don't think I've ever had the doors open at night and been working on the 'dark side' near the garage doors, though. You could probably get away with 6 lights with your foot print if you wanted to.
10-25-2023, 10:30 AM | #31 | ||
Rep 1,974
Nice!
10-25-2023, 11:28 AM | #32 |
Rep 313
I have my 8 ft LED lights mounted high on the walls around the perimeter of my shop.
That and the side mount garage door openers, which have been mentioned previously, are much quieter and unobtrusive. |
10-25-2023, 02:51 PM | #33 | |
Rep 414
To make it more clear, here is basically what I would propose in your space. This is with the assumption that at the top of the image, those are working areas - not sure what C/S refers to. I also like what your builder? suggested and is hardcoded into the schematic, but I would add one additional perpendicular to those for the little enclave at the bottom. Such a design makes it easier and aesthetically cleaner to daisy chain them if cords will be visible on drywall (which is the case for my setup). I made the look cleaner with something like this. Last edited by Reborn_; 10-25-2023 at 02:56 PM.. |
10-25-2023, 04:31 PM | #34 | |
Rep 1,974
C/S is for Ceiling Supply (HVAC). That wall separates the garage from a small portion of the interior living space. What you're seeing is a sliver of the interior of the home the garage is attached to. I daisy-chained in my last garage as I had a single receptacle that I added many LED lights to throughout the space using similar cable management you linked. In this case, the 4' LED lights I have selected will be run in series to a single switch, but have their own respective receptacle. |
Reborn_305.50 |
10-25-2023, 04:55 PM | #35 |
OG
362
Rep 481
If you like; Im a Elec Eng who specializes in lighting. I can help if you like. Show you how to tinker around with light levels, etc…Personally I have been specifying the Columbia CSL’s in 8’ for lots of mechanical/electrical spaces..Very bright and switchable lumen tech..
I like the idea of 4 rows of 8 footers running paralleled to cars.. How tall is your ceiling btw? |
Reborn_305.50 spazzyfry1235011.00 |
10-25-2023, 07:46 PM | #36 |
Rep 1,633
My garage is a 26x24 and I have 8 8' LED twins and 4 4' twins. They were free when I was doing construction.
10-30-2023, 03:58 PM | #37 | |
Rep 1,974
