SUPPORT ZPOST BY DOING YOUR TIRERACK SHOPPING FROM THIS BANNER, THANKS! |
06-25-2020, 10:01 AM | #552 | |
Rep 26
Take away points are - Take tires into consideration - Higher offset = safer (in general) - Rubbing on outer fender? Adding camber or choose a narrower tire
Gruppem RAM / Stromung Back Boxes / Vibra 360m EM / Rogue TM / Leather-Z Center Console / Stubby / CDV / Rockford Fosgate Sound + Panasonic MVH-S512B/ Clutch Stop / 3m Crystalline Tint
06-25-2020, 10:20 AM | #553 |
Rep 160
Found this recommendation from Apex (Apex E85/E86 Z4M Fitment Guide)
Front: 18x9" ET30 or ET31 with 255/35-18 tires Rear: 18x10" ET25 with 275/35-18 tires Unfortunately they did not have any pictures of this exact setup, I searched through all of the pages with no luck. Is anyone running this setup? If so would you post photos showing fitment and share alignment settings? Thanks in advance |
couchflyer112.00 |
05-23-2021, 06:58 PM | #555 |
Rep 27
Ok read through all 26 pages of this thread now & it’s a great help. I’m getting new wheels in the post tomorrow & they’re:
19x8.5 et 35 19x10 et 22 To be put on a Z4MC. I can see on here some have run very similar setups, so I know they’ll work but I’m now looking at tyres and not quite sure what to go for? I plan to lower the car 10mm rear & 20mm front but don’t want to be messing about with rolling the fenders to avoid rubbing. Any experts about to help? I’m thinking at the moment to run 235/35 on the fronts, as this increases ride height 5mm so allows me to lower the 20mm. Hoping this won’t look stretched? 245/35 seems to be the general consensus but worried the extra diameter will mean rubbing? On the rears I’m stuck between going 265/35 or 275/30? Leaning towards the 265/35, because I’m thinking the extra 5 between the 30 & 35 will be the difference between being crashy and bone shattering to moderately comfortable. Am I right in thinking this? Use the car as a daily so don’t want to ruin my experience in it. Thanks in advance for any help/insight anyone’s able to give. Last edited by Mos6689; 05-23-2021 at 06:59 PM.. Reason: Spelling error |
05-23-2021, 11:23 PM | #556 | |
Rep 2,882
Drives: Anything
05-24-2021, 03:57 AM | #557 |
Rep 27
Thanks for your advice Xmetal. This throws my understanding off a bit now. Bare with me here.
I may well be wrong but this is how I was calculating it: So OEM setup is: 18x8 225/40 RD (rolling dia) 637.2mm fronts 18x9 255/40 RD 661.2mm rears OEM difference fronts to rears + 24mm Stock they’re both running 40 and the rears are wider. So there’s a difference front to rear in the rolling diameters from stock. So I was looking to get as close to the difference between the rolling diameters from stock as possible. Back to my initial thoughts on sizes, I did take RD into consideration and here’s stats on them: 19x8.5 235/35 RD 647.1mm fronts 19x10 265/35 RD 668.1mm rears Difference fronts to rears +21mm What you’re suggesting: 19x8.5 235/35 RD 647.1mm fronts 19x10 265/30 RD 641.6mm rears Difference fronts to rears - 5.5mm OR 19x8.5 245/35 RD 654.1mm fronts 19x10 275/30 RD 647.6mm rears Difference front to rears -6.5mm Are you saying it’s better to have the RD front and rear as close to eachother as possible? If so, what benefit does this offer from OEM setup? I understood changing the difference in RD from front to rear is what would throw up problems like speedo error at +\- 2.5% & possibly the ABS/traction faultering. Be interested to hear what you and others think of this with the numbers. In parts of Europe (Germany for example) it’s illegal to have a speedo difference of +\- 2% when changing wheels. Also RD must be within a certain tolerance of OEM which only allows you a specific set of tyre sizes to choose from. Thought it was good practice to follow this but I’ve only recently got my head around all of this wheel jargon. Always just bought a set of rims and chucked them on without a second thought. Only matching PCD & nothing else. So I may well be wrong in my thought process. Last edited by Mos6689; 05-24-2021 at 04:04 AM.. Reason: Adding to |
05-24-2021, 05:41 AM | #558 |
Rep 27
Just been pointed out to me that fronts aren’t 225/40/18 OEM. They’re 225/45/18. Assumed because my car is low mileage and on 224’s it was all stock. FML back to the maths board!
FWIW in light of the OEM size being wrong, I can understand your suggestions now even before going to the drawing board! |
05-24-2021, 06:35 AM | #559 |
Rep 27
Just worked it out again based on the ACTUAL front OEM tyres. Basically only have 2 choices really:
Stock is 225/45 fronts RD 659.7mm 255/40 rears RD 661.2mm Difference of +1.5mm front to rear CHOICE 1 235/40 fronts RD 670.6mm - Arch gap decrease by 11mm. Speedo -1.6% 265/35 rears RD 668.1mm - Arch gap decrease by 7mm. Speedo -1% Difference of -2.5mm RD CHOICE 2 245/35 fronts RD 654.1mm - Arch gap increase by 5.6mm. Speedo +0.9% 275/30 rears RD 647.6mm - Arch gap increase by 13.5mm. Speedo +2.1% Difference of -6.5mm RD My main reason for wanting to lower is purely to get rid of the crap rear springs the car comes with. No one does like for like replacements & the closest to stock is eibach -10mm rear & -20mm front. Prefer the specs on choice 1. Closest to OEM spec but concerned the decrease in the arch gap, between tyre & fender, is going to be a problem when I lower it? |
05-24-2021, 06:38 AM | #560 |
Rep 208
Drives: 08 Z4 M Coupe
Just reinforcing what Xmetal posted about going up in tire sizes. 235 fronts should have 265 rears. 245 fronts should have 275 rears.
Unfortunately for 19's on the rear there isn't a way to not mess with rolling diameter compared to stock. But keep in mind BMW also over-reports your speed from the factory. On stock wheels an indicated 80mph is actually 77. Almost all OEMs do this because the EU has legislation against under-reporting speed.
'08 Z4M Coupe | Space Grey/Imola Red Extended/Carbon Leather | Eventuri Intake | Strömung Exhaust | Strong Strut Front/Rear Braces | 19" E46 M3 ZCP Wheels
08-20-2021, 04:47 PM | #561 | |
Rep 701
For a 19" wheel on our cars a 245/35/19 on the front is a big mistake if you are using 275/30/19 on the rear. And as you know you cannot use a taller 35 profile tire in the rear to even it out because it will rub. A front 245/35/19 will fit, but apart from just looking weird, the car won't ever sit right. Your front tires will be 6.5mm/0.26" higher than the rears. A 235/35/19 for the fronts would have been a better match.
Nitron NTR R3 | StopTech Trophy Sport STR-60 380x32mm / StopTech Trophy Sport STR-40 355x32mm | Bridgestone RE-71RS | ADV.1 | CDV Delete | TMS Rear Camber Arms | RE Diablo's | 4.10 Gears | Euro Headers | RTD REVO1 Short Shifter
04-25-2022, 10:29 PM | #562 |
Rep 50
Reading through this thread, it SEEMS like I will be ok, but didn't find anyone else running exactly what I have planned. There are 26 pages to this...whew.
1. Track car with occasional street driving. I got what I thought was a good deal on 2 sets of used Apex ARC-8. The rears are going to rub (18x10 ET25 285/30). I'm also concerned about the front. The wheels I bought are 18x9" in the front with ET30. However, the ARC-8 wheels don't clear the stupid F&F Brembo brakes that came on the car. Using washers to test, I would need an 8mm spacer to get close to the 3mm of clearance all around that Brembo stipulates. This would result in an 18x9" with effective ET22 using a 255/35. The car is lowered with -3.1 deg camber in the front. I suspect that this will result in some rubbing, but it seems that others may have run this low an offset with wider wheels without. The car came with the beautiful 513M, 18x9, Et29 f and 18x10 ET40 (12mm spacer) and these fit very well with no issues other than a very slight rub under track use. Finding these reasonably priced ain't easy... I'm starting to think that the best course of action is removing and selling the Brembos since they are such a PITA to deal with. Thanks! |
05-19-2022, 08:06 PM | #563 |
Rep 44
Hey guys,
Have an opportunity to get a set of wheels and tyres for cheap - F: 9.5x19 +19 R: 10.5x19 +30 Current tyres: 2x255/30/19 2x275/30/19 Its lowered on BR coils. Any issues with rubbing? Couldnt find similar set up in the spreadsheet? |
05-21-2022, 10:26 AM | #564 | |
Rep 12,570
Drives: Z4 M, X5, GX460
Garage List F15 X5 xDrive35i [8.75]
E86 Z4 M [10.00] F10 550i (Retired) [9.17] F25 X3 xDrive35i (R ... [9.43] E82 135is (Retired) [9.50] E85 Z4 M (Retired) [9.41] E90 328i xDrive (Re ... [9.25] E86 Z4 3.0si (Retired) [9.08] |
Re spacer, is that based on a wheel template or have you actually tried mounting the wheel? The issue is the convex spokes so I can see how there might be a slight clearance over the calipers. But I’d just run a spacer and run a 245 tire. |
06-21-2022, 10:19 AM | #565 |
Rep 28
Hello, I need some help with the wheels.
I have a set of Dinan wheels from my E46M3. Here are the spec of the wheels F: 9.5X19 ET45 R: 10X19 ET35 I am thinking to use 3mm wheel spacers at the front and 5mm wheel spacers at the rear. Do you think these wheels would work for the Z4m? can the front accommodate 265/30/19 tires (or I should stick with the 245/35/19) and R with 275/30/19? Thanks in advance! |
07-04-2022, 09:23 AM | #566 | |
Rep 50
The reasoning for the 285 is that it is smaller in diameter than the available 275 tires. The real answer is for me to quit being cheap and buy a proper set of squared up wheels all around. |
07-25-2022, 08:26 PM | #567 |
Rep 44
Hey guys,
Got a great chance to grab some Vorsteiner wheels. I just want to know what it'll take to make them fit + what tyres would be advisable. I've got the M sitting on BCR Coilovers; everything else stock. 19x9.5 et22 19x10.5 et 34 Having trouble finding out if there would be any issues. I'm assuming the front's wont work without some negative camber involved. Last edited by Caosa; 07-25-2022 at 08:31 PM.. |
03-29-2023, 11:36 PM | #568 |
Rep 37
Hi guys,
Just got myself a z4m roadster. I'm a huge fan of 166 style wheels (E60 M5 ones), with specs of: front: 19x8.5 et12 rear: 19x9.5 et28 what is the best tire setup for them? will 235/40 and 265/35 do? or 235/35 and 265/35? I'm looking at ad09 so only 255/30 available if i had to 30 on the rear. |
08-11-2023, 08:45 PM | #569 |
Rep 6
Found a set of D-Force rims I'd love to pick up. However, is there a reason why I'm not seeing much info on running 18x9 all around?
Been searching through pages on the topic and seems like something like this would be fine: Front - 245/40/18 Rear - 265/40/18 The set is a square 18x9 et 41 so I'm thinking worst case scenario I can use spacers to push the tires out to be flush if needed but they should fit, right? |
