09-15-2021, 05:48 PM | #1387 | |
Rep 2,643
Posts Drives: 2019 BMW 540 Join Date: Nov 2019
Also, excuse the mess. |
09-16-2021, 08:38 AM | #1388 | |
Rep 474
Posts Drives: F36 440i GC Join Date: Jan 2011
2024 Porsche Taycan 4S
2017 Ducati Monster 821 |
09-16-2021, 08:45 AM | #1389 |
Rep 474
My landscapers just finished up yesterday afternoon!
1200 sqft of sod, Mexican Beach Pebble lined walkway Planted a few trees and bushes, and lined the outside edge of the driveway with Junipers. Considering adding a couple on the opposite side to frame the driveway. 4 tons of crushed granite filling in the space between the concrete pavers, and a few trees/bushes planted in the back. Ordering some new chaise loungers for next season.
18
JP102463.00 S1nner126.00 oVeRdOsE.2705.50 RickFLM410971.00 IllSic_Design2124.00 King Rudi13154.00 nyalpine907433.00 hybrid_eg852.00 MPOWER52664753.00 DETRoadster11462.50 Buug95917382.50 rcaso26331.00 E92 M Sport286.50 MaC-N54-E82455.00 wrickem2101.00 hooligan_G016430.00 Turkish Pickle3084.00 |
09-16-2021, 09:07 AM | #1390 |
Rep 1,144
Much appreciated! Yes, it is the adhesive backed wallpaper from Target. It was cake to put on. Just need to watch for bubbling and smooth it out as you go. Worked well by applying to the top, then I held tension while the wife worked the paper down the wall keeping in mind to have the edges straight. Overall it was the easiest part of the project.
Patrick303674.50 |
09-17-2021, 02:30 PM | #1391 |
Rep 818
[QUOTE=Patrick303;28040663]My landscapers just finished up yesterday afternoon!
1200 sqft of sod, Mexican Beach Pebble lined walkway Love the look!! however, i eventually hated my MX pebbles.. first they get kicked around all the time which is super annoying and they also fade over time, not to mention they collect so much debris like leaves, etc.. i put up with it for nearly 2 years then put artificial grass and never looked back.. just a heads up..
Retired: '02 E46 M3, '02 E46 M3 Vert, '11 E90 335d, '15 F10 M5, '17 F85, '18 F90, '02 E46 M3, '21 F96 Comp
09-18-2021, 01:41 PM | #1393 |
Rep 14,522
while i'm researching and planning on what i need to complete my kitchen cabinet lighting i started to complete my basement stairs now that the basement is complete. i'll be using the same bamboo flooring i did with the main stairs but this time it should be easier since there's no corner cuts for the bull nose.
here's the main stairs i did a couple of years ago here's the basement stairs before i started ripping the carpet out carpet removed! and update progress
09-29-2021, 07:43 AM | #1394 |
Rep 1,189
So a couple weeks before the tornado hit I had a landscaper out to look at some stuff at my house. There were a couple trees that we wanted knocked down, I wanted a little fill dirt around the concrete pad, and I wanted some gravel poured in the area behind the house near the washbay. Well the tornado hit so all of that was rescheduled. Over the next couple months we got the house back to livable conditions, made some improvements, cleaned up the yard and had a new fence put up. On Monday my contractor came and installed our gutter guards, which essentially finished the house. My wife and I had decided that when the house was finished we could get back to the Biergarten project, so we had called the landscaper back and he showed up yesterday. He started with the fill dirt around the pad, nothing special but it will keep me from breaking my ankle if I step off it washing a car. He then filled some low spots and put down fabric.
Untitled by Nick Wood, on Flickr Then he put down the edging and laid the gravel. I went ahead and moved the bench and fire pit from out of my washbay where they have been sitting for almost a year now. Untitled by Nick Wood, on Flickr After the kiddos went to bed, I assembled the chairs that we had ordered right before the tornado. They were delivered the Monday after the tornado so we had used the boxes to block off the main room of the house since it was full of glass. I was happy to finally get them together. Untitled by Nick Wood, on Flickr And since this has been months in the making, I set them all up and had a beer out there last night. It was too late to start a fire so I stuck a magnetic work light on the washbay for ambiance. Untitled by Nick Wood, on Flickr We still need to plant ferns along the edging, hang up some signs, put up the lights, build a little pallet fence around the AC unit, and set up the traditional Biergarten table. I have a feeling we are going to spend a lot of time out here. |
09-29-2021, 08:02 AM | #1395 |
Space Force - 4 Star General
11463
Rep 3,264
OK, OK, I see what you're doing. This is super helpful. Thanks!
So whats the plan here for where you have your central support steel framed out on the left, your ducting framed out on the right, and your water, gas, and electrical conduit running up the middle between the two? Are you running sheetrock straight across that gap where the utilities run, and lowering your ceiling height? Or are you going to space the sheetrock down an inch or so below those pipes/conduit and have it follow the contour of the ceiling? This is where I keep getting stuck in my planning. How closely do i follow the contour of obstacles sticking down from the floor joists. |
09-29-2021, 08:24 AM | #1396 | |
Rep 1,965
DETRoadster11462.50 |
09-29-2021, 08:34 AM | #1397 |
OHIO STATE
651
Rep 697
Posts Drives: 2021 BMW M340i Join Date: Feb 2012
I had the same issue when I was finishing out my basement. I used a 1x2 wood strips and nail gunned them in. I didnt want to lose the headroom since we have 8ft ceilings in our basement. It worked perfectly and no issues. I also had a large steel beam on one side framed out. Best of luck!
Present: 2021 BMW M340i Mineral White
Past: 2018 BMW X5 Mineral White, 2018 BMW 340i Alpine White, 2016 BMW F15 X5 xDrive / Glacier Silver, 2011 BMW 335xi / Alpine White, 2008 BMW 135i Sedona Red |
09-29-2021, 02:41 PM | #1398 | |
11463
Rep 3,264
09-29-2021, 09:58 PM | #1399 |
Rep 5,484
Posts Drives: 23 X7 40i; 23 M3; 24 cooper s Join Date: Aug 2019
We finally got a lot of decor and updates done to our house.... nearly 4 years after moving in. Got around to taking pics of some of the rooms so thought I'd share. The guest bedrooms are still pretty bare so not including those:
Entryway: Dining Room: Office: Living Room: Kitchen Area: Daughter's Room: Master Bedroom: Loft: Basement:
2023 BMW X7 xDrive40i
2023 BMW M3 6MT 2024 Mini Cooper S Convertible '20 BMW m340i... '20 BMW X5 40i... '16 Infiniti Q50 RS 400... '10 Lexus RX 350... '08 Lexus IS 350... '00 Nissan Maxima... '93 Nissan Maxima |
09-30-2021, 01:57 AM | #1400 |
Rep 445
Patrick303674.50 |
09-30-2021, 08:47 AM | #1401 |
Rep 474
We started by selecting spacing so that the pavers lined up with the edge of the pool and then moved outward.
09-30-2021, 11:21 AM | #1402 |
Rep 445
Thanks! I was wondering if there were any rough guidelines for the size of the concrete patch vs gap to accommodate for drainage while still ensuring that the concrete patches were stable (e.g., not tilt, crack, etc.).
10-01-2021, 09:00 AM | #1403 |
Rep 474
Nothing specific. We just picked a size and spacing that we thought looked good and my contractor took care of drainage. They had to re-route a few of the gutters as well that are now buried underneath. They also did lots of ground prep and tamping because the far side of the yard originally sloped down, so they had to build it up some.
bayarea328xit500.50 |
10-11-2021, 07:58 AM | #1404 |
Rep 1,189
Saturday we loaded the kids up early and headed to Lowes for supplies. I had to change my plans up a couple times on the fly because Lowes seemed to be out of everything, but I eventually got it figured out. I grabbed some 10 foot sticks of 1/2 galv, I wanted to use conduit but they were out, some zip dies, anchors, etc etc. I drilled some holes in the top of the tubes and hammered them into the ground and attached them to the fence. I had to use the wrong mounts since lowes was out of those, but these worked.
Untitled by Nick Wood, on Flickr I anchored the lights to the house with some aluminum clamps from work and zipties, I hope they hold up. After about 2 hours I had the lights up. Untitled by Nick Wood, on Flickr The two strands of lights of course met in the middle of the air so I had to get a little crafty to hold them together. I then wrapped this sketchy contraption in duct tape of course. Untitled by Nick Wood, on Flickr And the finished product. Untitled by Nick Wood, on Flickr I ran out and grabbed some german beers, stole some firewood from my parents, and had a buddy over for cigars and beers.. PROST! Untitled by Nick Wood, on Flickr We still have some signs to put up and we have a biergarten table on the way, but its getting close and I enjoyed relaxing out there. 81NufHiG-yL._AC_SL1500_ by Nick Wood, on Flickr |
10-11-2021, 12:49 PM | #1405 |
Rep 538
Just finished our master (yes it super tiny) bathroom reno. Had a contractor do the tile and my B-i-L and I installed the shower door. I did the new faucet, mirror, and vanity lights myself.
The people we bought the house from bought from a flipper. It was obvious this house was one of the 1st for the flipper. The previous owners, after having lived in the house 3 months, noticed a horrible smell coming from the newly renovated master bath drain. After trying many different things, they couldn't get it to go away, so they took a sledgehammer to the floor. Discovered that, instead of installing concrete flooring and a shower pan, the flipper had put layers of DRYWALL under the tile and didn't attempt to water-proof. So that drywall soaked up months of water drainage and you see the super POS cheap tiles that were put in by the owners that we bought from. **Thanks to our sweet, sweet Bimmerpost app, no pictures will ever be in the correct order of upload, nor can you fix it We start our kitchen this weekend!! Taking out some non-supporting columns to create a true island & raising the ceiling to match the rest of the living room, then new countertops and painting the existing cabinets.
'16 Carbon Black Metallic F10 535i M-Sport - TOTALED 11/21/21 '13 Black Sapphire Metallic F30 335i M-Sport - unknown charge pipe, MSport Exhaust, 20" 405M wheels, $61k MSRP, CF M4 Mirror caps & Spoiler, NGK plugs, Dinan Coils, BMS intake |
10-12-2021, 05:46 PM | #1407 |
Rep 1,913
Posts Drives: Here and There Join Date: Jul 2013
I just did my first mow since 2020. Long, strung out ordeal with TruBrown destroying my yard. Paid some guys here a month or so ago to regrade the lot, new sod, and some new straw and got some rocks put in with metal edging. Happy with how it turned out.
9
IllSic_Design2124.00 vreihen1615242.50 nyalpine907433.00 hooligan_G016430.00 MoeTE87651.00 King Rudi13154.00 ramman434712.00 Buug95917382.50 wrickem2101.00 |
10-17-2021, 08:23 PM | #1408 |
Rep 378
Posts Drives: GMC Denali Join Date: Feb 2021
Decided to do a 3/4 board and batten wainscot wall. Since the wall was textured, I had to skim the area smooth first and then install the board and batten.
9
lakefront560.50 lsturbointeg9155.50 Patrick303674.50 Hawkeye2069.50 Kilabyte3948.00 jab23223.50 RickFLM410971.00 Buug95917382.50 |
