      08-01-2021, 10:25 PM   #1
Fritzer
No one sleep in Tokyo
Fritzer's Avatar
Drives: 2011 E90 328i//1995 E34 530i
I ate some metal today
You know those permanent retainers that orthodontists put behind your teeth after you get braces off? I've had mine on for the better part of 15 years. A few days ago on Friday, about 1 tooth's width worth of the retainer, came "un-glued". It was sticking out straight into my tongue any time I moved my mouth. Very painful, kinda sharp. Anyway, made an appointment with local dentist for Monday and bought some dental wax so it's not stabbing me.
This morning, less than 24 hours before the appointment to get it removed and replaced, I have breakfast. 20 minutes after breakfast, I realize that I don't feel anything where the sharp wire bit was. Upon inspection, it has disappeared! I swallowed it while I was eating.... So now I have a few mm of relatively pokey wire slowly making it's way through my digestive system. How fucked am I?
How was your guys' Sunday?
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
      08-02-2021, 01:28 AM   #2
NQRDDS
NQRDDS's Avatar
54
Drives: E90 M3
Most likely you will be fine. It will probably end up coming out on the other side. People swallow dental materials all the time, some much larger than what you described. I'd relax and not think about it too much.
      08-02-2021, 01:30 AM   #3
HFW003
HFW003's Avatar
Australia
6124
Drives: 2024 M340i xdrive
Ever had a fish hook in your finger, you’re fucked!
      08-02-2021, 02:31 AM   #4
Tambohamilton
Drives: E91 330d
You're exactly the same amount of fucked as before you swallowed it. It'll do no harm at all.
Fun fact; you can drink mercury if you want. It goes straight through and does absolutely nothing. However, if you accidentally inhale any of it, it's highly toxic!
      08-02-2021, 04:41 AM   #5
radix
you know he kills little girls like you
radix's Avatar
Drives: -
Life is an adventure, enjoy it!
      08-02-2021, 08:33 AM   #6
overcoil
Drives: M235i 6spd
Is there not a chance, if it's sharp and thin, that it could hook on to something.
Reads as though it safely got past the esophagus and upper tract.
My recommendation is to carefully check your stool over the next couple of episodes to make sure it passed.
Just kidding.
      08-02-2021, 08:49 AM   #7
tcphoto
tcphoto's Avatar
Drives: E92 335i 6MT Coupe
I was eating lunch when a tooth broke, it had a filling in it and I swallowed it. Do you think I'll set off the metal detector when I go through TSA next time?
      08-02-2021, 09:21 AM   #8
Tambohamilton
Drives: E91 330d
Nope. I've got a couple of small titanium screws in my finger, and nothing happens at airports
      08-02-2021, 09:47 AM   #9
Addbuyer
Addbuyer's Avatar
841
Drives: X3MC
You will be just fine. Did you know that you can jump off a 100ft high tower and I can guarantee you 100% that that jump wont kill you. The sudden stop at the bottom, now that's a different matter
      08-02-2021, 02:26 PM   #10
3.0L
3.0L's Avatar
10363
The little piece of wire will likely go through your digestive tract like a piece of unchewed corn. Kind of decorative in the end.
2014 BMW M235i
2024 Mercedes Benz GLC300
Expert ultracrepidarian
