08-06-2019, 01:55 PM | #705 |
Rep 14
Fakes=Counterfit
Regardless of cost, value, perceived value and status symbol, bottom-line is these watches are illegal to produce and to be sold. They infringe on IP and trademark laws. On top of that, these counterfeit enterprises are tied to other criminal enterprises that are admittedly way worse that IP law violations, ie human trafficking, arms dealing. Are Swiss, Japanese and German watch companies beyond reproach? Probably not, but they are legitimate businesses trying to make an honest buck.
08-07-2019, 05:14 PM | #706 | |
#buildnotbought
11104
Rep 4,930
A fake rolex with 3135 clone movement also isnt cheap. For that kind of money you can easily get a seiko with 6r15 movement, and I guess thats better than that clone movement. Clone movements usually have pretty bad finishing if you look under the microscope at the finishing of gears etc. And those clone movements dont are not made wiht the same grade of materials rolex uses for critical components, like very carefully formulated steel for for example balance hairspring etc. And at that level Seiko can compete. Seiko is the only manufacturer that has the ability to make everything inhouse. So all materials and components. Even rolex cant say that (I believe to extend it to the hairsping, rolex does make that component itself), seiko grows their own jewels and makes their own crystals, mainsprings, everything. Rolex still relies for some parts on other specialist swiss niche manufacturers (I think all those components that rolex does buy come from swiss high end manufacturers). But still relying on other manufacturers for highly specialized parts is more rule than exception, patek and the likes also do that (obviously also from swiss only companies). But Seiko is in that way unique. And a clone movement.... you'll be sure that thats all bought on the world market..... for the cheapest of the cheapest price. And its not really a clone movement, its a counterfeit movement, so an imitation movement. Clone movement, like Eta style movments from for example chinese manufacturer seagull, are also seagull branded and usually of much much higher quality in both materials as accuracy and finishing of parts as skillness of assembly. I'd never buy and wear a counterfeit watch (except maybe for a costume party that would require something like a very ugly and flashy rolex (gold yauhtmaster2...). With a normal watch costing 500 or 1k, you usually get 500-1k of quality. With a counterfeit 'clone' movement, costing similar money, you dont get 500-1k worth of quality. You get the lowest quality the manufacturer still can get away with as there's no name or brand to keep up high. Thats why lots of seiko's are dead reliable. arguably more reliable than Rolexes when it comes to keep ticking without being serviced. Seiko movements are real survivors (of course you can really only say that from old movements as time will only tell....) Of course a 500 buck Seiko cant compete with a 5k+ rolex watch to the level where it's regulated and tweaked to precision (witch can require partly rebuilding the movement a few times to get it 100% right) to meet certain standards. Rolex obviously puts way more time into that than seiko. But who doesnt put time into that is the counterfeit factory.
hooligan_G016431.50 |
08-08-2019, 02:30 PM | #708 | |
Rep 2,524
08-08-2019, 03:13 PM | #709 | |
#buildnotbought
11104
Rep 4,930
Also there are some seiko movements that are certainly fairly high end and not GS. Some used in the brightz series for instance (Seiko 6s), like a very nice column wheel chrono. Seiko 8R is also nice, and I believe also not a GS movement. I saw that video on youtube about the latest rolex counterfit from watchfinder&co (2 months ago) and I was not that impressed with the finishing of the materials in the fake movement. I mean, virtually first videoshot they made: If you think this is quality engineering and finishing we have completely different standards. Sure if you take a $100 Seiko 5, than you could accept this, but finishing like this is absolutely not seen anymore in the sarb/sarg/pressage line ($350-700), and mind you, this is, I believe a $1000 fake, so a $1000 watch. I mean yes, it has stipling (is that the correct english word? not a native speaker), but it has been applied because its there on the original, not in any way nice to actually improve the finishing. And that cutting on the movement ring? (I guess thats what it is)... was that done with a woodchisel? That kind of coarse, sloppy, cheap finishing surface, which is a result of cheap, inaccurate substandard machining, thats not something you'll find at seiko. Certainly not in that pricerange. And is it me, or does that baseplate look dirty? Also I think that a lot of parts might not have been machined to tolerance, but having used cheaper production methodes, and maybe even started out as a cast part instead of a billet part (further in the video, the column wheel). The latter of course way more expensive but way stronger. The only thing that makes that video bad, (and my only comment there ) is that they didnt put the fake on the timegrapher. (and dismanteling the watch to take a really good look at the movement parts. for example a delicate and very difficult part like the vertical clutch, I'd be eager to see what kind of botchjob they made of that) And if we look at older seiko's, as that is of course the only real benchmark there is to determine how a movement holds up to time and is a good marker for a companies merit and quality attitude: I have a 4006-7020, the 27J version with # 871955, so thats a 50+ year old watch, from what I could see never serviced (no marks) and if it so it was extremely long ago as I could only get the crown/stem out pulling so hard that the stem bushing/case tube came out with it. It was totally fused with the orings in the crown. First I thought thats a peculiar crown before I realized what had happened Case tube is of course impossible to source but I managed to get it undamaged out of the crown by heating, incinerating the o rings, and later microsolder the case tube back in the case (there was no clamping action present anymore). So long story short, very old watch, if serviced certainly before I was born. But on the timegrapher...Deadstraight (+/-6 sec or so in multiple positions), beat error? 0,2 maybe... And good amplitude. I also have a 6138 (well... more than one), same story. Even unserviced ones tick and tock very nice after 40+ years, and are easily regulated if needed. For sure we wont know until after 40 years if a 6r15 or such will hold up that well, but the heritage is there. So I certainly dont share your views. Obviously comparing $300-$800 seikos to $4000-$15000 rolexen there will be differences, but that $1000 fake, when the back was opened to me it became immediately clear where corners had been cut. It is made to look the same, but certainly not to be the same. The production methods used in that watch to make it look like a rolex are the cheapest of cheapest. And of course there is no way of telling, except of using a multi million$ lab, but I bet that critical components like hairsprings will be made of the cheapest of cheapest materials to keep it more or less ticking and not of very bespoke materials resulted from decades of research by the best time keeping companies of the last century (and mostly then patented I'd imagine). But thats something you cant see, but will arise if it has ticked a decade or so and gradually seems impossible to regulate anymore.
08-08-2019, 04:40 PM | #710 |
Rep 128
face it boys.. a fake watch will be a fake watch. it holds no real value. so if you spend 400-500 on a fake watch and then spend another few hundred on cleaning up some of the flaws.. at some point.. you'll want to sell this piece and they just don't hold any real value. Seiko in the other hand.. they actually hold their value or even more based on your mods.
idk i sold all my seikos and purchased a Rolex dayjust 36mm. I also daily this watch everyday so i'm not the best owner hahaha. |
08-08-2019, 04:59 PM | #711 | |
Rep 2,524
I also have worked on a ton of these 3135 clones, because it is the cheapest way to practice servicing gen 3135s. If you can service the clone and get it to run within Rolex spec, you can do the real thing no problem. Sure, their finishing isnt amazing, but neither are those seikos, and really, not even the standard grade ETAs. What you can compare these movements to and they fall short are the mid tier and higher tier ETA 2824s. Similar price points (all within 100-150 new wholesale'ish), but the eta quality is much better. FWIW, most these clone movements come either over oiled, under oiled, and/or dirty straight from the factories. Give them a proper service and they run like champs. Goes for the ETA clones to the Rolex clones and everything in between.
08-08-2019, 05:02 PM | #712 | |
Rep 2,524
They are meant to be worn. No shame in actually wearing them.
08-08-2019, 05:09 PM | #714 | |
Rep 4,139
But never getting away from that nonsense. Im not a huge watch guy. But I am looking to buy a nice watch and call it a day. Its literally just jewelry to me. The movements and all that don't matter. |
08-08-2019, 05:12 PM | #715 | |
Rep 618
08-08-2019, 05:19 PM | #716 | |
#buildnotbought
11104
Rep 4,930
A good fake from 15 years ago is probably nothing compared to the ones of today. Is it still worth the price it cost then? Or doesn no one want it anymore?
08-08-2019, 05:28 PM | #718 | |
Rep 2,524
Look at what Omegas MSRP for and what they sell for on the secondary market.
08-08-2019, 05:47 PM | #719 |
#buildnotbought
11104
Rep 4,930
maybe but if you have a seiko skx007 (one of its cheapest automatic divers, costs? $200 new or so?) and you have one from 20 or 25 years old (I think its now 25 years on the market), I bet it sells for the same price or maybe even higher if its in good condition of course.
And its predecessor is way way more expensive (skyrocketed) but there's a 10 year gap between that, so that already becomes vintage (to use a vague word). So its very model dependant, and not brand specific or budget specific (like that that only happens to very very expensive watches) There are also some unpopular rolex or patek or VC models that loose substantial value the moment it's carried out the jewelers door. So even there its model specific.
08-08-2019, 05:50 PM | #720 | |
Rep 2,524
08-08-2019, 05:59 PM | #721 |
#buildnotbought
11104
Rep 4,930
Ah ok, I thought you meant that those brands are high demand (as in the only real high demand brands on the planet).
I misunderstood. But yeah I reckon they're golden times to now trade in top tier steel sportswatches (mens models). Submariner, daytona are now probably the best investments you can make, not even limited to watches but also regarding stock etc (or at least could have made 5 years ago, but thats hindsight), not to speak of the vintage ones
08-13-2020, 02:05 PM | #722 |
Rep 4
I think maintenance comes into play here (or the lack of thereof): If it's a proper fake with a mechanical movement it needs maintenance, as the original would. Finding a place where you can bring in your fake watch to have it maintained might be a bit more tricky, so people might not maintain their fake watches at all. This uncertainty contributes to the fact that fakes lose a lot of value quickly.
Nivarox1094.00 |
09-11-2020, 12:21 PM | #723 |
Rep 2,494
Never understood what the point of buying a fake would be. If you can't afford it now then save up... I'd personally be embarrassed going around flaunting something that its not.
09-11-2020, 12:35 PM | #724 |
Rep 2,665
Agree but possibly you could afford it and just don't want to spend the money. Personally think it would be embarrassing to wear a fake, almost like a toupee. I guess you want people to think it is real but then not ask you? If they ask you do you tell them the truth or just say real and hope they aren't good enough to realize it? If they realize you are lying to them I guess anything else you say is also suspect.
Nivarox1094.00 |
09-12-2020, 11:43 PM | #726 | |
Not Enough Garage Space
1138
Rep 721
If you're buying a fake, you're either saying: 1) I want the real thing, but can't afford it (In which case you should think of it as inspiration and work towards it) 2) I want to be perceived as someone who can afford the real thing, but can't (deeper, sad issues here). 3) I've heard the argument "I can afford the real thing, but the real ones are overpriced and a waste of money, so I'll buy a fake"... well guess what, you have good watches out there for <$1,000 that you could buy...so if you're buying a fake of a Rolex, AP, etc. then you're contradicting yourself because you could easily get a "real" watch for way cheaper, you just want the brand...see point 2 above.
