      06-28-2019, 12:43 PM   #793
supra93
Drives: Z4, E500, Supra, RX7
HKS Has Built A 2JZ-Powered A90 Toyota Supra Drift Car With 700bhp
https://www.carthrottle.com/post/hks...r-with-700bhp/
HKS is the latest company to build a 2ZJ-powered version of the new A90 Toyota GR Supra, and it'll be drifting its way up Goodwood hill next week
You didn’t think Daigo Saito’s A90 drift car would be the only 2JZ-powered Supra, did you? We’re already on our third - the second being a car fielded by Saito’s fellow D1 GP drifter Kawabata Masato - with this latest effort coming from HKS.
The Japanese company - which supplied to parts to both previous 2JZ A90 Supra efforts - has revealed its own entry into this new tuning niece ahead of a public debut at next weekend’s Goodwood Festival of Speed. There, it will slide its way up the famous hill climb with official HKS driver Nobuteru Taniguchi at the helm.
The setup sounds quite similar to Saito’s car. The 2JZ-GTE in this one has the same 3.4-litre HKS enlargement kit and an HKS GTIII-4R turbocharger. Power is slightly lower at just under 700bhp, but that’ll be plenty for Taniguchi-san to light up the rearmost Yokohama Advan A052 tyres while he’s sitting in the Bride driver’s seat.
The HKS A90 drift monster sits on Hipermax dampers and has been given a dramatic wide-arch conversion. The finishing touch is a giant rear wing.
We can’t imagine there’s a whole lot of stock A90 Supra left in there, but who cares when the resulting car looks like this?
angelr187.50
Mingwan1892.50
clee1982797.50
NickyC17445.00
      06-28-2019, 07:23 PM   #794
Mingwan
Drives: X1 Individual custom paint
^frs owners be like shouldve come from the factory that way
supra932480.00
      06-28-2019, 07:26 PM   #795
supra93
Another dyno vid w/ 376hp.
clee1982797.50
      07-02-2019, 09:14 AM   #796
OkieSnuffBox
Drives: '13 135i
I had a BRZ for 3 years before my 135, it's literally the dumbest owner group I've ever witnessed in my life.
ItsGary1457.50
      07-04-2019, 01:39 PM   #797
supra93
2020 Supra Documents Added to TIS
https://www.supramkv.com/threads/202...d-to-tis.1915/
http://techinfo.toyota.com/
  • Full engine model is B58B30M.
  • Power is listed as 335@5000 to 6500, which is interesting. Flat torque curves are common these days, but a flat power curve almost always means it is being limited by the ECU and/or being under stated.
  • Doesn't require premium fuel (87 octane AKI or higher).
  • "Toyota Genuine Motor Oil SN 0W-20 C5 for GR Supra" engine oil is specified, 0W30 is also acceptable.
  • BMW Frostox HT-12 engine coolant is specified.
  • Crank and rods are forged of course.
  • Steering wheel is 373 mm
  • Automatic Gearbox Oil ATF 3+ transmission oil is specified.
  • Exterior mirrors are heated, auto-dumming and have power folding.
  • Canada/US curb weight is listed at 3397 lbs.
  • Mexico curb weight is listed at 3461 lbs.
  • Fuel tank capacity is 52L
  • Canada/US model code: model code: DB43L-ZRLA, Grade: RZ.
  • Mexico model code: DB41L-ZRLW, Grade: RZ.
  • Front brakes: 40/44mm piston size, 348x36mm 2-piece floating rotors
  • Rear brakes: 44mm piston size, 345x24mm 2-piece floating rotors
  • DOT4 brake fluid is specified.
  • Rear differential is a BMW 215LWS model with 3.15:1 final drive.
  • BMW Hypoid Axle Oil G4 is specified for the differential.
  • Heated power seats with a memory system on the driver's seat.
  • A spare tire is not provided, only a repair kit.
  • Front wheel alignment: toe-in: 0.27° +/- 0.20°, camber: -1.63° +/- 0.50° w/o(AVS), -1.75° +/- 0.50° w(AVS), caster: 7.58° +/- 0.50°, steering axis inclination: 17.35°. Toe is adjustable, camber is adjusted by replacing the steering knuckle.
  • Rear wheel alignment: toe-in: 0.23° +/- 0.20°, camber: -1.83° +/- 0.42° w/o(AVS), -2.00° +/- 0.42° w(AVS). Toe is adjustable.
      07-05-2019, 12:47 AM   #798
Savedamanualse90
Savedamanualse90's Avatar
Drives: 6spd n52
Supra is pushing out 375hp on a dyno, way above listed HP.
If you can?t daily drive it, what?s the point. #savethemanuals
#NA
3IM AA PE eibach sportline with bilstein Megan rear arm kits AFE Headers and AFE mids euro intake m3 SSK JVC CarPlay.
      07-05-2019, 08:47 AM   #799
SteveinArizona
Drives: BMW 530e
BMW is well known for sandbagging its HP numbers and several recent efforts at dynoing BMWs produced results were the HP at the wheels was close to the HP at the crank.
Since this is a BMW engine, that is what is likely happening.
      07-05-2019, 12:14 PM   #800
Dog Face Pony Soldier
2006 TIME Person Of The Year
Dog Face Pony Soldier's Avatar
Drives: M Sport 335i
2014 335i  [9.74]
[QUOTE=supra93;24990493]https://www.supramkv.com/threads/202...d-to-tis.1915/
Not having to run premium fuel is a unforeseen plus!
Not having a heated seat on the passenger side is going to be an issue. Hoping a heated passenger seat can be optioned in.
      07-05-2019, 10:19 PM   #801
hellrotm
Drives: F80
I read that as heated power seats(driver & pass), with the memory only on the driver. Which would be a common setup.
      07-06-2019, 04:42 AM   #802
Biginboca
Biginboca's Avatar
3762
Drives: 2009 E92 328i 6MT
Those alignment specs are way more aggressive than I’ve seen for any bmw cars.
-1.75 front camber
-2.00 rear camber
E92m3 front camber was -1.2, the M2 -1.3, and the M4 -1.3.
N54Yankee2706.00
      07-06-2019, 07:05 AM   #803
supra93
Carwow: Toyota Supra v BMW Z4 - DRAG RACE, ROLLING RACE & BRAKE TEST
https://g29.bimmerpost.com/forums/sh....php?t=1631315
      07-06-2019, 09:30 AM   #804
OhioRiderAaron
Drives: 2016 BMW M3 ZCP
-1.75 front camber
-2.00 rear camber
No wonder it's getting such praise for handling! Every lil bit helps to wake these cars up.
ZCP - Daily Driven Trackster ~ Gone but not Forgotten
1LE - Track Rubber & Garage Dust Collector
      07-07-2019, 01:42 AM   #805
The Automotive Enthusiast
Retired BMW Genius
The Automotive Enthusiast's Avatar
Drives: 2018 Audi S5 Coupe
I'm kind of excited for this car.
Originally Posted by LucBroDude View Post
TRAITOR.
TRAITOR.
supra932480.00
      07-07-2019, 03:07 PM   #806
heavyD^2
heavyD^2's Avatar
Drives: X3M Competition
Latest C&D with a production car road test;
0-60 mph: 3.8 sec
1/4 mile: 12.3 sec @ 113 mph
Skidpad: 1.07 g
Performance/dollar this car has to be the new king as a 12 second 1/4 mile is very impressive at this price range.
      07-07-2019, 04:13 PM   #807
RM7
RM7's Avatar
2893
Drives: Camaro SS 1LE
This is nothing new. BMW has advertised x horsepower and most of the time, they have been found to put out x horsepower at the wheels. The brilliance of this is then it's entered into a competition with other cars, all of which are advertised as having similar to "x horsepower", except being measured at the wheels, the BMW always has a hp/tq advantage and takes the performance figures.
      07-09-2019, 12:54 PM   #808
clee1982
Drives: 2019 BMW 540i xDrive
waiting for a similar test for the US version!
      07-09-2019, 01:27 PM   #809
heavyD^2
heavyD^2's Avatar
Are there any expected differences outside of particulate filters?
      07-09-2019, 01:31 PM   #810
IllSic_Design
IllSic_Design's Avatar
Drives: 09 E92 335i
Euro Z4 has 50 less horses than US Z4
clee1982797.50
      07-09-2019, 02:28 PM   #811
DPelletier
Drives: 2020 Z4 M40i
2020 Z4 M40i  [8.00]
North American Z4 M40i dyno; 373.5 HP at the rear wheels https://g29.bimmerpost.com/forums/sh....php?t=1621271
Dave
      07-09-2019, 02:34 PM   #812
Red Bread
Drives: Smog machines
Has anyone dyno-ed an EU one? I'd be surprised if it's really down that much in power.
      07-09-2019, 02:39 PM   #813
Joe240
Joe240's Avatar
Drives: 2021 C8 Corvette 1LT
Dynos within this thread are EU spec and are showing powers similar to the US spec Z4 M40i. If memory serves me correct, around 360whp and 415wtq.
Red Bread4463.00
      07-09-2019, 02:48 PM   #814
DPelletier
2020 Z4 M40i  [8.00]
Not that I know of but the results of CarWow's drag test implies there is a significant difference (see post 2075) between the euro Z4 and the Supra.
The flip side is dyno tests here show the north american version of the Z4 to have a 34hp rwhp advantage vs. the Supra meaning the drag race test between the Supra and NA version of the M40i wouldn't have the same outcome.
https://www.caranddriver.com/news/a2...no-horsepower/
Dave
clee1982797.50
Red Bread4463.00
