10-04-2017, 09:33 AM | #1 |
Rep 891
GTS coding
Hello,
I have seen that some people are coding GTS steering, GTS differential and GTS ESP is that true is it really different and has someone done it and felt a difference? |
10-04-2017, 12:14 PM | #2 |
Rep 3,386
I have it and the GTS steering flash is honestly one of the best mods I have done to the car. To me comfort mode without the flash had a bad on center feel as there was a big dead zone. Sport removed that dead zone, but has a very over assisted mid corner feel. Sport plus was just awful. With the gts flash, the dead zone is gone in comfort mode and the over assisted feel is gone from sport mode
Hope that helps
10-04-2017, 02:00 PM | #3 | |
Rep 379
10-04-2017, 09:09 PM | #8 |
Rep 8,364
10-05-2017, 06:43 AM | #9 |
Rep 379
I know how to VO code, any pointers or where to find what info needs needs to be changed also my car is 2015 build is it still possible to do GTS coding?
10-05-2017, 09:20 AM | #10 |
Rep 8,364
You change chassis, if necessary, and Type code in FA and then VO code required modules. 2015 is fine, though improvement will depend on I-Step.
10-05-2017, 12:51 PM | #12 |
just a fool
345
Rep 675
Is there more specific instruction for which module and its parameters to change? I've managed to find the below reference to choosing F87CS.
10-05-2017, 12:57 PM | #13 |
Rep 8,364
Never looked into specific changes. I just let VO coding do the work. You can use TM NCD / CAFD tool if you wish to explore further.
10-14-2017, 02:48 AM | #14 |
Rep 241
Hey OP great topic. Could I maybe suggest you add CS to the title as well? We’d love to hear from people who got the gts or CS one in comparison to zcp.
I believe the gts suspension is Manually adjustable and the CS actually has different springs so would it be wise to code GTS ESP? What about the diff is there any physical difference? This might be another thread but maybe leave here I’m not sure ... |
