11-19-2014, 09:47 AM | #1 |
Rep 557
Rubber Inflation Valves (Amended)
Hi
Just noticed today after looking at another f30 I have rubber valves on my 2013 403's, the other F30 2014 had aluminium valves also on 403's, should mine be aluminium. Also have 0001's if that makes any difference. I do get pressure sensor information ie it comes up on the dash if the pressers are uneven. can I retro fit to the aluminium when I change tyres and will this then give me individual pressure in each tyre. Thanks
E46 325is MV Augusta Previously-E30 318is E36 323i
11-19-2014, 10:23 AM | #3 |
Rep 8,114
Yes from April 2014 the full TPMS system is fitted with sensors in the aluminium valve stems. Prior to that the ABS sensors were used.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
11-19-2014, 11:58 AM | #4 | |
Rep 557
Cheers
11-19-2014, 12:50 PM | #6 | |
Rep 557
Thanks
11-19-2014, 01:22 PM | #7 |
Rep 2,808
I bought a March 2014 registered 330d and found out later it was *manufactured* a month or two earlier. I only found this out after a bought a set of 400m wheels with the new TPMS valves in them they will be in the classified section in the next few weeks when I have fitted my new winter tyres to the 400m's.
Current: G26 i4 M Sport Pro, Tech Pk, Sunroof
Previous: 2016 440i MPPSK, 2014 330d Saloon F30, 2013 Audi S4 Avant, 2011 Mercedes C350 |
11-19-2014, 04:56 PM | #9 | |
Rep 32,881
Although, if your winter tyres are RFT then by law you need to have some sort of flat tyre warning! |
11-20-2014, 06:08 AM | #10 | |
Rep 257
11-20-2014, 06:14 AM | #11 |
Rep 2,047
As I don't have the sensors does anyone know if there is a way to code the car to use the old ABS method my 2012 car uses? I've looked through the cheat sheets but can't see anything.
11-20-2014, 06:23 AM | #12 |
Rep 32,881
What is it you want to code? Your car has the basic flat tyre warning system, to get full TPMS you have to add the module, sensors, receivers in each wheel arch and cabling.
11-20-2014, 06:25 AM | #13 |
Rep 2,808
I will have some TPMS sensors for sale in the next week if you are interested.
11-20-2014, 07:53 AM | #14 |
Rep 2,047
11-20-2014, 07:57 AM | #15 |
Rep 32,881
Oh I see so you want to use Winter tyres without TPMS sensors?
11-20-2014, 08:01 AM | #16 |
Rep 2,047
11-20-2014, 08:06 AM | #17 | |
Rep 32,881
Maybe ask @shawnsheridan |
11-20-2014, 08:29 AM | #18 |
Rep 39
Stupid question, but is the valve cap part of the system?? I recently had a puncture repaired and they just fitted the standard rubber cap... I haven't noticed any error messages so I'm guessing its not important, just doesn't look as good!!
11-20-2014, 08:40 AM | #19 |
Rep 2,047
As you picked up your car on 1st March 2014 it probably doesn't have TPMS.
11-20-2014, 08:55 AM | #21 |
Rep 2,047
