E90Post
Studio RSR
BMW 3-Series (E90 E92) Forum > BMW E90/E92/E93 3-series General Forums > General E90 Sedan / E91 Wagon / E92 Coupe / E93 Cabrio > i smell a smelly smell
Reply
      09-29-2014, 03:35 PM   #1
krahooligan
krahooligan's Avatar
52
Drives: 2008 328i e90
recently when I start my car it SMEEEELLLLS terrible on the inside.
I am a very clean person when it comes to vehicles. no food is eaten in it...your lucky to drink water.
I cleaned emma (328i) for two hours yesterday.(wash, wax, leather treatment, vacuum, new air freshener)
this is really bugging me. does anybody have any idea what is causing this?
maybe a bad evaporator? there is a faint smell when I start the A/C but that goes away instantaneously.
any idea is helpful at this point.
      09-29-2014, 03:38 PM   #2
phamlay
Drives: 335i Sedan
Try changing your cabin filters? or checking those?
2009 e90 mtec| alpine white|black interior| DC intake| gloss black kidney grills| LED Interior| LED Exterior| gloss black vinyl roof| BBS RS-GT wheels| 235/35/19 front| 265/30/19 rear| KW V1 coilovers|CF trunk spoiler| CF diffuser| HKS catback exhaust| Fully coded|
      09-29-2014, 04:07 PM   #3
krahooligan
52
I did that two weeks ago.
worth another try I guess
      09-29-2014, 04:11 PM   #4
FL335
Drives: 2009 335i
Try Ozium. If it doesn't work, it could be freon…I had "that" smell a few months ago….turned out to be my evaporator coil leaking….for you, I hope this is not the case.
      09-29-2014, 04:13 PM   #5
krahooligan
52
isn't that like a 3k fix?
my car just went out of warranty.
      09-29-2014, 04:50 PM   #6
krahooligan
52
update. warranty extended by dealership for two days to try and resolve this issue...but they don't even know if its covered under warranty?
argghhhhhhh.
looks like im learning how to replace an evaporator.
      09-29-2014, 04:55 PM   #7
thomas88162
Drives: E92 328i
Does it smell musky? It could just be mold/mildew forming from the AC running. This happens to cars with age. I doubt that your evaporator is the direct cause.
      09-29-2014, 04:58 PM   #8
blaster3500
Drives: 07 E90 335i
Did you have any door panels off recently? If you lose a foam washer from one of the clips it will leak into the back floor and smell.
07 335 6MT
      09-29-2014, 05:03 PM   #9
krahooligan
52
I took off a trim panel to paint it, but did not take off the door panel. it smells musty and gross. haha. I have all 4 windows down at lunch and when I came back to the car I could smell it before I opened the door. aghhh.
      09-29-2014, 05:03 PM   #10
krahooligan
52
how would I fix this?
I had the warranty guy smell it and he thinks the evap..but if there is a way that I can fix this and not spend 3k then ill try.
      09-29-2014, 05:20 PM   #11
FL335
Drives: 2009 335i
At the dealer…yes. The dash has to come out. It's a pretty big job.I had my trusted Indy do it: $1640, OTD. Very reasonable. It's been problem in these cars…something about the seam of the evaporator giving out.
Let us know what happens. Fingers crossed for you. Hows the AC been? Is it cold?
      09-29-2014, 05:43 PM   #12
thomas88162
Drives: E92 328i
There are aerosol products just about anyplace you go which sanitize your HVAC system. Any of them will do the same job, kill the nasty bacteria causing the smell! To clarify, an evaporator goes bad if it starts leaking refrigerant, which would cause your AC to not work at all. You do not smell refrigerant, it just leaks out into the atmosphere.
      09-29-2014, 06:45 PM   #13
krahooligan
52
that's reasonable. why so much at the stealership then?. the A/C is getting less and less cool.
      09-29-2014, 08:08 PM   #14
FL335
Drives: 2009 335i
Because it's a big job and…Stealership.
      09-29-2014, 11:35 PM   #15
thomas88162
Drives: E92 328i
Now that is (generally) a sign of low refrigerant. You could very well have a leak, it is easiest to let a shop take care of A/C work; they already have all of the equipment needed to work on HVAC systems.
Reply
e90post
