Closed Thread
      08-08-2011, 02:57 AM   #3829
adrean8j
adrean8j's Avatar
Drives: SGM 135I
2008 135i  [10.00]
Originally Posted by rodi View Post
take out the background - are you happy with the model?
take out the model - are you happy with the background?
light your scene and frame your scene before you throw in the model. then light your model separately, without the light on the scene.
then put the two together.
That is very well put Ryan! I think I will use that as a mantra when/if I ever get to really shoot a "model" shoot.
Originally Posted by ptack View Post
SGM was God's color and has been recalled to heaven.
      08-08-2011, 03:56 AM   #3830
rodi
186
Drives: your FACE!
2009 135i | space grey | sport | navi | hifi | heated
dinan stage 2 software | bmw performance exhaust
kw v2 | hotchkis front sway | vmr v710
      08-08-2011, 09:41 AM   #3831
oneintheory
no longer a BMW owner
Drives: 2011 Ford Edge Sport
Seriously, Josh, the photo is technically well done. But I'm missing the point here. What are you trying to convey?
Please don't take this the wrong way and this is my own personal opinion and as such should be taken with a very big grain of salt, but I can't get the connection between the models and their surroundings. I'm not into "edgy," being an old fart and all, so maybe it's all just beyond me.
after looking at it a little more, i don't like it as much either. but it all comes down to taste, i think. there isn't a good connection here, admittedly, but i'm a fan of edgy...
take out the background - are you happy with the model? no
take out the model - are you happy with the background? yes
lit the background first, it was a bitch to get. one of my 3 battery packs died. didn't light the model separately. the pose isn't fantastic either.
then put the two together. no perfect harmony.
i like this one better. it's a bit more dramatic...but i actually adjusted the lights down for the aperture. only thing i don't really care for are the plants in the foreground.
Untitled by jsophoto, on Flickr
Originally Posted by UdubBadger View Post
i bet you would.
      08-08-2011, 09:49 AM   #3832
adrean8j
adrean8j's Avatar
Drives: SGM 135I
2008 135i  [10.00]
Josh,
I think the model looks fine in the photo, the plants/weeds have to go though. There are just too distracting from your subject (her of course). Maybe a little tighter on the model to cut back on how much the plants interfere with the shot?
      08-08-2011, 10:11 AM   #3833
oneintheory
if i cut in tighter on her, then i lose more of the backdrop. i have a couple shots that are tighter. the only plants i think are distracting are the defocused ones in the foreground, and i for whatever reason felt it would be a good idea to crouch there that night. the rest of them sort of add to the ambiance.
      08-08-2011, 10:23 AM   #3834
adrean8j
adrean8j's Avatar
Drives: SGM 135I
2008 135i  [10.00]
With a wider angle 20mm and lower? Wouldn't that keep the backdrop and allow you walk in a bit tighter? BTW I am just guessing here as I have never done an official shoot before. Just learning stuff from your experience and others
      08-08-2011, 10:40 AM   #3835
Activ
Activ's Avatar
57
Drives: Black e92 335i
Don't think I have posted this yet... Lulz
Git sum :: EuroSunday Treffen :: Granite Bay by Trevor Thompson, on Flickr
Trevor Thompson :: Activ Films
Facebook Youtube Flickr
EuroSunday :: Contributing Photographer/Videographer
      08-08-2011, 10:42 AM   #3836
gary88
Ikea enthusiast
gary88's Avatar
Drives: '07 E92 335i
2007 E92 335i  [7.96]
^^^^^^Rain or washing the car, Gary?
Hose with the nozzle off
because racecar
      08-08-2011, 10:49 AM   #3837
oneintheory
shooting models with a 20mm or lower lens close up on a full frame is a HUGE no...for me, at least. lens distortion does really unflattering things to faces, etc. i try not to go wider than 35mm. I'm sure dave will come in here and tout dxo optics pro as a good fix for that, but i've never really found correction software to be as effective on human subjects. i'd rather just do it correctly on scene.
      08-08-2011, 12:25 PM   #3838
adrean8j
adrean8j's Avatar
Drives: SGM 135I
2008 135i  [10.00]
I took a look at your set over on Flickr and there are a few shots you made between 17mm-19mm of the model that do not look distorted? The still have the background (but you still managed to keep one weed between her and your lens). Her pose in those shots is not as "compelling" but shooting between 17-20mm doesn't seem to be a problem...at least with the lens you were using. A dedicated wide angle (11-16 or the like) might be a different story I am speculating. What do you think?
      08-08-2011, 12:36 PM   #3839
Chewy734
Drives: 2006 BMW 330i ZPP, ZSP
most (nearly all published ones) portraits are done with focal lengths 35mm or longer. Almost every pro photographer will tell you the same thing as what Josh told us. That being said, I've also taken some portraits with a wider-angle lens without any noticeable issues. But, most pro photographer will use a 50mm, 85mm, or even 135mm length (although that's pushing it).
There is a caveat though, I'm generally talking about head shots, or even shoulder shots. Full-body shots can utilize wider-angle lenses as long as they don't distort a ton (like a 11-16mm Tokina). Sometimes group shots even require wider lenses, and even distortions may make for a more edgy photo.
      08-08-2011, 03:17 PM   #3840
oneintheory
i use a 17-40, but i use default correction profiles in LR3. i can notice a huge difference between 17 and 35mm in terms of distortion. however, when you put the subject in the middle of the frame and they only take up a small part of it, distortion is mitigated. what you're suggesting, though (wider angle, move closer) would make the subject closer to the lens and would push her more to the edges of the frame where distortion occurs.
      08-08-2011, 03:28 PM   #3841
dcstep
Drives: '09 Cpe Silverstone FR 6MT
2009 M3  [8.40]
Everybody using wide zooms should be automatically correcting for vignetting, geometric distortion, CA, etc. in RAW coversion. DxO, LR, ACR and others provide this and it's pretty darn amazing. If you want purposeful distortion, you can turn it off, but in most cases you'll want it. It brings zoom lenses into competition with the very best primes (which can also be corrected).
Long-gone are the days when you had to get it right in the camera and primes were all most self-respecting pros would use.
Too few seem aware of the capability of the latest conversion softwares. DxO corrects for every aperture at every focal length of the lenses included in their database. It's amazing.
Dave
      08-08-2011, 03:48 PM   #3842
- Paul -
- Paul -'s Avatar
England
740
Drives: see above.
2005 320D SE  [10.00]
2005 645  [9.00]
I use DXO also - great software for batch conversion aswell.
      08-08-2011, 03:54 PM   #3843
Weebl
Weebl wobbles but eats Pie
95
Drives: 2012 X5 d,2008 335i, 2000 740i
Dave
The few, the ignorant and the learning..
I thought it just fixed a portion of the CA and not the barrel/pincushion.
Kevin Goto
2000 740i-Annalisa (sold 2018) 2008 335i-Weebl. Weebl may wobble but has DTC 2012 X5d in Sparkling Bronze ( The Ultimate Cat Carrying Machine)-RIP BMW buyback 2019:2017 A3, 2018 Audi SQ5
      08-08-2011, 04:02 PM   #3844
dcstep
2009 M3  [8.40]
DxO corrects for it all, particularly barrel and pincushion. I'm not sure how far LR and ACR go.
Dave
      08-08-2011, 05:04 PM   #3845
rodi
186
Drives: your FACE!
what makes you happy with the background???
and how is that edgy?
      08-08-2011, 05:07 PM   #3846
Chewy734
Dave
Good question. I haven't played around with lens correction in LR3, but here's some documentation on it (for those of us who are interested):
http://help.adobe.com/en_US/Lightroo...6de9-8000.html
      08-08-2011, 05:11 PM   #3847
Chewy734
now play nice rodi
Honestly, I'm with Mark and rodi on this one... not really sure what Josh was trying to do.
      08-08-2011, 05:15 PM   #3848
Weebl
95
Kevin Goto
      08-08-2011, 05:32 PM   #3849
Chewy734
Hmm... I just realized that my 7 year old 20D has a higher fps than the much newer 5DMK2 (hopefully it'll be here by the weekend). I wonder if that's something I'm gonna miss having.
      08-08-2011, 05:39 PM   #3850
UdubBadger
Drives: '04 330i ZHP
2004 BMW 330i ZHP  [9.50]
2011 135i  [7.46]
2008 328xi  [8.76]
thats why i kept my 40D... for shooting sports/action
Closed Thread
