08-22-2024, 12:38 AM | #1 |
Rep 320
Posts Drives: 2016 F30 340xi M Sport Join Date: Sep 2013
Did I damage my steering wheel? Or is it still just dirty?
Hey all — I attempted to deep clean and condition my leather steering wheel this afternoon, and I was a little alarmed at the results. I used Chemical Guys Leather Cleaner and a microfibre cloth. I was not rough at all. I sprayed the cleaner onto the cloth, and started cleaning the wheel. I noticed that black/dark indigo residue started appearing on the cloth, which I assumed was dirt/grime. I then followed-up with a coat of Chemical Guys Leather Conditioner.
Did I mess up? I'm not entirely sure if I removed some sort of top-layer of coating/finish, or if the wheel was just *that* dirty and it's still not clean. It's my first time doing this. Any help would be much appreciated.
2016 F30 340xi M Sport |
08-22-2024, 04:21 AM | #2 |
Rep 99
Strangely, it does look like the surface dye or top layer is damaged. I had wear on my 2003 and redyed it with leather color restorer. It looks virtually brand new. If you elect to do it, start and end on a seam. Do it in a cool location and let it dry for 24hrs untouched. It was very simple.
https://www.amazon.com/dp/B07R4GD4HX...sin_title&th=1
tracer bullet3457.50 |
08-22-2024, 04:53 AM | #3 |
Rep 803
Are you sure it is leather?
Is it possible that the lighter shade is wear from use? Hard to tell from the photos, it does kind of look like dirt might be filling the pores still, if the dye has been rubbed off you will have to refinish anyway. I would take an old toothbrush, put some cleaner on it and gently rock it back and forth on one spot, it could be it just needs one more application of cleaner.
2008 E86 M coupe
08-22-2024, 05:32 AM | #4 |
Rep 143
Stop using all that bs cleaner/conditioner garbage. It does more harm than good.
Buy a bar of PEARS soap. Use a clean microfibre cloth with warm water and work that around the wheel to open up the leather a bit. Lather up a soft paint or detailer brush with PEARS, work it around the wheel (or work in sections). Let it sit for a min or two. Use another clean, warm, damp microfibre cloth to wipe the soap out of the wheel. Use another clean, dry microfibre cloth to do a final wipe on the wheel. Repeat process if your wheel was disgusting/shiny. Your wheel will look like it came straight from the factory again - nice and clean and MATTE. Do this a couple of times per year, or at whatever interval you need to, and your wheel will always look great. Everything else is a scam in my book. I use the soap to clean the entire interior using the same process. |
08-22-2024, 05:55 AM | #6 | |
Rep 125
08-22-2024, 07:14 AM | #7 |
Rep 6
I use Gyeon Mild Leather Cleaner and a microfiber scrub pad/sponge. Steering wheel is also ceramic coated.
In my previous X5 and 540i, the leather began to discolor similar to the pictures by OP (although not as bad). In those cases I was using the BMW leather cleaner and an actual brush. About 2-3 times a month. In hindsight, I think it the brush was too hard and messed up the dye over time. |
08-22-2024, 08:22 AM | #8 |
Rep 921
I use Sonex on my alcantara/leather steering wheel and have zero issuses.
2018 F80 M3. YMB/BLK. ZCP. Three Pedals.
"Education will never be as expensive as ignorance." |
08-22-2024, 08:43 AM | #9 |
Rep 4,166
Posts Drives: BMW M3 Join Date: Feb 2011
@OP It looks like the finish is worn off. You might try the suggestions here, but you might be looking at getting it refinished or having an excuse to upgrade to a new wheel.
Charles
2024 BMW M3 Sedan Frozen Pure Grey II/Fjord Blue, 6MT
Past: 2021 Z4 M40i Frozen Grey II/Black Alcantara | 2017 F30 340i Mineral Gray/Coral Red, 6MT | 2011 E92 335i Le Mans Blue/Black, 6MT |
08-22-2024, 08:47 AM | #10 |
Rep 3,644
Bottom line is the dye has worn off, most likely from use and the way you turn your wheel and also hand lotions can contribute.
All you did with the cleaner is remove the oils that were covering the worn out spots. Within a month of use those will be covered again. So you're left with redying it or living with it the way it is. |
08-22-2024, 10:33 AM | #11 |
YNWA
1152
Rep 878
Your wheel is cooked
/// 2004 Silvergrey M3 · Coupe · 6MT · Slicktop · zero options
/// 2011 Jerez/Bamboo E90 M3 · DCT · Slicktop · IG: @na.s54 |
08-22-2024, 10:54 AM | #12 |
Rep 334
Patina!
Also, consult a medical professional about that whole "swamp hands" thing.
Carbon Black - Debadged|Mocha Nappa|DHP|DAP|Executive|Luxury Seating|M668 w/ DSW06+
08-22-2024, 10:54 AM | #13 |
Grandmaster
919
Rep 875
The steering wheel in my car had degraded enough by only 20k miles of normal use that i opted to get a alcantara wheel. I just couldnt stand how easily the stock wheel degraded and it looked awful right in front of my face every time i drove.
I love my new alcantara wheel, one of my favorite mods on my car.
Daily - 2018 Alpinweiß ///M2 6MT Exec Rain/Snow/Winter - 2011 328i 6MT Sedan - Black on Black, Sport Package Sold, But Not Forgotten - 2009 135i 6MT - Black on Black, M-sport, JB4 |
08-22-2024, 11:58 AM | #14 |
Rep 474
I had the same exact thing on my F30. It was quality in that generation for sure because I've been using Sonax Leather Cleaner for well over a decade and never had an issue. Granted I think my E90 M3 had real leather vs the F30 had dye. I'm starting to see some fading on my G20 steering wheel and it's very annoying.
08-22-2024, 12:22 PM | #15 | |
Rep 334
There was some strange downward streaking on the instrument panel, like someone swiped at it with a wet rag during a wash. I carefully cleaned it with Sprayway glass cleaner and a fresh microfiber and it all came away - after three tries.
08-22-2024, 12:46 PM | #16 | |
Rep 320
I've been pouring over similar threads here and on Reddit, and the consensus seems to be it's either dye fading, or it's actually embedded dirt, and just requires a deeper clean. I have a horse hair brush arriving today. I'm going to give that a shot in hopes that it actually is embedded dirt that's working its way out. If that doesn't work, I'll just have to redye the wheel. Or live with it.
DrVenture998.50 grannyknot1003.50 |
08-22-2024, 12:52 PM | #17 |
Rep 2,362
I looks like the dye is gone in some areas. Here's a repair kit to consider:
https://leatherique-restoration-prod...heel-kit-black
____________________________________________
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system, Blue Metallic Matt Accent Moldings, Aluminum Hexagon Interior Strips, Anthracite Headlining |
DrVenture998.50 |
08-22-2024, 01:26 PM | #18 |
Rep 4,503
Just get a new wheel, they are a dime a dozen (slightly used).
Current: 2024 BMW M3 Competition xDrive | 2022 Audi Q7
Gone: 2022 Audi RS5 | 2020 BMW M340i | 2019 Audi RS5 |
08-22-2024, 03:02 PM | #19 | |
Rep 474
DrVenture998.50 |
