Go Back   BMW E39 5-Series Forum | 5Post.com > BIMMERPOST Universal Forums > General BMW News and Cars Discussion
      06-08-2022, 03:18 PM   #1
G30M
G30M's Avatar
5080
Drives: M550i; retired - M340i
Tire pressure - why my tires look so flat?
I see that these racing people with high volume tires set tire pressures at 21, 24 something like that
I have 255/35/19 RFTs and i am to set it at 39-50 COLD!
I tried 35PSI and the tire looks so flat
Even at 39 it still looks flat
What gives?
M340i is about 4000lbs with me in it
      06-08-2022, 03:19 PM   #2
G30M
G30M's Avatar
5080
second question - maybe i need higher volume tires?
255 40 18 is exactly yhe same size i am after performance first second comfort looks not important
any advice?
      06-08-2022, 04:00 PM   #3
DanG
DanG's Avatar
Drives: 2018 M2 AW DCT
2018 BMW M2  [7.95]
any advice?
If you are performance first, get rid of those run flats. Try Michelin PS4Ss in stock size. I run at stock pressure and tires look fine.
DrFerry6803.50
      06-08-2022, 04:12 PM   #4
Westside Guy
Westside Guy's Avatar
7107
Drives: 22 Z4 M40i, 21 228i Retired
At the very least the OP should consider the Michelin Pilot Super Sports. They come as standard equipment when you order the 19 inch wheels on the Z4 M40i. BMW recommends 32 psi when the tires are cold and they look perfectly fine.
That being said I will probably get the Pilot Sport 4s tires when it is time to replace my SS ones as the 4s is a fabulous dry and wet performer and perfect for where I live in South Florida.
DrFerry6803.50
      06-08-2022, 04:26 PM   #5
HighlandPete
Drives: BMW F11 535i Touring
255 40 18 is exactly the same size i am after performance first second comfort looks not important
any advice?
Got to ask, what is the problem? If the pressure is in the working range, you have the performance first, comfort second. How it looks is simply a case of "that is how it is", looking flat is not a problem.
Smaller diameter rims give higher sidewalls and performance gives way to more comfort. That's what you'd be doing with a higher aspect ratio on your current rims.
DrFerry6803.50
      06-08-2022, 04:34 PM   #6
Tommysalami
Tommysalami's Avatar
566
Drives: E92 M3
Pics?
I ran a (non-performance all season) tire at too low pressure during an autox a long time ago and think I destroyed the sidewalls inner construction. After that no matter the pressure, the sidewalls sagged out a bit and they looked flat.
      06-08-2022, 07:11 PM   #7
G30M
G30M's Avatar
5080
the issue is that performance track cars run high(er) volume tires [eg 265 35 18] and low pressures [24 psi] - but hey it was a stripped out F series M4 ... so perhaps very light
when i look at mine it's low volume and high pressure!
maybe a storm in a teacup ... 255 35 19 is probably same volume as 265 35 18 if not more ...
will do some more reading ....
yes that's why i'm asking questions, will be ditching RFTs on my next set
      06-09-2022, 04:19 AM   #8
HighlandPete
A lot of variables and different requirements when we compare a track/race car. The M4 road setup is not on those sizes, if running 18" wheels. (255/40 ZR18 95Y / 275/40 ZR18 99Y on 9.0J x 18 / 10.0J x 18). The track setup you mention means the sidewall height is less than the road car. BTW, was the M4 running a square setup, or are you talking front or rear sizing?
You'd also need to know rim widths for those sizes, that also has an influence, besides the pressure. I'd say the key thing to consider is, a stripped out track/racing coupe is far different for weight and chassis balance than a road going, load carrying wagon.
      06-09-2022, 07:48 PM   #9
G30M
G30M's Avatar
5080
hmm my car recommends (255 35 19) 39 psi min
whereas the G80 recommends 32 psi min for the same tire
https://www.carsguide.com.au/bmw/m-m.../tyre-pressure
      06-09-2022, 07:56 PM   #10
G30M
G30M's Avatar
5080
3 Series
